voxl-osd
Provides the FPV on-screen display and stick menu, for MVX digital video or a third-party VTX.
- Overview
- Data Flow
- voxl-configure-osd
- Configuration File
- OSD Menu
- External Flight Controller (MSP)
- HDZero Output
- Debugging
- Source Code
voxl-osd provides the on-screen display (OSD) for FPV video: battery, RC link, flight mode, arm state, position, heading, VIO state, VTX temperature and power, and warnings. It also runs the OSD menu, a stick-driven menu in the goggles for changing the channel, video profile, flight modes, failsafe behavior, logging and other settings without a ground station.
On ModalAI MVX digital FPV systems (VTX Air Unit, Stinger and the VRX Ground Unit), voxl-vtx carries the OSD to the VRX, which draws it over the video at the display’s resolution. Which elements show, the color theme and the opacity are set on the VRX in VRX SETTINGS > OSD; see OSD Menu & Display.
voxl-osd also lays out a character-cell canvas in the standard MSP DisplayPort format, which it can send over UART to a third-party VTX that supports MSP input.
Run the same SDK release on the drone and the VRX. SDK 1.8.1 ships voxl-osd 1.8 and voxl-vtx 3.19. See MVX Software Setup.
voxl-osd is enabled by voxl-configure-mpa on FPV SKUs such as Stinger and the VTX Air Unit, and disabled by default everywhere else. It runs as the systemd service voxl-osd.service, starting after voxl-px4 (without requiring it) and restarting automatically.
The OSD as the VRX draws it in SDK 1.8.1. The numbered elements are explained in OSD Menu & Display.
Data Flow
By default the service reads everything it displays from MPA pipes and writes the finished canvas to one output pipe.
| Pipe | Direction | Used for |
mavlink_onboard | in | PX4 telemetry from voxl-mavlink-server: battery, attitude, GPS, RC channels, arm state, flight mode |
mavlink_from_gcs | in | MANUAL_CONTROL from the ground, so the menu also responds to a joystick sent over IP |
ov, qvio | in | VIO quality from voxl-open-vins-server or voxl-qvio-server |
vfc | in | Assisted flight mode state from voxl-vision-hub, shown instead of PX4’s “OFFBOARD” |
vtx_latency | in | VTX temperature, TX power, and link stats from voxl-vtx |
cpu_stats2 | in | CPU and memory usage from voxl-cpu-monitor, for the optional usage lines and overload warnings |
payload_status | in | Optional payload arm and position strings shown at the top right |
msp_osd | out | The OSD and menu, consumed by voxl-vtx |
msp_ext_fc_status | out | Arm state of an external flight controller, published only in MSP input mode |
In external flight controller mode (see below) the MAVLink, VIO, and VFC inputs are replaced by an MSP UART link to the other flight controller.
voxl-configure-osd
voxl-configure-osd writes /etc/modalai/voxl-osd.conf and enables or disables the service. It must be run as root.
voxl-configure-osd factory_enable # reset the config to defaults and enable
voxl-configure-osd factory_enable_no_compass # defaults with the compass tape and degrees hidden
voxl-configure-osd external_fc # take input from an external MSP flight controller over UART
voxl-configure-osd hdzero # send the canvas over UART to an HDZero VTX
voxl-configure-osd enable # enable the service without touching the config
voxl-configure-osd disable # stop and disable the service
external_fc and hdzero pick the UART by platform:
| Platform | external_fc input port | hdzero output port |
| M0054, M0154 (VOXL 2) | /dev/ttyHS1 | /dev/ttyHS1 |
| M0104, M0204 (VOXL 2 Mini) | /dev/ttyHS0 | /dev/ttyHS0 |
| M0197 | /dev/ttyHS7 | none |
Other platforms fall back to /dev/ttyHS1 for input and leave the output port empty; on M0197, set output_port by hand for hdzero. Edit input_port or output_port in the config file if your wiring differs.
