DeprecatedThis documents a deprecated product or feature. It may be outdated and is no longer recommended.
VOXL Emulator Docker Image
  1. Install the voxl-emulator Docker Image
    1. Installation Process
    2. Using the Installed Docker Image
voxl-emulator is deprecated. Use voxl-cross for building VOXL applications instead.
voxl-emulator enables one to develop CPU-based applications for VOXL and VOXL Flight, then test CPU-only in an emulated environment.
The VOXL 1 emulator image (voxl-emulator_v1.7.tgz) is no longer distributed on downloads.modalai.com.
qrb5165-emulator enables one to develop CPU-based applications for VOXL 2, then test CPU-only in an emulated environment. It is an ARM 64 emulator with the VOXL 2 sysroot mounted. It has very limited application to end developers. It is for low-level service development for cross-compiling applications not yet supported by cross-compiling in voxl-cross
The installation process is the same for both VOXL and VOXL 2.
  1. Download the archived docker image from the Miscellaneous folder on downloads.modalai.com (login required).
    • For VOXL 2: 865-rootfs_m0054_qrb5165-emulator-v1.5.tar
    • For VOXL 1: no longer distributed
  2. Install Dependencies:
# install packages
$ sudo apt-get install qemu binfmt-support qemu-user-static
# Execute the registering scripts, see $https://www.stereolabs.com/docs/integrations/docker/create-images-for-nvidia-jetson
$ docker run --rm --privileged multiarch/qemu-user-static --reset -p yes
  1. Load and Tag the Docker Image:
$ docker load -i qrb5165-emulator_V1.5.tgz
$ docker tag voxl-cross:V2.5 voxl-cross:latest
To enter the docker image’s build environment, run the command:
$ voxl-docker -i qrb5165-emulator_V1.5.tgz
