libmodal-flow
libmodal-flow is the visual frontend used by open-vins-server on VOXL for feature-point detection and sparse optical-flow tracking. It ingests grayscale camera frames (commonly from tracking_*_misp_norm_ion pipes), builds image pyramids on GPU, detects keypoints, and tracks points frame-to-frame.
  1. Public Header APIs
    1. Additions in SDK 1.8.0 (libmodal-flow 1.0.10)
    2. Core types
    3. Manager operations
    4. Detect and track IO
  2. Field Reference (Used in Detect + Track Examples)
    1. modal_flow::Camera
    2. modal_flow::ImageDesc, modal_flow::ImageView, and modal_flow::Frame
    3. modal_flow::DetectOptions
    4. modal_flow::DetectInput
    5. modal_flow::DetectResult
    6. modal_flow::TrackInput
    7. modal_flow::TrackOptions
    8. modal_flow::TrackResult
    9. Point layout (modal_flow::Keypoint) and indexing
    10. ion_buf_release_msg_t (manual ION release)
  3. Example Workflow: Detect + Track from ION pipes
    1. 1) Create the flow manager, detector/tracker, and register cameras
    2. 2) Subscribe to camera ION pipes
    3. 3) In the ION callback: claim pyramid buffers and upload frames
    4. 4) Run feature detection
    5. 5) Run tracking between previous and current buffers
    6. 6) Release pyramid buffers (release_pyramid) after detect/track use
    7. 7) Release ION buffers when images are no longer needed
  4. Notes
Public Header APIs
The current user-facing headers are in:
  • library/include/modal_flow/Types.hpp
  • library/include/modal_flow/Manager.hpp
  • library/include/modal_flow/Detector.hpp
  • library/include/modal_flow/Tracker.hpp
In the current examples, users instantiate the OpenCL backend directly via:
  • library/include/modal_flow/ocl/OclDevice.hpp
  • library/include/modal_flow/ocl/ManagerCL.hpp
  • library/include/modal_flow/ocl/DetectorCL.hpp
  • library/include/modal_flow/ocl/TrackerCL.hpp
  • Stereo matching: StereoMatcherCL (match_stereo) is a ZNCC epipolar-band stereo matcher. ManagerCL and StereoMatcherCL layouts are part of the public headers.
  • Exclusion masks: detection, temporal tracking and stereo matching accept optional strided exclusion masks. The mask geometry is validated. Adding the masks changed the public input structs, so code built against libmodal-flow 1.0.5 (SDK 1.6) must be rebuilt.
  • Version check: the installed modal_flow/Version.hpp provides MODAL_FLOW_VERSION_STR, the C-linkage modal_flow_runtime_version() and modal_flow::version_matches(), so an application can refuse to run against a library other than the release it was compiled with.
  • Kernel profiling: ManagerCL::set_queue_profiling(bool), called before add_camera(), turns on OpenCL event profiling so the kernel-time accessors report values.
Core types
Types.hpp defines Camera, ImageView, Frame, BufferId, Keypoint, and related enums (PixelFormat, ExternalType, Backend).
Manager operations
Manager.hpp exposes camera and buffer lifecycle plus batched detection/tracking:
  • add_camera() / remove_camera()
  • acquire_pyramid_buf() / release_pyramid()
  • upload_frame_to_buf()
  • detect_many() and track_many()
Detect and track IO
Detector.hpp defines:
  • DetectOptions
  • DetectInput
  • DetectResult
Tracker.hpp defines:
  • TrackInput
  • TrackResult
This section maps the commonly initialized structs to the field values used by the test apps.
FieldMeaningExample value(s)
idLogical camera identifier used throughout manager/detect/track calls0 (front), 1 (down)
widthFrame width in pixels1280
heightFrame height in pixels800
formatCamera pixel formatmodal_flow::PixelFormat::R8
add_camera(cam, num_bufs) also sets how many internal pyramid buffers are reserved per camera. The examples use num_bufs = 3 (detect) and num_bufs = 6 (track).
These wrap each incoming ION frame before upload.
