Qualcomm Flight RB5 Pre-Flight Setup
Update 2022-07-20: the Qualcomm Flight RB5 vehicle is now supported by the VOXL SDK! Please see here from more information
VOXL SDK First Flight Guide can be found here
Using QGroundControl for QGC
We will be using QGroundControl as a means to perform the pre-flight setups and checks as needed.
Sensor Calibration
Qualcomm Flight RB5 flight sensors are delivered pre-calibrated from the factory. PX4 will warn you if your compass needs to be re-calibrated depending on your location and environmental conditions. If so, or if you’d like re-calibrate all sensors, follow the px4 sensor calibration precedure.
RC Radio Setup
Bind Receiver to Transmitter
The RB5 has a Spektrum receiver that must be paired (or “bound”) with a transmitter. Follow these instructions to pair your Spektrum transmitter to RB5.
Version 1.0
Early RB5 shipments came with an additional piece of hardware with instructions to enable the receiver to be put in binding mode until a software solution was available.
If your RB5 has a 5V outlet on the side or if it came with a binding plug (pictured below), see the RB5 quickstart Here for binding instructions.
Version 1.1
For later RB5 Shipments, follow these instructions:
First, make sure your RB5 is powered on.
Next, connect via ADB by plugging the USB-C into RB5’s flight deck. Then, open up the terminal and type:
adb shell
To use the binding utility, use
rb5-bind
Follow the on-screen prompts. Select your bind type.
Tool used for binding Spektrum receiver. In order to use, select ONLY 1 bind type.
-d, --debug enable debug messages
-h, --help print this help messag
-t, --DSM2_22 3 pulses (DSM2 1024/22ms)
-f, --DSM2_11 5 pulses (DSM2 2048/11ms)
-s, --DSMX_22 7 pulses (DSMX 22ms)
Once you select your type, you will see the message:
An orange light should now be flashing on your receiver.
If so, your receiver is successfully in binding mode
Check that the receiver is in binding mode. The light should flash.
Once in binding mode, pair your transmitter to the receiver. The exact instructions for pairing depend on your transmitter. Check with your transmitter’s manufacturer for up to date information.
Once the transmitter is paired, make sure the receiver light is solid orange.
Make sure to power cycle your RB5 before continuing
Calibrate Radio
Once bound, power cycle the vehicle and restart QGroundControl, otherwise the radio channels will fail to show up. Now follow the on-screen instructions to calibrate the range and trims of your radio.
Confirm RC Settings
Every user will want to use different flight modes and different switch assignments, but for getting started with Qualcomm Flight RB5 we suggest starting with something similar to this configuration and working from there.
- “Flap Gyro” switch left of Spektrum Logo
- Channel 6
- Up position: Manual Flight Mode
- Middle Position: Position Flight Mode
- Down Position: Offboard Flight mode
- Channel 6
- “Aux2 Gov” switch right of Spektrum Logo
- Channel 7
- Up position: Motor Kill Switch Engaged
- Down Position: Motor Kill Switch Disengaged (required to fly)
- Channel 7
Since we have a manual kill switch on the radio there is no need for the “safety switch” on the Pixhawk GPS module as so it is disabled in our params file in favor of the kill switch.
If you have a Spektrum DX6e or DX8 radio with a clean acro-mode model you can accomplish the above channel mapping by loading the following config file
https://gitlab.com/voxl-public/px4-parameters/-/blob/master/params/spektrum_dx8_config.params
Still confirm the mapping in QGroundControl before flight!
