VOXL SDK Release Notes
A VOXL SDK release bundles three things: the voxl-suite meta-package (all VOXL SDK software packages installed on VOXL), a matching system image, and an installer. The release takes its version number from the included voxl-suite meta-package.
Each release is cut from a tagged voxl-suite meta-package that pins the exact version of every package it contains — see the release tags for precisely what is in each release. Releases go through alpha and beta cuts with internal flight testing before they are published.
Because the system image and voxl-suite are tested together as a whole, we highly recommend installing SDK releases as-is with a full system flash. Experienced developers can configure VOXL to pull individual packages from development repositories by following the voxl-configure-pkg-manager page, but we do not support software issues that arise from doing so.
Which SDK Should I Flash?
The build artifacts listed in the Release Index show which platforms a release was built for — not which vehicles it has been flight tested on. For ModalAI drones, flash the most recent release that has been flight tested on your vehicle (see each release’s test matrix for details):
Part numberDescriptionSDK to flash
D0004RB5 Flight (EOL)SDK 1.5.0 — last release with RB5 Flight support
D0008-4-V5Seeker Vision 5” (VOXL 2)SDK 1.6.4
D0008-4-V6Seeker Vision 5” (VOXL 2)SDK 1.6.4
D0008-9Seeker Vision 5” (QCS6490)SDK 1.7.0 — currently in beta; not yet available for download
D0012Starling 2 MaxSDK 1.6.4
D0013Stinger VisionSDK 1.6.6
D0014Starling 2SDK 1.6.4
D0020-4-V5Seeker Vision 10” (VOXL 2)SDK 1.6.4
D0020-4-V6Seeker Vision 10” (VOXL 2)SDK 1.6.5
D0020-9Seeker Vision 10” (QCS6490)SDK 1.6.8 — not yet available on downloads.modalai.com
M0006VOXL (apq8096)SDK 1.3.5 — last release with apq8096 support
M0019VOXL Flight (apq8096)SDK 1.3.5 — last release with apq8096 support
M0054VOXL 2 development kitsSDK 1.6.6
M0104VOXL 2 Mini development kitsSDK 1.6.6
R0001VRX Ground UnitSDK 1.6.6
Release Index
SDK seriesLatest releaseReleasedBuild artifacts
SDK 1.7in development — current cut 1.7.0-beta3-VOXL 2, VOXL 2 Mini, VRX, QCS6490
SDK 1.61.6.8 (QCS6490 only); 1.6.6 for all other platformsJuly 2026VOXL 2, VOXL 2 Mini, VRX, QCS6490
SDK 1.51.5.0June 25, 2025VOXL 2, VOXL 2 Mini, RB5
SDK 1.41.4.5May 16, 2025VOXL 2, VOXL 2 Mini, RB5
SDK 1.31.3.5October 3, 2024VOXL 2, VOXL 2 Mini, RB5, VOXL, VOXL Flight (apq8096)
SDK 1.21.2.0April 15, 2024VOXL 2, VOXL 2 Mini, RB5, VOXL, VOXL Flight (apq8096)
SDK 1.11.1.3February 26, 2024VOXL 2, VOXL 2 Mini, RB5, VOXL, VOXL Flight (apq8096)
SDK 1.01.0.x2023VOXL 2, VOXL 2 Mini, RB5, VOXL, VOXL Flight (apq8096)
SDK 0.9 and olderlegacy2022-2023VOXL, VOXL Flight (apq8096)
To move to a new SDK release — including patch releases — download the full release from downloads.modalai.com and install it with a complete system flash. Upgrading individual packages in place with apt is not recommended: each SDK release is tested as a whole, and mixed package versions are not a supported configuration.