Configuration File
/etc/modalai/voxl-osd.conf is JSON. It is created with defaults the first time the service runs, and any missing keys are added with their defaults on load. To print the loaded values without starting the service:
voxl-osd -c
Input and Output
| Field | Default | Meaning |
input_protocol | 1 | 1 = MAVLink, 2 = MSP |
input_type | 1 | 1 = MPA pipes, 2 = UART |
input_port | "" | UART device when input_type is 2 |
output_type | 1 | 0 = none, 1 = MPA (to voxl-vtx), 2 = UART (HDZero), 3 = both |
output_port | "" | UART device when output includes UART |
emit_canvas | true | Emit the DisplayPort text canvas on the MPA output. UART output is never gated by this |
resolution | 1 | Canvas size in character cells: 0 = SD 30x16, 1 = HD 50x18, 2 = HD 30x16, 3 = HD 53x20 |
font_type | 0 | Font index reported to the VTX |
Display Toggles
show_compass_tape | true | Scrolling compass tape along the top of the canvas |
show_compass_degrees | true | Numeric heading in degrees. Shown even when the tape is off |
compass_fov_deg | 120 | Field of view of the compass tape |
show_mgrs | true | MGRS grid reference line |
mgrs_precision | 5 | MGRS digits per axis, 0 to 5 |
craft_name | "" | Free-text craft name drawn on the canvas |
show_vtx_cpu_mem_usage | false | VTX CPU and memory usage lines |
show_vrx_stream_stats | false | VRX stream statistics |
show_vio_overlay | false | VIO overlay |
show_thermal_flow | false | Thermal flow status |
show_mavlink | false | Saved state of the ADVANCED > MAVLINK FWD menu row, which turns MAVLink telemetry forwarding on the VTX on or off |
Element Positions
Every movable element has a *_col / *_row pair giving its character cell, origin top left. Set either value to -1 to hide the element. Defaults are for the HD 50x18 canvas.
Positions lay out the character canvas sent to an HDZero VTX. The MVX VRX draws its own layout and only takes the craft name position from here; turn its elements on or off in VRX SETTINGS > OSD.
| Element | Fields | Default (col, row) |
| RC link RSSI | rssi_col, rssi_row | 0, 0 |
| Compass tape | compass_col, compass_row | 22, 0 |
| VIO state | vio_col, vio_row | 1, 1 |
| Payload actuator state | payload_actuator_col, payload_actuator_row | 42, 2 |
| Payload status | payload_status_col, payload_status_row | 42, 3 |
| Craft name | craft_name_col, craft_name_row | 10, 3 |
| VTX temperature | vtx_temp_col, vtx_temp_row | 0, 4 |
| VTX TX power | vtx_dbm_col, vtx_dbm_row | 0, 5 |
| VTX CPU usage | vtx_cpu_usage_col, vtx_cpu_usage_row | 0, 6 |
| VTX memory usage | vtx_mem_usage_col, vtx_mem_usage_row | 0, 7 |
| Crosshair | crosshair_col, crosshair_row | 26, 8 |
| Velocity | velocity_col, velocity_row | 47, 13 |
| Altitude | altitude_col, altitude_row | 47, 14 |
| Distance and direction to home | to_home_col, to_home_row | 39, 14 |
| VTX overheat warning | vtx_overheat_warn_col, vtx_overheat_warn_row | 0, 14 |
| VTX overheat critical | vtx_overheat_crit_col, vtx_overheat_crit_row | 0, 15 |
| MGRS grid reference | mgrs_col, mgrs_row | 39, 15 |
| Armed / disarmed | disarmed_col, disarmed_row | 25, 15 |
| VTX CPU overload warning | vtx_overload_col, vtx_overload_row | 0, 16 |
| Latitude | latitude_col, latitude_row | 46, 16 |
| Status text | status_col, status_row | 24, 17 |
| VTX memory warning | vtx_mem_leak_col, vtx_mem_leak_row | 0, 17 |
| Longitude | longitude_col, longitude_row | 46, 17 |
| Flight mode | flight_mode_col, flight_mode_row | 24, 19 |
Current draw, pack voltage, and per-cell voltage are pinned to the bottom right (column 43, rows 17 to 19) and cannot be moved.
