LegacyThis documents a legacy product. Newer alternatives may be available.
Qualcomm Flight RB5 SDK Chirp Server
  1. rb5-chirp-server
    1. Current equivalent
    2. How to Build and Install
    3. How to Use
rb5-chirp-server
The rb5-chirp-server service publishes range data from the vehicle’s two chirp ultrasonic distance sensors to a named pipe.
The Qualcomm Flight RB5 SDK is the original software stack that shipped on the vehicle. The Qualcomm Flight RB5 is now supported by the VOXL SDK, which replaces these rb5-* services. See the VOXL SDK for RB5 Upgrade Guide.
Current equivalent
The VOXL SDK handles distance sensors through the services described in the Rangefinders feature guide.
If you have a Qualcomm Flight RB5, it comes pre-loaded with the software and there is no need to re-install unless you want to.
How to Use
rb5-chirp-server is a systemd service, started on boot in the factory configuration. See RB5 SDK Services for the boot sequence.
Enable or disable it at boot:
systemctl enable rb5-chirp-server
systemctl disable rb5-chirp-server
Start or stop it now, and check its status and log:
systemctl start rb5-chirp-server
systemctl stop rb5-chirp-server
systemctl status rb5-chirp-server
journalctl -u rb5-chirp-server
