VOXL 2 Mini ESC Configurations
Supported ESC configurations and wiring for VOXL 2 Mini.
- Summary
- ESC Options for Built-in Flight Controller
- VOXL ESC - 4-in-1
- VOXL Mini ESC - 4-in-1
- PWM ESC Option
We are working to expand the capabilities of VOXL 2 every day. The built-in PX4 flight controller enables industry leading SWAP for an autonomous flight controller, but not every interface and flight controller are supported yet. This page provides an overview of available connectivity. If this connectivity is insufficient for your application, VOXL 2 is a world-class companion computer for autonomous navigation and AI when paired with an external flight controller.
| Protocol | Driver | Instructions | Max Number of Channels | Example Hardware |
| UART | voxl_esc | Below | 4 | VOXL 4-in-1 ESC |
| UART | voxl_esc | Below | 4 | VOXL Mini 4-in-1 ESC |
| UART | voxl_esc | Below | 4 | VOXL FPV 4-in-1 ESC |
| PWM | voxl2_io | VOXL 2 IO | 8 | VOXL 2 IO |
| DSHOT | voxl2_io in development | Not yet supported | 8 |
The modal_io driver was renamed to voxl_esc in SDK 1.1.1+, more information can be found in the VOXL ESCs section.
VOXL ESC - 4-in-1
Hardware Setup
For bi-direction UART communications, connect VOXL 2’s J19 connector to the VOXL ESC’s (M0049 or M0117) J2 using MCBL-00081 or building your own following this.
J2 pin 1 is the end nearest the J3 connector and is marked with a dot on the board silkscreen — count pins from there. Pin 1 is a 3.3V reference output (VREF_OUT), not a no-connect; leave it unwired.
M0049/M0117 J2:
M0104 J19:
- Connector on board : SM12B-GHS-TB(LF)(SN)
- Mating connector : GHR-12V-S
VBAT Power and Motors
Use standard installation processes following the datasheet pinouts.
Software Setup
Checking Status
If your voxl2 mini has SDK 1.1.1+ or newer, you can use the px4-qshell voxl_esc status command to access the driver which has debug info and tools. If you are on an older SDK, the px4-qshell modal_io status command can be used.
The px4-listener esc_status can be used to check status of published topics.
PX4 Driver
The PX4 parameters that are used by the system are here
For example, if you need to change the motor ordering or min/max RPMs, these are params you will want to tweak.
The driver source code for voxl_esc is here for reference. The driver source code for modal_io is here.
When PX4 runs on VOXL2, this is where voxl_esc is started using SDK 1.1.1+ and this is where modal_io is started on older SDKs.
How to Spin Motors
- Use the
actuator_testcommand, for exampleactuator_test set -m 1 -v 0.05 -t 10, which spins PX4 motor 1 for 10 seconds - Use the motor test feature in QGC.
Hardware Setup
For bi-direction UART communications, connect VOXL 2’s J19 connector to the VOXL Mini ESC’s (M0129) J1 using MCBL-00082 or building your own following this.
M0129 J1:
- Connector - 4 Position JST GH, Vertical, BM04B-GHS-TBT
- Mating Connector - JST GHR-04V-S
M0104 J19:
PWM ESC Option
PWM ESCs can be used with VOXL 2 and VOXL 2 Mini’s built in flight controller. Due to the lack of PWM output on the Qualcomm QRB5165 chipset, an external PWM generator is required. The VOXL 2 ecosystem supports the VOXL 2 IO. To use the VOXL 2 IO to control PWM ESCs follow the VOXL 2 IO User’s Guide
