LegacyThis documents a legacy product. Newer alternatives may be available.
VOXL Camera Configurations
  1. Camera Ports
  2. Configurations
    1. 1 Tracking + Stereo
    2. 2 Tracking Only
    3. 3 High-Resolution + Stereo + Tracking
    4. 4 High-Resolution + Tracking
    5. 5 TOF + Tracking
    6. 6 High-Resolution + TOF + Tracking
    7. 7 TOF + Stereo + Tracking
    8. 8 High-Resolution Only
    9. 9 TOF Only
    10. 10 Stereo Only
  3. Configuration Files
  4. Compatible Image Sensors
Camera Ports
VOXL has 3 camera connectors Labeled J2, J3, J4 in the two images below.
VOXL Core Connected
Image 1 - VOXL Bottom View
VOXL Core USB
Image 2 - VOXL Top View
The connectors are attached to the following Camera Subsystem ports and have the following colloquial names. Note that the ports can be used in other configurations as described bellow, not just the purpose described by the port’s colloquial name.
PortCamera SS PortColloquial Name
J2CSI0High-Resolution 4k RGB Port
J3CSI1Stereo Camera Port
J4CSI2Tracking Camera Port
Configurations
1 Tracking + Stereo
PortCameraCamera ID
J2EmptyN/A
J3Stereo Cameras1
J4Tracking Camera0
2 Tracking Only
PortCameraCamera ID
J2EmptyN/A
J3EmptyN/A
J4Tracking Camera0
This is the default configuration for the M500 Drone
PortCameraCamera ID
J2High-Resolution 4k RGB0
J3Stereo Cameras2
J4Tracking Camera1
PortCameraCamera ID
J3EmptyN/A
J4Tracking Camera1
5 TOF + Tracking
PortCameraCamera ID
J2emptyN/A
J3TOF time-of-flight0
J4Tracking Camera1
PortCameraCamera ID
J3TOF time-of-flight1
J4Tracking Camera2
This is the default configuration for the Seeker Drone
PortCameraCamera ID
J2TOF time-of-flight2
J3Stereo Cameras1
J4Tracking Camera0
PortCameraCamera ID
J3EmptyN/A
J4EmptyN/A
9 TOF Only
PortCameraCamera ID
J2EmptyN/A
J4EmptyN/A
10 Stereo Only
PortCameraCamera ID
J2EmptyN/A
J3Stereo Cameras0
J4EmptyN/A
Configuration Files
Rarely, if ever, will you need to touch these configuration files manually. In most cases you can use the voxl-configure-cameras script as described above.
Sensor ModuleSensorResolution / FOVDescriptionMinimum System Image
ModalAI MSU-M0024Sony IMX2144kHigh-Resolution2.0
ModalAI MSU-M0025Sony IMX2144kHigh-Resolution2.0
ModalAI MSU-M0026Sony IMX3774kHigh-Resolution2.0
ModalAI MDK-M0061-1Sony IMX4124kHigh-Resolution2.5.1
ModalAI Stereo SensorOV7251640x480 85.6º diagonalStereo2.0
ModalAI MSU-M0014-1-01OV7251640x480 166º diagonalTracking2.0
Sunny GP161COV7251640x480 85.6º diagonalStereo2.0
ModalAI MSU-M0072-1-00 equivalent to Sunny MD102AOV7251640x480 166º diagonalTracking2.0
ModalAI MSU-M0040-1-01 PMD TOF LiteOn A65irs10x0c224x172 110º horizontalTOF (Time of Flight)2.3
Next: Docker on VOXL
