Provides HDMI input into VOXL or VOXL Flight.
** Note: ModalAi’s HDMI accessory has been discontinued and is no longer available **
Board Connections
SYSTEM
TOP
BOTTOM
Specifications
System Specification
- HDMI input connector for camera, MIPI connector output for VOXL/VOXL Flight
- Provides 1080p videa to VOXL/VOXL Flight at variable frame rates up to 60FPS in a named pipe
- Requires ModalAI System Image 2.6 or newer
- For B102 specifications, refer to this link
Physical Specification
System:
| Specification | Value |
| Size | TODO |
| Weight | TODO |
Auvidea PCB:
| Size | 27 x 42 mm |
| Weight | TODO |
| Mounting | 3x M2.5 mounting holes (do not use M3 screws) |
| Mount Hole Spacing | 22mm (h) x 21mm (v) |
