Safety First!
For setup and configuration of your Sentinel you must Remove the Propellers for safety.
Battery Information
Sentinel requires a Gens Ace 5000mAh, or any 3S battery with XT60 connector.
Buy Battery Here
To install a 3s battery, slide into the body as shown. There is a stop at the front of the vehicle that will prevent the battery from sliding too far forward. The battery should be pressed all the way in until it hits the stop for a consistent center of mass.
Power on Sentinel by connecting the battery to the XT60 connector.
Benchtop Power Supply
For desktop use, a 12VDC wall power supply can be used and is available here. this is convenient when doing development.
