MVX Recording, Streaming & Flight Logs
Record the pilot's view on the VRX, stream video and telemetry to a ground station or ATAK, and capture flight logs.
  1. Pilot view
  2. Record video on the VRX
    1. Recording messages
  3. Stream to a ground station or ATAK
    1. MPEG-TS over UDP
    2. RTSP
    3. Headless mode
  4. Telemetry to a ground station
  5. Flight logs
Pilot view
The VRX records and streams the pilot view: exactly what the pilot sees in the goggles, video and OSD together. It does this with or without a display attached. When the pilot view is not available, the VRX uses the received camera video without the OSD instead.
The pilot view is H.265 at 4 Mbps by default (pilot_view_mbps in /etc/modalai/voxl-vrx.conf). Its frame rate follows the display refresh, up to 60 fps.
Recordings go to a USB flash drive in the VRX. See USB flash drive requirements before you start.
  • By hand: press button 2 (Record) to start, and press it again to stop. The OSD shows REC and the elapsed time while recording.
    Status bar showing REC and the elapsed time
  • Automatically: set VRX SETTINGS > RECORDING > Video, then SAVE AND EXIT:
    • Off: record only by hand (default).
    • On: record from when the VRX starts.
    • Arm: record while the drone is armed. A recording you started by hand is left alone.
The same setting is record_video (off, on or arm) in /etc/modalai/voxl-vrx.conf.
VRX SETTINGS > RECORDING with Video and Log rows
Files are MP4, saved in a vrx_videos folder on the drive and named vrx_video.mp4, vrx_video_1.mp4, and so on.
Without a USB drive: turn on RECORD TO LOCAL in the drone menu (ADVANCED) to let the VRX record to its internal storage, in /data/video/vrx_videos/. Copy the files off over ADB:
adb pull /data/video/vrx_videos/
Recording messages
OSD messageMeaning
REC DENIED: NO USB DRIVENo USB drive is mounted and recording to internal storage is off.
REC DENIED: DISK FULLThe drive has no free space.
REC FAILED: USB ERRORThe drive could not be written, for example because it is read-only or has an unsupported format.
REC STOPPED: USB REMOVEDThe drive was pulled during a recording.
REC STOPPED: DISK FULLThe drive filled up during a recording.
REC FAILED TO STARTThe recording could not start. Try again; if it keeps failing, collect a flight log and contact ModalAI.
MPEG-TS over UDP
The VRX can send the pilot view as an MPEG-TS stream over UDP, which ATAK and most video players can open directly. In /etc/modalai/voxl-vrx.conf:
SettingDefaultMeaning
en_mpeg_ts_rebroadcastfalseSet true to send the stream.
gcs_ip10.0.0.1The device to send it to.
mpeg_ts_rebroadcast_port8901The UDP port to send it to.
telem_tx_ip10.0.0.2The VRX’s own network address to send from. The stream runs only while this address is up on the VRX.
Restart the VRX service after editing:
systemctl restart voxl-vrx
On the receiving device, open a UDP stream on port 8901. In ATAK, add a UDP video alias on that port.
RTSP
voxl-streamer runs on the VRX and serves the pilot view over RTSP out of the box at rtsp://<VRX IP>:8900/live, for example rtsp://10.0.0.2:8900/live with the USB-to-Ethernet setup.
To stream the received camera video without the OSD instead, set "input-pipe": "vrx_encoded" in /etc/modalai/voxl-streamer.conf and restart the streamer:
systemctl restart voxl-streamer
The VRX only encodes the pilot view while something uses it (a recording, the MPEG-TS stream, or an RTSP client), so leaving streaming set up costs nothing when nobody is watching.
Headless mode
To use the VRX only as a receiver for your own software, set "headless": true in /etc/modalai/voxl-vrx.conf. The VRX then publishes the received H.264/H.265 video on the vrx_encoded pipe without decoding, displaying or recording it.
The VRX passes the drone’s MAVLink telemetry to a ground station or ATAK device on its network, and passes the ground station’s MAVLink (missions, commands) back to the drone. In /etc/modalai/voxl-vrx.conf:
gcs_ip10.0.0.1The ground station’s address
mavlink_gcs_port14550The MAVLink port on the ground station
allow_mavlink_forward_while_armedfalseAlso pass the ground station’s MAVLink to the drone while it is armed
ADVANCED > MAVLINK FWD in the drone menu turns telemetry forwarding on or off.
The MVX link carries video, the OSD, telemetry and menu commands. It is not a general-purpose data link, so custom application data between the drone and the ground cannot be sent over it. For that, use an IP link such as an IP radio, LTE, or the VTX radio in WiFi mode.
Flight logs
The drone and the VRX can each record a flight log of the link: video, radio and link-quality data, events and the drone’s MAVLink telemetry. The two logs of one flight share an ID, so they can be lined up. Flight logs are what ModalAI support asks for when you report a link problem.
Turn on from the OSD:
  • VRX SETTINGS > RECORDING > Log (Off, On or Arm), then SAVE AND EXIT. This sets logging on the drone and the VRX together.
  • Or on the drone menu: ADVANCED > LOGGING > DEBUG LOG (DISABLED, ENABLED, ON ARM).
    ADVANCED > LOGGING menu
Or in the config files: debug_log (off, on or arm) in /etc/modalai/voxl-vtx.conf on the drone and /etc/modalai/voxl-vrx.conf on the VRX.
  • arm starts one log per flight, from arm to disarm. on logs from service start.
  • log_format chooses ulog, csv or both (default). ULog files open in PlotJuggler.
  • Logging stops when free space drops below log_min_free_mb (500 MB by default).
Logs are saved on each unit, one folder per flight:
UnitFolder
Drone/data/mvx/vtx/logs/flight_NNNN_<id>/
VRX/data/mvx/vrx/logs/flight_NNNN_<id>/
Copy them off over ADB, for example from the VRX:
adb pull /data/mvx/vrx/logs/
