M0254 Feature Matrix
  1. Summary
    1. QCS6490 platform
  2. Specifications
VOXL 3 (M0254) is a drop-in sustaining replacement for VOXL 2 (M0154), built on the Qualcomm QCS6490 to carry the VOXL platform forward and introduces many new system improvements. It preserves the VOXL 2 board outline, mounting pattern (31 x 62.5mm), and core connector positions and pinouts, so existing carriers, harnesses, and airframe integrations transfer with minimal-to-no redesign.
Customer interoperability is the top priority. J3 (Legacy B2B), J5 (High-Speed B2B), the J6–J8 CSI ports, J9 (USB-C), J10, J18 (ESC), and J19 (FC) all retain their VOXL 2 positions. Where the QCS6490 exposes fewer native QUP ports, an on-board SiLabs CP2105 USB-UART bridge restores the dropped serial interfaces preserving the full VOXL 2 customer interface map without a carrier redesign.
Direct battery power — no power module required. VOXL 3 accepts 2S–6S VBAT directly (ModalAI Yellow VBAT Format, JST SM02B-SFHL, 4A max) with on-board input voltage sensing, eliminating the external power module (M0041) or ESC-derived 5V rail. This removes a board, a harness, and a conversion stage from every build representing a significant system integration and airframe-mass win.
Side Sensor Port (J10). The J10 SPI port now supports a selectable sensor source: use the on-board IMU, or route an external flight-control sensor module (IMU/Baro) directly into the DSP sensor path. This lets integrators bring qualified external sensors to the flight stack without contention — the on-board IMU is deselected when an external module is active.
Improved cable routing. Input power (J4) and the fan connector (J2) are relocated adjacent to the ESC connector, cleaning up power and cooling harness runs. Corners are radiused to 2mm — reducing edge stress and easing enclosure and isolator fitment.
Upstream mainline Linux. Unlike the QRB5165’s closed BSP, the QCS6490 runs an upstream mainline kernel — a longer-supported, more maintainable software foundation with an open GPU stack, directly extending platform longevity. Platform-specific behavior and hardware deltas are handled in the VOXL SDK layer, leaving the base kernel unmodified.
VOXL SDK. The VOXL SDK is already fully featured on VOXL 3, running the same applications as VOXL 2, with planned support for the full range of existing customer use cases.
QCS6490 platform
The Qualcomm QCS6490 is a 6nm octa-core SoC (Kryo 670: 1× 2.7GHz + 3× 2.4GHz + 4× 1.9GHz), with Adreno 643 graphics @ 812MHz, a Hexagon AI engine (12 TOPS), dual-channel LPDDR5/5X, and Wi-Fi 6E / Bluetooth 5.2 support.
Specifications
FeatureVOXL 2VOXL 3
COMPUTE & MEMORY
CPUQRB5165
8 cores up to 3.091GHz
8GB LPDDR5
128GB UFS Flash
QCS6490
8 cores up to 2.7GHz
8GB LPDDR5/5X
128GB UFS Flash
GPUAdreno 650 GPU @ 587MHzAdreno 643 GPU @ 812MHz
NPU15 TOPS12 TOPS
SOFTWARE & DEVELOPER
OSUbuntu 18.04 - Linux Kernel v4.19Ubuntu 24.04 - Mainline Kernel
VOXL SDK: GPS-denied navigation, SLAM, obstacle avoidance, object recognitionYesYes
