PCB Decoder Ring
Our PCB catalog with part numbers, diagrams, links, and production status
| NUMBER | DESCRIPTION | WEIGHT | 3D Model | BUY | DATASHEET |
| M0006 | VOXL | 16.51g | 3D STEP | Buy | Datasheet |
| M0007 | EOL - Flight Core REV A | ||||
| M0008 | Flex VOXL Interposer DFT36/24 | 0.8g | Buy | ||
| M0009 | EOL - APM V2 | ||||
| M0010 | Stereo Flex 36/24/24 | 0.87g | EOL | Datasheet | |
| M0011 | NOT IN PRODUCTION | ||||
| M0012 | EOL - Microhard Modem using LAN7850 | ||||
| M0013 | NOT IN PRODUCTION | ||||
| M0014 | VIO OV7251 Tracking Image Sensor | 0.51g | 3D STEP | EOL — see MSU-M0166 | Datasheet |
| M0015 | Stereo Image Sensor OV7251 | 0.41g | Datasheet | ||
| M0016 | NOT IN PRODUCTION | ||||
| M0017 | Serial / USB / Fastboot Debug Board | 4.83g | 3D STEP | EOL | |
| M0018 | Flight Core | 6.13g | 3D STEP | EOL | Datasheet |
| M0019 | VOXL Flight | 24.5g | 3D STEP | EOL | Datasheet |
| M0022 | PWM Breakout Board (3row header) | 4.17g | 3D STEP | Buy | |
| M0024 | IMX214 High-res Image Sensor (10x10x16mm) | 3.79g | EOL | Datasheet | |
| M0025 | IMX214 High-resolution (8.5x8.5x5mm) | 0.83g | EOL — see MSU-M0161 | Datasheet | |
| M0026 | IMX377 m12 Wide Angle | 8.57g | EOL | Datasheet | |
| M0027 | EOL - ESC 4in1 Gen 2.5 | ||||
| M0030 | LTE Add-on v2 (Sierra Wireless) | 8.24g / 14g (with modem + lid) | 3D STEP | EOL | Datasheet |
| M0034 | VOXL-TRAY for VOXL Flight Deck | Datasheet | |||
| M0036 | Image Sensor Extension 14.5cm | 0.62g | 3D STEP | Buy | Datasheet |
| M0037 | Interposer for Auvidea B102 to VOXL | ||||
| M0038 | Mezzanine Gen 1 - Stereo, IMU, Tracking connector | 5.65g | |||
| M0039 | Wide Stereo Flex | 3D STEP | |||
| M0040 | TOF cable | 0.59g | |||
| M0041-1 | APM LITE (5V, 12AWG XT60 Cables) | 34.72g | 3D STEP | Datasheet | |
| M0041-5 | APM LITE (5V, No Cables Soldered) | 4.81g | 3D STEP | Datasheet | |
| M0042 | FRAMOS IMX296 Interposer | 2.27g | 3D STEP | ||
| M0045 | UART Splitter - Horizontal | ||||
| M0046 | ICM42688 Breakout Board | ||||
| M0047 | NOT IN PRODUCTION | ||||
| M0048 | Microhard Modem LAN7500 | 14.81g | 3D STEP | Datasheet | |
| M0049 | ESC 4in1 rev B | 10.28g / 9.5 no wires | 3D STEP | Buy | Datasheet |
| M0052 | RB5 Flight SOM Carrier PCB | 24.87g | 3D STEP | Datasheet | |
| M0054 | VOXL 2 | 16g | 3D STEP | Datasheet | |
| M0059 | Microhard pMDDL900, pMDDL1621/4 Add-on | 3D STEP | Buy | Datasheet | |
| M0061 | FRAMOS Flexible FSM Interposer (“FFF”) | 2.29g | 3D STEP | Datasheet | |
| M0062 | VOXL2 breakout w/ debug (upgrade for M0017) | 15.46g | 3D STEP | ||
| M0064 | Voxl-2 DF40C to Voxl AXT Image Sensor Adapter | ||||
| M0065 | VOXL 2 IO - UART to PWM/S.Bus board | 4g | |||
| M0067 | VOXL2 5G PCIe Modem Carrier Board with Debug | 13.22g | 3D STEP | ||
| M0068 | VOXL - M0006 Refresh for EOL and maintainability | ||||
| M0069 | VOXL - M0019 Refresh for EOL and maintainability | ||||
| M0070 | Mini-STM TOF board (VL53L1CX) | 0.13g | |||
| M0072 | MD102A Replacement | 0.38g | EOL — see MSU-M0166 | ||
| M0073 | Color stereo sensor OV9782 | 0.53g | |||
| M0074 | Image Sensor Extension Flex - 60mm | 0.35g | 3D STEP | Buy | Datasheet |
| M0076 | VOXL-2 DF40C to VOXL AXT Image Sensor Adapter + Power Fix version 2 | 0.59g | 3D STEP | Datasheet | |
| M0078 | VOXL Serial / USB / Fastboot Debug Board Ver 2 | 3.14g | 3D STEP | EOL | Datasheet |
| M0084 | VOXL-2 DF40C to VOXL Y-AXT Flex | 1.52g | Buy | Datasheet | |