TypeFieldMeaningExample value
ImageDescwidthImage widthdata->img_meta.width
ImageDescheightImage heightdata->img_meta.height
ImageDescformatPixel formatmodal_flow::PixelFormat::R8
ImageDescstrideBytesRow stride in bytesdata->img_meta.stride
ImageViewdataCPU pointer input (unused when external handle is used)nullptr
ImageViewhandle_typeExternal buffer handle typemodal_flow::ExternalType::ClMem
ImageViewexternal_handleOpaque cl_mem handle valuecast of cl_mem_out[ch]
FramecamCamera id associated with this frame(modal_flow::CameraId)ch
FrametTimestamp field (ns)0 in these tests
FrameimgImage payload wrapperiv
FieldMeaningValue used in modal-flow-test-detect
border_xLeft/right image border ignored by detector3
border_yTop/bottom image border ignored by detector3
thresholdFAST-like detection threshold35.f
use_grid_detectEnable grid-partitioned detectiontrue
horizontal_grid_cellsNumber of grid columns5
vertical_grid_cellsNumber of grid rows5
grid_cells_to_searchExplicit grid cells to searchall (row, col) pairs from (0,0) to (4,4)
use_nmsEnable non-max suppressiontrue
FieldMeaningValue set in example
cam_idCamera id to run detect oni
img_bufClaimed pyramid buffer id for that camerag_img_buf[i]
optsDetect options for this camerashared opts instance
detect_many() returns:
  • std::vector<modal_flow::DetectResult> (one result per input camera)
  • each DetectResult contains keypoints (std::vector<modal_flow::Keypoint>)
Minimal usage pattern:
std::vector<modal_flow::DetectResult> results = mgr->detect_many(in);
const auto& cam0 = results[0];
for (const auto& kp : cam0.keypoints) {
    float x = kp.x;
    float y = kp.y;
    float score = kp.score;
    // use or filter keypoints here
Example shape of one camera result:
// Pseudodata for illustration
modal_flow::DetectResult cam0_result;
cam0_result.keypoints.push_back(modal_flow::Keypoint{102.3f, 87.1f, 34.0f});
cam0_result.keypoints.push_back(modal_flow::Keypoint{245.8f, 121.6f, 41.0f});
cam0_result.keypoints.push_back(modal_flow::Keypoint{512.0f, 300.4f, 29.5f});
FieldMeaningValue set in modal-flow-test-track
prev_cam_idCamera id for previous framei
next_cam_idCamera id for current framei
prev_img_bufBuffer id containing prior frame pyramidprev_img_buf[i]
next_img_bufBuffer id containing current frame pyramidnext_img_buf[i]
prev_pointsInput keypoints to propagateseed_pts / current tracked points
TrackOptions exists in the API and provides LK tuning parameters. The current track example uses library defaults (it does not override them in TrackInput).
FieldMeaningDefault value in header
winLK tracking window size21
max_itersMax LK iterations per level30
epsilonConvergence tolerance0.01f
FieldMeaningHow example uses it
next_pointsTracked keypoints for next frameupdates g_current_points
statusPer-point validity flag (1 success, 0 lost)success keeps trajectory; lost resets to origin
errorPer-point tracking error metricreturned but not thresholded in this test
The point type used by detect and track is:
FieldTypeMeaning
xfloatX pixel coordinate
yfloatY pixel coordinate
scorefloatDetector/tracker score or confidence-like value
Practical construction example:
std::vector<modal_flow::Keypoint> seed_pts;
seed_pts.push_back(modal_flow::Keypoint{100.f, 100.f, 0.f});
seed_pts.push_back(modal_flow::Keypoint{320.f, 240.f, 0.f});
seed_pts.push_back(modal_flow::Keypoint{640.f, 400.f, 0.f});
Detect output shape:
  • DetectResult.keypoints is std::vector<modal_flow::Keypoint>.
  • Each entry is one detected feature point with x/y/score.
Track input/output shape:
  • TrackInput.prev_points is the input point vector for a frame-to-frame track step.
  • TrackResult.next_points, TrackResult.status, and TrackResult.error are aligned by index with prev_points.
Index alignment example:
for (size_t i = 0; i < res.status.size(); ++i) {
    const auto& prev = seed_pts[i];          // input point i
    const auto& next = res.next_points[i];   // tracked output for point i
    uint8_t ok = res.status[i];              // 1=tracked, 0=lost
    float err = res.error[i];                // tracking error for point i
When CLIENT_FLAG_MANUAL_ION_BUF_RELEASE is set, the detect test releases each consumed ION buffer using:
  • client_id = 0
  • buffer_id = data->buffer_id
  • generation = data->generation
and sends that struct via pipe_client_send_control_cmd_bytes(...).