Menu and Flight Mode Fields
menu_up_threshold | 1550 | Pitch stick value (us) above which the cursor moves up |
menu_down_threshold | 1450 | Pitch stick value below which the cursor moves down |
menu_right_threshold | 1550 | Roll stick value above which a value is incremented |
menu_left_threshold | 1450 | Roll stick value below which a value is decremented |
menu_hold_delay_ms | 350 | How long the pitch stick is held before the cursor starts to autoscroll |
menu_hold_autoscroll_ms | 350 | Time between cursor steps while autoscrolling |
fltmode1_pset_mode, fltmode4_pset_mode, fltmode6_pset_mode | 0 | VFC assisted mode assigned to each flight-mode switch position, written by the Flight Mode menu |
shortcut | "OPT_A" | Unused, kept for compatibility |
Menu thresholds were 1650 / 1350 / 1850 / 1150 in voxl-osd 0.4.x. Versions from 1.0.0 on use the values above, so the menu needs less stick travel.
OSD Menu
With the vehicle disarmed, push throttle down, yaw right, pitch down and roll left to open the menu. On a Mode 2 transmitter that is both sticks down and in. A brief tap is enough, and the menu always opens at the main menu.
- Pitch up and down moves the cursor. Hold the stick to keep scrolling.
- Roll left and right changes the value on the selected row or enters the highlighted submenu.
- Submenus end with
BACK,EXIT(discard) andSAVE AND EXITrows; the main menu ends withEXITandSAVE AND EXIT. - Some changes ask for confirmation in a pop-up that lists what will happen.
When the drone is flown over an IP link with RC over IP instead of an RC receiver, the same stick inputs arrive from the ground station (see IP Radios & RC over IP). The menu is not available when the only output is UART to an HDZero VTX.
OSD Menu & Display describes the menu from the pilot’s side, including the VRX’s own settings menu. The table below adds what each row writes on the drone.
| Menu | Rows | What it changes |
| Main | CHANNEL, PROFILE, PIT, FLIGHT MODE, ADVANCED, VRX SETTINGS, EXIT, SAVE AND EXIT | CHANNEL opens a channel list grouped by band, and the setup for frequency hopping. PROFILE picks a VTX video profile. PIT turns pit mode on or off. VRX SETTINGS hands the sticks to the VRX’s own settings menu (see VRX SETTINGS menu) |
| Channel | MODE, then the channel list, or BAND, JAMMING AVOIDANCE and the channels to hop over | MODE is STATIC (one channel) or FREQUENCY HOPPING. Starting hopping shows a confirmation pop-up. Channels where the VTX transmits at reduced power are tagged LOW PWR. On Silvus and DTC links managed by voxl-vtx, the list shows the frequencies every radio supports, and SAVE AND EXIT retunes all of them |
| Flight Mode | FLIGHT MODE, SWITCH VALUE | Assigns a mode to the switch position currently selected on the transmitter. The scrollable picker lists the modes PX4 reports as available, including external modes by name. Writes COM_FLTMODE* and PSET_MODE and switches mode right away. Modes that need GPS are hidden when SYS_HAS_GPS is off. Shown only with PX4 over MPA |
| Advanced | RECORD TO LOCAL, MAVLINK FWD, BAT CELLS, RADIO, LOGGING, AR WAYPOINTS, RC CHANNELS, FAILSAFE, ELRS | RECORD TO LOCAL lets the VRX record to its internal storage when no USB drive is inserted. MAVLINK FWD turns MAVLink telemetry forwarding to the VRX on or off. BAT CELLS (1 to 12, default 4) writes the PX4 parameter BAT1_N_CELLS so the VRX can show per-cell voltage. FAILSAFE appears only with PX4 over MPA |
