VOXL Inspect Barometer
voxl-inspect-baro prints barometer data to the screen for inspection. It defaults to the px4_baro pipe; on VOXL 2 a voxl_baro pipe may also be available, as shown in the help text below. The default output shows the read latency plus the pressure (Pa) and temperature (C) averaged over each batch of samples. JSON output modes are available for scripting, and when the PX4 baro thermal calibration file /data/modalai/px4/parameters_baro_tc.cal (/data/px4/param/ on SDK 1.6 and older) is present its values are included in the JSON output.
Arguments
voxl2:/$ voxl-inspect-baro --help
Tool to print Baro data to the screen for inspection.
-d, --debug                 enable libmodal-pipe debug mode
-h, --help                  print this help message
-n, --newline               print each sample on its own line
-t, --time                  wait time in seconds between printing samples
-c, --csv					format output for csv
-T, --test                  single print test mode
-j, --json                  json output formatting
-k, --json_human            human readable json output formatting
default baro is px4
example usage on VOXL2:
/# voxl-inspect-baro voxl_baro
example usage on RB5 Flight:
/# voxl-inspect-baro px4_baro
The tool also accepts an -a/--all flag that is not listed in the help text: it prints every sample with its timestamp and inter-sample dt(ms) instead of the averaged output, and cannot be combined with -t.
Example Output
pressure in PA, temp in C
delay(ms)| Pressure |  Temp |
     2.1 |100930.86 |  32.41 |
Source
