MVX External Flight Controller
Use the VTX Air Unit as the digital video system for a Betaflight or other MSP flight controller.
The VTX Air Unit can be the digital video system for a flight controller that is not a VOXL, such as one running Betaflight. The flight controller connects to the VTX’s OSD UART and speaks MSP; the VTX draws the OSD from it and sends it to the VRX. No MAVLink or PX4 is involved.
Set up the VTX
On the VTX, switch voxl-osd to the external flight controller mode:
voxl-configure-osd external_fc
voxl-osd then reads the flight controller’s arm state, RC channels, status, battery and GPS over the OSD UART and renders the OSD from them. See the voxl-osd page for details.
With an external flight controller:
- The OSD menu, channel changes and pit mode work from the transmitter sticks as usual.
- Zoom on the hi-res camera and white/black hot on thermal profiles are controlled from the flight controller’s RC channels.
- The RC dead man’s switch uses the flight controller’s RC failsafe.
- PX4-only menu rows (FLIGHT MODE, FAILSAFE, PX4 LOGGING) are not shown.
Wiring
The VTX Air Unit kits include cables for common flight controllers; the cable list and an example wiring diagram are in the VTX Air Unit Quick Start Guide under OSD MSP DP.
Betaflight Note (Rotor Riot F7)
The UART for DVTX had a bug in the 4.5 Betaflight firmware that we tested against, so we fixed it using the 4.5 maintenance branch. Here’s a docker project that can build the FW like we did:
https://gitlab.com/voxl-public/support/betaflight-build-docker
