VOXL CAM Quickstart
First power-up and connection steps for VOXL CAM.
VOXL CAM is a VOXL companion computer, a set of cameras, and optionally a Flight Core and a modem, assembled in one enclosure. Each part is set up the way it is on the standalone products, so the quickstart is a short sequence of existing guides.
  1. Set up the VOXL side. Follow VOXL CAM Setup for power, ADB, and Wi-Fi, then the VOXL Quickstart for the first tools to run.
  2. Set up the Flight Core, if your unit has one. Follow VOXL CAM Flight Core Setup, then the Flight Core Quickstarts for firmware and radio setup.
  3. Set up the modem, if your unit has one. Follow VOXL CAM Modem Setup.
  4. Check the cameras. Open VOXL Portal from a device on the same network and confirm each camera streams.
The VOXL CAM Datasheet lists the configurations, connectors, and dimensions.
