  1. Overview
  2. Requirements
    1. Hardware
    2. Software
  3. SIM Card Installation
  4. Hardware Setup
  5. Software Setup
The VOXL system provides the ability to easily and quickly add an LTE connection. The following guide provides you the necessary details on doing so with an LTE v2 Modem.
Requirements
Hardware
In order to connect the VOXL to an LTE network using the v2 Modem, you have two choices of modem types:
Part NumberDescription
MDK-M0030-1-01VOXL Add-on board for North American LTE Carriers WP7610 module
MDK-M0030-1-04VOXL Add-on board for Europe, Middle East, Africa LTE Carriers RC7620 module
MDK-M0030-1-00VOXL Add-on as USB hub only, no modem
MDK-M0030-1-03VOXL Add-on board for North American LTE Carriers RC7611 module
v2 Modem
Each kit conveniently comes with two LTE antennas, purchase more here
Software
The following software is required and should already be pre-installed:
  • The SIM card needs to be installed in the orientation pictured below.
SIM card installation on the LTE v2 add-on, step 1
  • Slide the SIM card into the SIM card slot on the bottom of the LTE board.
SIM card installation on the LTE v2 add-on, step 2
  • Push the SIM card in until you feel the card click into place.
SIM card installation on the LTE v2 add-on, step 3
To remove the SIM card, push the card slightly further into the slot until you feel a click, the card will then be able to slide out.
Hardware Setup
  • Remove power and USB from the VOXL
  • Insert your SIM card into the modem’s SIM card slot
  • Attach antennas to the modem
  • Attach LTE modem to VOXL using VOXL’s J13 connector
  • Reconnect USB and power to VOXL
Software Setup
VOXL ships with a simple utility to assist with setting up a modem. (voxl-modem 1.x)
voxl-configure-modem allows you to quickly and easy bring up a network connection using an LTE modem.
# On VOXL
1) v2
2) microhard
3) dtc
4) doodle
5) quectel
6) em9X91
Choose 1 for v2 modem. (On the original VOXL, the menu also lists v1 first, so choose 2 for the v2 modem there.)
You will then be asked if you are attempting to connect to ModalLink:
1) yes
2) no
If you are using a SIM from a cellular network (AT&T, Verizon, T-Mobile, etc.) select 2 for no.
You will then be asked to select the correct APN for your SIM card:
Verizon - APN: vzwinternet
Google Fi - APN: h2g2
US Mobile (Dark Star/Verizon) - APN: ereseller
1) m2m.com.attz	      4) fast.t-mobile.com  7) ereseller
2) broadband	      5) vzwinternet	    8) Custom
3) phone	      6) googlefi
If you do not see your APN on the list, you can choose Custom and enter your SIM card’s APN.
You will then be asked which region your SIM card will be used in:
Select modem region:
1) Americas
2) Europe/Middle-East/Asia
Your VOXL is now finished configuring and will setup and start the required background services.
Setting APN: m2m.com.attz
reloading systemd services
DONE configuring voxl-modem
After a short time your VOXL will be connected to the LTE network. You will now be able to reboot your VOXL and have it connect to the LTE network automatically.
For information on how to get connected to your Ground Control Station over LTE, checkout our page on the LTE Modem User Guide..
