Relocalization
One inherent shortcoming of navigating with VIO is that VIO algorithms are generally unaware of their absolution location unless they employ a mapping and relocalization function. Most of them only know their position relative to where the algorithm started.
One reliable and configurable method for relocalization is using fiducial markers. We incorporate this functionality into voxl-vision-hub specifically using Apriltags. In this demonstration video you can see the drone start up crooked so that it thinks forward is offset and yawed to the right. It’s told to fly forward and back in a straight line before landing at the 0,0,0 point. On its return to the landing pad it sees the Apriltag and immediately corrects the error, allowing it to land squarely on its landing pad.
  1. Video Walkthrough
  2. Configuration Files
  3. Frames of Reference
  4. Debugging
  5. Fixed Frame Pipe for user-provided localization
  6. Filter Configuration
  7. Correcting Setpoints with the Fixed Frame Offset
  8. Precision Landing
Video Walkthrough
Configuration Files
To use this feature, you must enable VIO and the “en_tag_fixed_frame” feature in /etc/modalai/voxl-vision-hub.conf which will be discussed later in this page.
    "en_vio": true,
    "en_tag_fixed_frame": true,
    "en_transform_mavlink_pos_setpoints_from_fixed_frame": true
When using the “en_tag_fixed_frame” feature you need to specify the position and rotation of each Apriltag relative to fixed frame in the /etc/modalai/tag_locations.conf file. See the Tag Locations config file description for how to set this up. Specifically you should be configuring apriltags with the type fixed for use with the relocalization feature.
Frames of Reference
The geometry module inside voxl-vision-hub keeps track of the following frames of reference.
px4_chart-geometry_overview
Calculation of the translation and rotation between fixed and local frame is done using the relation between the following frames. voxl-vision-hub keeps a small buffer of odometry data relating the IMU to VIO frames as the drone moves. Using the accurate camera frame timestamps, voxl-vision-hub then goes back in time and interpolates to best estimate the position and orientation of the drone when the Apriltag was detected.
px4_chart-apriltag_frames
Debugging
Before first flight, we highly suggest running voxl-vision-hub from the command line with each of the following options one at a time. This will let you inspect the behavior of the relocalization algorithm and Apriltag detection. A small typo when configuring the Apriltag positions and orientations in the config file can be disastrous.
-g, --debug_fixed_frame     print debug info regarding the calculation of fixed frame
                              relative to local frame as set by apriltags.
-l, --debug_tag_local       print location and rotation of each tag in local frame
                              note that apriltag frame of reference is not the same
                              as local frame so interpreting roll/pitch/yaw requires
                              some thought
-m, --debug_tag_cam         print location and rotation of each tag detection wrt cam
-o, --debug_odometry        print the odometry of body in local frame each time
                              a VIO packet is sent to PX4
-p, --debug_odometry_fixed  print the odometry of body in fixed frame. Note this
                              is not the data being sent to px4. This is to help
                              ensure fixed apriltags are set correctly in config file
The user may wish to implement their own method of localization instead of using the integrated Apriltag feature. For example: multi-fiducial-marker detection, or landing pad detection. In this case, the user may simply disable the Apriltag localization feature. The fixed-pose input pipe has no enable option and is always available.
In /etc/modalai/voxl-vision-hub.conf
"en_tag_fixed_frame":  false,
voxl-vision-hub opens a sink pipe named vvhub_fixed_pose_input at /run/mpa/vvhub_fixed_pose_input to which the user can write data in the form of a pose_4dof_t struct relating the location of the body to fixed frame. The pipe name is defined in /usr/include/voxl_vision_hub.h and the struct is defined by libmodal-pipe:
#define FIXED_POSE_INPUT_NAME		"vvhub_fixed_pose_input"
#define FIXED_POSE_INPUT_LOCATION	(MODAL_PIPE_DEFAULT_BASE_DIR FIXED_POSE_INPUT_NAME)
typedef struct pose_4dof_t{
    uint32_t magic_number; // unique 32-bit number signaling the start of a packet
    int64_t timestamp_ns;  // timestamp in apps-proc clock-monotonic
    double p[3];           // meters
    double yaw;            // radians, between +- PI
} pose_4dof_t;
An example of how to write to this pipe can be found here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-vision-hub/-/blob/master/examples/fixed_frame_pipe_example.c
Passing data in through the fixed_frame_pipe uses the same basic method as Apriltag detection and the low pass filter described below is also used. Accurate timestamping is critical when passing data in this way since the geometry module will look back in time and use interpolation to find the VIO odometry data corresponding to the provided timestamp.
As with all sensors, there is inherent noise and uncertainty with Apriltag detections. For this reason we incorporate a moving average filter to smooth out the estimate of the rotation and translation between local and fixed frame. This filter is configured such that if only one detection is made, the filter will output exactly that value to prevent the rise time that would be incurred if the filter had to wait to be completely filled before converging.
The filter length is user-configurable. It can be increased if the use-case involves the drone hovering still over a target in order to better estimate its position. If the user wishes to ensure the drone very quickly localizes given only a few camera frames looking at a tag then the filter length can be reduced.
It is possible to set the filter length to 1 which will result in the local-to-fixed frame relation being completely determined by the most recent tag detection.
"fixed_frame_filter_len": 5
So far, we have only discussed how the offset between local and fixed frame is computed. This information is never actually sent to PX4. PX4 always receives odometry data as the position and rotation of the body with respect to local frame. If PX4 was provided with the Body with respect to Fixed frame then the sudden jump that occurs upon relocalization would cause PX4’s EKF2 to misbehave and likely fall out of position-hold mode.
Instead, the user can provide setpoints in fixed frame and voxl-vision-hub will automatically translate those setpoints into local frame so PX4 will fly where you want it to go relative to apriltags.
"en_transform_mavlink_pos_setpoints_from_fixed_frame": true,
When enabled, any SET_POSITION_TARGET_LOCAL_NED mavlink messages received through UDP will have its position, velocity, acceleration, and yaw values updated with the fixed frame offset before being sent to PX4 over UART. This is very useful for MAVROS and MAVSDK processes running locally or remotely.
This feature is completely optional if you wish to have more control yourself.
Precision Landing
A common question is whether VOXL supports precision landing on an AprilTag. The current status:
  • AprilTag relocalization corrects VIO drift in the local frame as described on this page. Landing at a known location above a fixed tag benefits from this correction, since the position estimate is re-aligned to the tag each time it is observed.
  • PX4’s dedicated precision-landing mode is not integrated: no VOXL SDK service publishes the MAVLink LANDING_TARGET message that mode requires.
  • voxl-vision-hub’s tag-follow offboard mode holds position relative to a tag; it does not descend or land.
Tag-relative landing behavior beyond this must be implemented by the user, for example through offboard mode.