| Radio | BANDWIDTH, and on Silvus and DTC links DRONE POWER and GCS POWER | BANDWIDTH sets the channel width. It is read-only and shows HOP SET while hopping, ADAPTIVE when the active profile uses adaptive link, and N/A (IP) on IP links that voxl-vtx does not manage. On Silvus and DTC links it offers the widths every radio supports. DRONE POWER and GCS POWER set each radio’s transmit power (DTC shows FULL or dB below full). See IP Radios & RC over IP |
| Logging | VOXL-LOGGER-AUTO, DEBUG LOG, PX4 LOGGING | VOXL-LOGGER-AUTO records a voxl-logger session on each arm. DEBUG LOG sets the link’s flight log to DISABLED, ENABLED or ON ARM. PX4 LOGGING (PX4 drones only) turns PX4 logging on or off through ARTIFACT_MODE in /etc/modalai/voxl-px4.conf; a pop-up says whether a reboot is needed, and turning it off erases saved logs and missions on the next boot |
| RC Channels | live table | Read-only view of every RC channel value |
| Failsafe | RC LOSS TIME, RC LOSS ACT, RC FINAL DELAY, RC FINAL ACT, GCS LOSS TIME, GCS LOSS ACT | Writes COM_RC_LOSS_T, NAV_RCL_ACT, COM_RCL_ACT_T, COM_RCL_ACT, COM_DL_LOSS_T, and NAV_DLL_ACT. Actions: AUTO RTL, AUTO LAND, HOLD, TERMINATE, DISARM, DESCEND, plus DISABLED for GCS loss |
| ELRS | Custom Domain RX | ELRS receiver option |
| AR Waypoints | HOME WAYPOINT, LOCATION WAYPOINTS, CoT WAYPOINTS, CLEAR ALL WAYPOINTS | Augmented-reality waypoint markers on the video, including markers received as ATAK CoT. Enabling them checks the camera extrinsics for the vehicle; Stinger and the VTX Air Unit are not supported and show UNSUPPORTED VEHICLE SKU |
The VTX can act as the digital video system for a non-VOXL flight controller that speaks MSP over UART, such as Betaflight:
This sets input_type to UART and input_protocol to MSP. The service then polls the external flight controller at 20 Hz for RC channels, status, box IDs, battery, analog, and GPS, renders the OSD from those, and publishes the arm state on msp_ext_fc_status. No MAVLink or PX4 is involved. Setup, wiring and Betaflight notes are in External Flight Controller, and cable options in the VTX Air Unit Quick Start Guide.
HDZero Output
To drive a third-party HDZero VTX instead of, or as well as, voxl-vtx:
This resets the config to defaults, sets output_type to UART and the platform’s default output_port (VOXL 2: /dev/ttyHS1, VOXL 2 Mini: /dev/ttyHS0). Set output_type to 3 to keep the MPA output as well; the OSD menu needs the MPA output. Don’t also set PX4’s OSD option to HDZERO, which drives the same UART. See VOXL 2 with Third-Party VTX for the hardware side.
Debugging
voxl-inspect-services # is voxl-osd running and enabled?
journalctl -u voxl-osd -f # live service log
voxl-osd -c # print the loaded config and exit
ls /run/mpa/ # msp_osd should exist once the service is up
- No OSD in the goggles but video is fine: check that
voxl-osdis running and thatoutput_typeis1or3.voxl-vtxmust be running to carry the OSD to the VRX. - Telemetry fields blank: the service is up but
mavlink_onboardhas no data. Check voxl-mavlink-server and voxl-px4. - Menu does not open: the vehicle must be disarmed, and the sticks must pass the thresholds in the config. The RC Channels menu is the quickest way to see the values the service is reading.
- After editing the config file, restart the service with
systemctl restart voxl-osd.
Source Code
Source is at voxl-public/voxl-sdk/services/voxl-osd. It builds in the voxl-cross docker image per the repository README. Package versions shipped in each SDK are in the release notes.
