Starling 2 & Starling 2 Max Hardware Quickstart
The Starling 2 and Starling 2 Max share the same VOXL 2-based compute stack and the same software experience — everything in the rest of this bootcamp applies identically to both. The differences are the airframe and the power system:
| Starling 2 | Starling 2 Max | |
| Battery | one 2S 18650 pack (e.g. Sony VTC6 3000mAh) with XT30 connector | two 2S 18650 packs, connected in series for an effective 4S (16.8V max), XT30 connectors |
| Airframe | 285g take-off weight, 220mm class | 500g take-off weight, 322mm carbon fiber airframe, 180mm folding props, 500g payload capacity |
| Power module | — | integrated in the ModalAI 4-in-1 Mini ESC |
| RC receiver | 915MHz ELRS | 915MHz ELRS |
Starling 2 Max requires both batteries installed — the two packs power the drone in series. Never mix a charged and a depleted pack.
Power On
- Inspect the airframe and propellers for damage from shipping.
- Install the battery (Starling 2) or both batteries (Starling 2 Max) and connect the XT30 connector(s).
- The drone boots automatically when battery power is applied. Startup takes roughly 30 seconds; the ESC will play its startup tone.
- Power on the transmitter. If your kit includes the iFlight Commando 8 handset, power it on with a short press of the power button followed by a long press. A short press on its own does not turn the handset on.
For full specifications, kit contents, and component part numbers, see the Starling 2 datasheet and Starling 2 Max datasheet.
Next
Continue with Setting Up ADB to connect to the drone — from here on, the bootcamp steps are identical for both models.