The code below is adapted directly from:
  • examples/modal-flow-test-detect.cpp
  • examples/modal-flow-test-track.cpp
libmodal-flow is not open source; the library and its examples are installed on target as part of the VOXL SDK.
auto& dev = modal_flow::ocl::OclDevice::Instance();
mgr = new modal_flow::ocl::ManagerCL(dev);
auto det = std::make_unique<modal_flow::ocl::DetectorCL>(dev, /*nms_radius*/ 3);
mgr->set_detector(std::move(det));
auto trk = std::make_unique<modal_flow::ocl::TrackerCL>(dev);
mgr->set_tracker(std::move(trk));
modal_flow::Camera cam_front{.id = 0, .width = 1280, .height = 800,
                             .format = modal_flow::PixelFormat::R8};
int num_bufs = 3;
mgr->add_camera(cam_front, num_bufs);
for (int ch = 0; ch < kNumCh; ++ch) {
    pipe_client_set_ion_buf_helper_cb(ch, _ion_buf_cb, nullptr);
    pipe_client_set_disconnect_cb(ch, _disconnect_cb, nullptr);
    pipe_client_open(
        ch,
        pipes[ch].c_str(),
        CLIENT_NAME,
        CLIENT_FLAG_EN_ION_BUF_HELPER | CLIENT_FLAG_MANUAL_ION_BUF_RELEASE,
        0);
Use CLIENT_FLAG_MANUAL_ION_BUF_RELEASE when your app will explicitly release buffers back to the producer.
modal_flow::ImageDesc desc{data->img_meta.width, data->img_meta.height,
                      modal_flow::PixelFormat::R8, data->img_meta.stride};
modal_flow::ImageView iv{desc,
                         nullptr,
                         modal_flow::ExternalType::ClMem,
                         static_cast<uint64_t>(reinterpret_cast<std::uintptr_t>(cl_mem_out[ch]))};
modal_flow::Frame f{(modal_flow::CameraId)ch, 0, iv};
if (g_img_buf[ch]) {
    mgr->release_pyramid((modal_flow::CameraId)ch, g_img_buf[ch]);
    g_img_buf[ch] = 0;
g_img_buf[ch] = mgr->acquire_pyramid_buf((modal_flow::CameraId)ch);
mgr->upload_frame_to_buf(f, g_img_buf[ch]);
This is the claim/use/release cycle for internal pyramid buffers.
std::vector<modal_flow::DetectInput> in(kNumCh);
modal_flow::DetectOptions opts;
opts.border_x = 3;
opts.border_y = 3;
opts.threshold = 35.f;
opts.use_grid_detect = true;
opts.horizontal_grid_cells = 5;
opts.vertical_grid_cells = 5;
opts.use_nms = true;
for (int i = 0; i < kNumCh; i++) {
    in[i].cam_id = i;
    in[i].img_buf = g_img_buf[i];
    in[i].opts = opts;
auto res = mgr->detect_many(in);
std::vector<modal_flow::TrackInput> inputs(kNumCh);
for (int i = 0; i < kNumCh; ++i) {
    inputs[i].prev_cam_id  = i;
    inputs[i].next_cam_id  = i;
    inputs[i].prev_img_buf = prev_img_buf[i];
    inputs[i].next_img_buf = next_img_buf[i];
    inputs[i].prev_points  = seed_pts;
std::vector<modal_flow::TrackResult> results = mgr->track_many(inputs);
The API method is release_pyramid(CameraId, BufferId) (there is no release_pyramid_buf symbol in the header).
Recommended lifecycle:
  • claim: BufferId id = mgr->acquire_pyramid_buf(cam_id);
  • use: mgr->upload_frame_to_buf(frame, id); and run detect/track using that id
  • release: mgr->release_pyramid(cam_id, id); when the buffer is no longer needed
Common patterns used in the examples:
  • detect loop: release previous frame’s g_img_buf[ch] before acquiring the next one
  • track loop: when next_img_buf[ch] becomes prev_img_buf[ch], release the old previous buffer first
  • shutdown: release any remaining non-zero BufferId values before exit
Minimal cleanup pattern:
        g_img_buf[ch] = 0;
If manual release is enabled, return each consumed buffer to the producer:
ion_buf_release_msg_t msg;
msg.client_id  = 0;
msg.buffer_id  = data->buffer_id;
msg.generation = data->generation;
int ret = pipe_client_send_control_cmd_bytes(ch, &msg, sizeof(ion_buf_release_msg_t));
Without this release step, camera producers can stall due to unreleased buffers.
Notes
  • modal-flow-test-detect demonstrates a detection-oriented pipeline and explicit ION buffer release.
  • modal-flow-test-track demonstrates temporal tracking with prev_img_buf/next_img_buf and TrackResult.status handling.
  • For clean shutdown, close all subscriptions with pipe_client_close_all().
