VOXL 2 Mini Hardware Quickstart
NOTE: Please exercise ESD safety precautions and have electronics knowledge when interfacing with the hardware.
For technical details, see the datasheet
How to Setup Hardware
Using VOXL ESC Mini
- Connect power cable to VOXL 2 Mini
J1(3.8V input, but use Power Module or ESC) - The other side of power cable should come soldered to the VOXL Mini ESC
- Connect USBC cable to VOXL 2 Mini
J9 - Connect other side of USBC cable (recommended USB type A) to host computer
- Connect the ESC XT60 connector to battery or wall wart power supply
Using a VOXL Power Module
J1(3.8V input, but use Power Module or ESC) - Connect other side of power cable to Power Module
- Connect Power Module to the wall wart power supply
- Plug wall wart power supply into mains supply
How to Power Off
