LTE Modem v2 Pro Datasheet
  1. Development Kits
  2. Dimensions
    1. 2D Drawings
  3. Features
  4. Block Diagram
  5. Connector Callouts
    1. J5 - apps_proc UART7 and I2C9
    2. J8 - apps_proc SPI11, UART13 I2C2 and GPIO
    3. J9 - apps_proc UART19 and I2C10
    4. J10 - apps_proc USB2 (1A limit, port2)
    5. J11 - apps_proc USB3 (2A limit, port3)
    6. J12 - apps_proc USB2 (1A limit, port4)
Development Kits
PNDescription
MDK-M0130-00board only
Dimensions
2D Drawings
Xmm x Xmm x Xmm
Features
FeatureDetails
WeightX g
Top
Block Diagram
Connector Callouts
Hover a highlighted connector to identify it — click to jump to its pinout.
M0130 LTE V2 Pro connector callouts, top and bottom views
ConnectorMPN
Board ConnectorSM06B-GHS-TB(LF)(SN)
Mating Connector
Pin #Signal NameUsage / Notes
1VREG_3P3V_LOCAL
2UART_TX_3P3V/dev/ttyHS1
3UART_RX_3P3V/dev/ttyHS1
4I2C_SDA_3P3V/dev/i2c-1
5I2C_SCL_3P3V/dev/i2c-1
6GND
ConnectorMPN
Mating Connector
1VREG_3P3V_LOCAL
2SPI_MISO_3P3V/dev/spidev11.0
3SPI_MOSI_3P3V/dev/spidev11.0
4SPI_SCLK_3P3V/dev/spidev11.0
5SPI_CS_3P3V/dev/spidev11.0
6GPIO_152
7GPIO_88input only ini SPI mode
8I2C_SDA_3P3V/dev/i2c-0
9I2C_SCL_3P3V/dev/i2c-0
10UART_TX_3P3V/dev/ttyHS3
11UART_RX_3P3V/dev/ttyHS3
12GND
ConnectorMPN
Mating Connector
1VREG_3P3V_LOCAL
2UART_TX_3P3V/dev/ttyHS2
3UART_RX_3P3V/dev/ttyHS2
4I2C_SDA_3P3V/dev/i2c-2
5I2C_SCL_3P3V/dev/i2c-2
6GND
ConnectorMPN
Board ConnectorSM04B-GHS-TB(LF)(SN)
Mating Connector
1VDC_5V_USB1_PORT2D4 LED
2USB1_CON_D_N
3USB1_CON_D_P
4GND
ConnectorMPN
Board ConnectorSM10B-GHS-TB(LF)(SN)
Mating Connector
1VDC_5V_USB1_PORT3D16 LED
2USB1_HS_HUB3_CON_D_N
3USB1_HS_HUB3_CON_D_P
4GND
5USB1_HS_HUB3_SS_RX_N
6USB1_HS_HUB3_SS_RX_P
7GND
8USB1_HS_HUB3_SS_TX_N
9USB1_HS_HUB3_SS_TX_P
10GND
ConnectorMPN
Mating Connector
1VDC_5V_USB1_PORT4D16 LED
2USB1_CON_D_N
3USB1_CON_D_P
4GND
