MVX Link Diagnostics
Check link health with voxl-inspect-vtx and voxl-inspect-vrx, fix common problems, and collect logs for support.
  1. Inspect the link
    1. Most useful columns on the VRX
    2. Most useful columns on the drone
  2. Common problems
  3. Collect logs for support
voxl-inspect-vtx on the drone and voxl-inspect-vrx on the VRX print a live line of link statistics per video frame. Run them over ADB or SSH:
voxl-inspect-vtx      # on the drone
voxl-inspect-vrx      # on the VRX
Add -n to print each sample on a new line instead of updating one line, which is easier to copy into a support request.
ColumnMeaning
total(ms)Latency from the end of the camera exposure to the VRX drawing the frame. The display’s own scan-out is not included.
vtx(ms), vrx(ms)The part of that latency spent on the drone and on the VRX.
decode(ms), render(ms)Time to decode and to display the frame on the VRX.
fps, rx fpsDisplayed and received frame rates.
rssi, snr, noise_floorSignal strength, signal-to-noise ratio and noise at the VRX. Higher SNR is better.
packet_lossShare of video packets lost on the link.
dropsFrames the VRX dropped.
dmg flag/taint/hidFrames the decoder flagged as damaged, frames affected by lost data, and damaged frames hidden by the Freeze video loss mode.
vbat(VDC)The VRX supply voltage.
ColumnMeaning
cam(ms)Camera latency, from the camera exposure to the encoded frame reaching the VTX.
vtx(ms)From the camera exposure until the frame has been sent, including cam(ms).
out (mbps)Video bitrate being sent.
temp(C)Radio temperature.
pwr(dBm)Transmit power.
mcsCurrent radio data rate setting.
The other columns are for ModalAI support.
Common problems
SymptomWhat to check
No video, OSD shows INVALID ENCRYPTION KEYThe drone and VRX hold different keys. Install the same vtx.key on both. See Pairing & Encryption Keys.
No video, channel readout on the VRX is amberThe drone is frequency hopping and the VRX cannot follow it, usually because the keys differ. See Frequency Hopping.
No video at allCheck that both units are on the same channel and bandwidth: step through channels with buttons 1 and 4, or double-tap to scan. Check that both units run the same SDK release.
Picture breaks up at rangeUse a narrower channel or the Adaptive profile, pick a clearer channel with the RF occupancy scanner, or turn on frequency hopping. See Channels, Bandwidth & Power.
Damaged frames bother the pilotSwitch Video Loss to Freeze. See OSD Menu & Display.
Recording does not startCheck the REC message on the OSD and the USB flash drive requirements.
Changes from the drone menu do nothingDisarm the drone, then try again. On a second VRX, check that it is not an OBSERVER; see Multiple Ground Stations.
Frequency hopping does not startSee If hopping does not start.
When you contact ModalAI about a link problem, include:
  1. The SDK version on the drone and the VRX. The VRX SETTINGS menu footer shows both.
  2. Flight logs from both units for a flight that shows the problem. Turn logging on with VRX SETTINGS > RECORDING > Log before the flight (see Flight logs), then copy the logs off:
    adb pull /data/mvx/vtx/logs/     # from the drone
    adb pull /data/mvx/vrx/logs/     # from the VRX
  3. A few seconds of voxl-inspect-vrx -n and voxl-inspect-vtx -n output while the problem is happening.
  4. The service logs from each unit:
    journalctl -u voxl-vtx --no-pager > vtx.log     # on the drone
    journalctl -u voxl-vrx --no-pager > vrx.log     # on the VRX
Ask on the ModalAI forum or contact ModalAI support.