ROSROS 1 & 2ROS 1 & 2
QGroundControlYesYes
ATAKYesYes
POWER
Input PowerJ4 5V @ 6A via Power Module or ESCJ4 Direct 2S-6S VBAT, 4A max
SBC/Carrier Board Use Case5V Power input bypass via J5 (not J3)5V Power input bypass via J5 & J3 (shorted, no more eFuse restrictions)
VBAT / Input MonitoringVia external power module / ESCDirect on-board voltage sense (no external module)
Power Consumption0.1 - 7W0.1 - 6W
I/O & CONNECTORS
Connectors — fixed positionJ3 Legacy B2B · J5 HS B2B · J6 CSI Grp0 (0:1) · J7 CSI Grp1 (2:3) · J8 CSI Grp2 (4:5) · J9 USB-C · J10 SPI (apps proc) · J18 ESC · J19 FC (GMRI)J3 Legacy B2B · J5 HS B2B · J6 CSI Grp0 (0:1) · J7 CSI Grp1 (2:3) · J8 CSI4 (single, lower only) · J9 USB-C · J10 Side Sensor Port · J18 ESC · J19 FC (GMRV)
Connectors — relocatedJ2 Fan (5V)
J4 Power (Molex MiniSPOX 0022057045)
J2 Fan (5V)
J4 Power (JST SM02B-SFHLS)
both relocated near ESC for easier cable routing
USB-CComms/debug + full OTG; power required via J4Comms/debug + full OTG; power required via J4
USB Host (via J5 HS B2B)USB 3.0 SS (5 Gbps)USB 2.0 HS (480 Mbps)
Internal USB HubNoneUSB 2.0 hub (fans out host port to J3 B2B + CP2105 bridge)
QUP / Serial I/O20 native QUP (SPI/I2C/I3C/UART)16 native QUP + 2 UART via SiLabs CP2105 (USB bridge) = 18 total; preserves VOXL 2 customer interface map
VBUSHost switch SoC GPIO-controlled (GPIO_157)
2A output on J3 Legacy B2B
PCIe Expansion (via J5 HS B2B)PCIe2 Gen3, dual-lanePCIe1 Gen3, dual-lane
J18 (ESC) / J19 (GNSS/Mag/RC)Position & pinout baseline
J19 “GMRI” — DSP I2C present but unused
Position & pinout preserved
J19 “GMRV” — DSP I2C repurposed to Apps I2C VTX port for external sensors
J10 Sensor Port (SPI)SPI pinoutSPI pinout preserved; selectable sensor source — use on-board IMU, or route an external flight-control sensor module (IMU/Baro) into the DSP sensor path.
Selecting external sensor deselects the on-board IMU.
eDL / FastbootSwitch + buttonSwitch + button
LED BlackoutNoYes — software-controlled, all LEDs
IMAGE SENSORS & VISION
MIPI CSI PortsJ6, J7, J8, upper & lower (6 total)
2.5Gbps D-PHY
J6, J7 identical (upper & lower)
J8 lower only (5 total)
2.5Gbps D-PHY
Video Encoding8K30 h.264/h.265 64MP still images4K30 h.264/h.265
Computer Vision SensorsQTY. 2 Stereo Pair
QTY. 1 Tracking
QTY. 2 Stereo Pair
QTY. 1 Tracking
PMD TOFYesYes
FLIR BosonUSB, MIPIUSB, MIPI
FLIR LeptonUSB, SPIUSB, SPI
SENSORS & FLIGHT CONTROL
Flight Controller EmbeddedYes (PX4 or Ardupilot on Sensors DSP)Yes (PX4 or Ardupilot on Sensors DSP)
Integrated SensorsQTY. 2 ICM-42688P IMU
QTY. 1 ICP-10100
QTY. 2 BMI270 IMU
QTY. 1 DPS368
MECHANICAL
Dimensions / Mounting70 x 36mm, square corners
MTG 31 x 62.5mm
70 x 36mm, 2mm radiused corners
MTG 31 x 62.5mm (identical)
Weight16g16g
CONNECTIVITY
Built in WiFiNoNo
Add-on ConnectivityWiFi, 5G, 4G/LTE, MicrohardWiFi, 5G, 4G/LTE, Microhard
COMPLIANCE
NDAA ’20 Section 848 CompliantYes, Assembled in USAYes, Assembled in USA
Blue UASYesPlanned
