VOXL Flight IMUs
VOXL Flight IMU Hardare Configuration
VOXL Flight has two IMUs connected to the snapdragon and three connected to the PX4 flight controller MCU.
In the VOXL-SDK, both snadragon IMUs are enabled and provide data through MPA, however IMU0 should be preferentially used since it is a newer and better performing part. Note this differs from the VOXL board which contains two of the same IMU. Configuring MPA services with voxl-configure-mpa will select the correct IMU based on board part number.
VOXL Flight M0019
| Configuration | Part Number | Interface |
| VOXL IMU0 (recommended) | ICM-42688-P | VOXL SPI10 |
| VOXL IMU1 | ICM-20948 | VOXL SPI1 |
| Flight Core IMU1 | ICM-20602 | PX4 SPI1 |
| Flight Core IMU2 | ICM-42688 | PX4 SPI2 |
| Flight Core IMU3 (likely DNI’d) | BMI-088 | PX4 SPI6 |
VOXL Flight M0069
| VOXL IMU0 | ICM-42688-P | VOXL SPI10 |
| VOXL IMU1 | ICM-42688-P | VOXL SPI1 |
VOXL Flight IMUs Top
VOXL Flight IMUs Bottom
Next: VOXL Flight Configuration
