VRX System Image
Changelog for the system image used by the VRX SDK (ubun2.0-multi) on the VRX Ground Unit.
  1. Overview
  2. System Image Changelog
    1. 2.0.2-perf-20261117
    2. 2.0.2-perf-20261110
    3. 2.0.2-perf-20261105
    4. 2.0.2-perf-20261004
The VRX system image is the operating system for the VRX Ground Unit: a Linux 5.4 kernel, an Ubuntu 20 root file system, and firmware for the other processors on board. It is a separate image from the VOXL 2 and VOXL 2 Mini system image.
The system image ships inside VRX SDK releases (ubun2.0-multi_SDK_x.y.z.tar.gz) and is flashed as part of the SDK install, see the SDK flashing instructions. It is not distributed separately. Get the VRX SDK from the Downloads page.
2.0.2-perf-20261117
ReleasedNovember 18, 2026 · Ships with SDK 1.8.1
Changes:
  • Faster channel-width changes on the VRX radio
  • VRX radio transmit power can be set at every channel width
  • Quieter radio driver logs
  • Radio driver improvements for link robustness
2.0.2-perf-20261110
Pre-release image, not shipped in an SDK release. Its changes are included in 2.0.2-perf-20261117.
Changes:
  • 5/10 MHz channel support is now the default on the Gen 1.5 VRX
2.0.2-perf-20261105
Pre-release image, not shipped in an SDK release. Its changes are included in 2.0.2-perf-20261110.
CVE fixes:
  • OpenSSL, rsync, kmod and brotli package updates
Changes:
  • Opt-in 5/10 MHz channel support on the Gen 1.5 VRX; leaving 5/10 MHz takes a full reset
  • Radio driver: channel-width changes on the same frequency, and a fix for starting at a narrow width
  • RF occupancy scanner support on the Gen 1.5 VRX
  • Display capture enabled (used by pilot view recording)
2.0.2-perf-20261004
ReleasedOctober 2026 · Ships with SDK 1.8.0
