LegacyThis documents a legacy product. Newer alternatives may be available.
Starling Hardware Quickstart
This section provides the minimum steps needed to get a device powered up and ready to connect to a console.
More details can be found on the Starling Hardware Overview and Datasheet pages, but are not necessary to complete the bootcamp.
Unmanned Aerial Systems (drones) are sophisticated, and can be dangerous. Please use caution when using this or any other drone. Do not fly in close proximity to people and wear proper eye protection. Obey local laws and regulations.
1. Ensure propellor clips are installed:
MRB-D0005-prop-clips
2. Connect USB-C Cable
  • Connect USB-C cable to VOXL 2
  • Connect other side of USB-C cable (recommended USB type A) to host computer for later use
MRB-D0005-4-V2-C6-M22-callouts-rear
3. Power ON
  • Connect the battery or wall power supply to the XT30 connector (labeled Power above)
    • NOTE: do not arm the vehicle while using wall power
The development drone will bootup and play a jingle via the ESC.
How to Power Off
Next Step: Set up ADB
