LTE Modem v2 Pro Datasheet
- Overview
- Development Kits
- Dimensions
- 3D Drawings
- 2D Drawings
- Features
- Block Diagram
- Connector Callouts
- J5 - apps_proc UART7 and I2C9
- J8 - apps_proc SPI11, UART13 I2C2 and GPIO
- J9 - apps_proc UART19 and I2C10
- J10 - apps_proc USB2 (1A limit, port2)
- J11 - apps_proc USB3 (2A limit, port3)
- J12 - apps_proc USB2 (1A limit, port4)
TODO: graphic
Development Kits
PN | Description |
MDK-M0130-00 | board only |
Dimensions
3D Drawings
TODO: 3D step
3D STEP
2D Drawings
Xmm x Xmm x Xmm
Features
Top
Block Diagram
Connector Callouts
Connector | MPN |
Board Connector | SM06B-GHS-TB(LF)(SN) |
Mating Connector | |
Pin # | Signal Name | Usage / Notes |
1 | VREG_3P3V_LOCAL | |
2 | UART_TX_3P3V | /dev/ttyHS1 |
3 | UART_RX_3P3V | /dev/ttyHS1 |
4 | I2C_SDA_3P3V | /dev/i2c-1 |
5 | I2C_SCL_3P3V | /dev/i2c-1 |
6 | GND | |
Connector | MPN |
2 | SPI_MISO_3P3V | /dev/spidev11.0 |
3 | SPI_MOSI_3P3V | /dev/spidev11.0 |
4 | SPI_SCLK_3P3V | /dev/spidev11.0 |
5 | SPI_CS_3P3V | /dev/spidev11.0 |
6 | GPIO_152 | |
7 | GPIO_88 | input only ini SPI mode |
8 | I2C_SDA_3P3V | /dev/i2c-0 |
9 | I2C_SCL_3P3V | /dev/i2c-0 |
10 | UART_TX_3P3V | /dev/ttyHS3 |
11 | UART_RX_3P3V | /dev/ttyHS3 |
12 | GND | |
Connector | MPN |
2 | UART_TX_3P3V | /dev/ttyHS2 |
3 | UART_RX_3P3V | /dev/ttyHS2 |
4 | I2C_SDA_3P3V | /dev/i2c-2 |
5 | I2C_SCL_3P3V | /dev/i2c-2 |
6 | GND | |
Connector | MPN |
Board Connector | SM04B-GHS-TB(LF)(SN) |
1 | VDC_5V_USB1_PORT2 | D4 LED |
2 | USB1_CON_D_N | |
3 | USB1_CON_D_P | |
4 | GND | |
Connector | MPN |
Board Connector | SM10B-GHS-TB(LF)(SN) |
1 | VDC_5V_USB1_PORT3 | D16 LED |
2 | USB1_HS_HUB3_CON_D_N | |
3 | USB1_HS_HUB3_CON_D_P | |
4 | GND | |
5 | USB1_HS_HUB3_SS_RX_N | |
6 | USB1_HS_HUB3_SS_RX_P | |
7 | GND | |
8 | USB1_HS_HUB3_SS_TX_N | |
9 | USB1_HS_HUB3_SS_TX_P | |
10 | GND | |
Connector | MPN |
1 | VDC_5V_USB1_PORT4 | D16 LED |
4 | GND | |