| M0085 | Respin of M0038-1 mezzanine for Flir, RGB LED | 5.91g | |||
| M0086 | Chirp Adapter for RB5 Flight | 3g | |||
| M0087 | Flight Core v2 / H7 | 6g | 3D STEP | ||
| M0088 | Color stereo sensor OV9782 | 0.68g | |||
| M0089 | IR LED Board + Driver board | ||||
| M0090 | M.2 USB2.0/3.0 adapter board for VOXL/VOXL2 5G modems | 12.8g | 3D STEP | Buy | Datsheet |
| M0091 | OV9281 VIO Tracking Modules | 2.13g | |||
| M0092 | NOT IN PRODUCTION | ||||
| M0093 | NOT IN PRODUCTION | ||||
| M0094 | RB5 Flight Spektrum Binding Module | ||||
| M0104 | VOXL 2 Mini | 11.0g | 3D STEP | Buy | |
| M0107 | IMX412 RGB Rolling Shutter with IR Filter | 7.5g | 3D STEP | EOL — see MSU-M0161 | Datasheet |
| M0113 | Color stereo sensor (OV9782) | 3D STEP | |||
| M0117 | ESC 4in1 rev B / Alternate to M0049 | 10.28g / 9.5 no wires | 3D STEP | Buy | Datasheet |
| M0125 | USB3 UART Expansion Board | 3D STEP | Buy | Datasheet | |
| M0129 | ESC Micro 4-in-1 | 3D STEP | Buy | Datasheet | |
| M0130-1 | VOXL 2 LTE Add-on | 11.3g | 3D STEP | Buy | Datasheet |
| M0134-1 | ESC 4in1 rev B / Alternate to M0049, M0117 | 10.28g / 9.5 no wires | 3D STEP | Buy | Datasheet |
| M0135-1 | VOXL 2 and VOXL 2 Mini Dual Image Sensor Adapter | 3D STEP | Buy | Datasheet | |
| M0136-1 | TBD WiFi VOXL/VOXL2 + EXT ANT | 3D STEP | Buy | Datasheet | |
| M0136-2 | TBD WiFi STANDALONE + EXT ANT | 3D STEP | Buy | Datasheet | |
| M0136-3 | TBD VOXL/VOXL2 + CHIP_ANT_VER | 3D STEP | Buy | Datasheet | |
| M0136-4 | TBD STANDALONE + CHIP_ANT_VER | 3D STEP | Buy | Datasheet | |
| M0138-1 | ESC FPV 4-in-1 | 17.9g | 3D STEP | Buy | Datasheet |
| M0141-1 | VOXL 2 WiFi Add-on and I/O Breakout | 3D STEP | Buy | ||
| M0143-1 | IMX678 RGB Module | 7.97g | 3D STEP | ||
| M0144-1 | VOXL 2 B2B Breakout | 3D STEP | |||
| M0149-1 | VOXL 2 AR0144 Fisheye Tracking Module | 3D STEP | Buy | Datasheet | |
| M0151-1 | USB3 UART Expansion Board | 3D STEP | Buy | Datasheet | |
| M0154 | VOXL 2 | 16g | 3D STEP | Buy | Datasheet |
| M0155-1 | VOXL 2 Single Coax Adapter | 3D STEP | Buy | Datasheet | |
| IRS2975C | PMD IRS2975C TOF Module | 3D STEP | |||
| M0162-1 | VOXL 2 Coax Adapter for Boson+ | 3D STEP | |||
| M0161-1 | IMX412 Module with m12 lens and micro-coax interface | 7.75g | Buy | Datasheet | |
| M0166-1 | AR0144 Module with m7 lens and micro-coax interface | 1g | 3D STEP | Buy | Datasheet |
| M0169-1 | PMD IRS2975C TOF Legacy Adapter Board (External Power) | 3D STEP | |||
| M0170-1 | 40-Pin Molex Straight Flex | 3D STEP | Buy | Datasheet | |
| M0171-1 | PMD IRS2975C TOF High Power Adapter Board | 3D STEP | |||
| M0173-1 | Starling 2 Camera Front-end | 3D STEP | |||
| M0177-1 | Starling 2 TOF Flex Cable | 3D STEP | Datasheet | ||
| M0178-1 | PMD IRS2975C TOF High Power Adapter Board with mounting hole | 3D STEP | |||
| M0181-1 | VOXL 2 and VOXL 2 Mini micro-coax Hi-res and Boson adapter (Hadron) | 3D STEP | Buy | Datasheet | |
| M0185-2 | VTX PCB | 3D STEP | |||
| M0186-1 | IMX664 FPV Module with m12 lens and micro-coax interface | 3D STEP | Buy | Datasheet | |
| M0188-2 | VOXL 2 Mini / Stinger Image Sensor Break-out | 5.54g | |||
| M0194-2 | VOXL 2 Mini / Stinger Image Sensor Break-out Hi-Res and Boson | 3D STEP | |||
| M0201-1 | Boson+ MIPI adapter for VOXL 2 and VOXL 2 Mini (replaces M0153) | 3D STEP | Buy | Datasheet | |
| M0202-1 | Hadron640R MIPI micro-coax adapter for VOXL 2 and VOXL 2 Mini | 3D STEP | Datasheet | ||
| M0204-1 | VOXL 2 Mini Refresh | 3D STEP | Datasheet |
