Link
Search
Menu
Expand
Document
Home
VOXL Developer Bootcamp
1. ESD Safety
2. Hardware Quickstart
2.1 VOXL 2
2.2 VOXL 2 Mini
2.3 Starling
2.4 Sentinel
2.5 VOXL Flight
2.6 VOXL
2.7 M500
3. Setting Up ADB
4. WiFi Setup
4.1 VOXL 2 WiFi
4.2 VOXL WiFi
5. Inspect and Configure SKU
6. Modal Pipe Architecture
7. Basic Tools and Utilities
8. Check Calibration
9. VOXL Version
10. Upgrading VOXL SDK
11. VOXL Portal
12. Installing QGC
13. Connect to QGC
14. First Flight
Starling First Flight
Sentinel First Flight
15. Write Apps for VOXL
16. voxl-cross-template
17. Graduation
VOXL SDK
VOXL SDK Release Notes
SDK 1.6 Release Notes
SDK 1.5 Release Notes
SDK 1.4 Release Notes
SDK 1.3 Release Notes
SDK 1.2 Release Notes
SDK 1.1 Release Notes
SDK 1.0 Release Notes
SDK 0.9 Release Notes
Old Releases
SDK Configuration
Config Conventions
voxl-configure-mpa
Configure Extrinsics
Configure Package Manager
Calibration
Calibrate Cameras
Calibrate Camera Focus
Calibrate IMU
Calibrate Barometer
Calibrate Horizon
Feature Guides
Mavlink Routing
VIO
Open-VINS server
VOA
Apriltag Detection
Relocalization
AOI Yaw Tracking
Depth From Stereo
Deep Learning
Mapping and Path Planning
Setting up VOXL Mapper
Interacting with VOXL Mapper
ELRS
M0184 Gemini 915MHz ELRS
M0184 Software Guide
ELRS Configurator
Remote ID
VOXL Modems
Connect to QGC over 4G/5G
Logging
Replaying
Rangefinders
Cameras & Video
MPA Camera Interface
Camera Server
Configure Cameras
Electronic Image Stabilization
FLIR Lepton
FLIR Hadron
UVC Camera Support
RTSP Video Stream
Low Latency Video Streaming
MAVCam Manager
Record Video
Debugging Camera Issues
Sensors
VOXL IMU Server
Voxl Mini Tof Server
Voxl IIM Server
Core Services
VOXL Vision Hub
Wait For FS
voxl-mavlink-server
Debugging Services
VOXL ArduPilot
VOXL PX4
Hardware
System Architecture
Param Files and Log Files
Connectivity
VOXL2 PX4 HITL
PX4 Simulation in Hardware (SIH)
Custom VOXL Applications
Developing Applications for VOXL SDK
VOXL Emulator
Software Packaging Standards
VS Code User Guide
OpenCV Guide
OpenCL Guide
TFLite Guide
MAVSDK
Figure 8
Custom ROS Applications
ROS2 Installation VOXL 2
ROS Installation VOXL 2
ROS Installation VOXL 1
MAVROS
Building ROS Nodes
Building ROS2 Nodes
Misc. User Guides
VOXL 2 Thermal Performance
Enabling File Encryption
Libgphoto2
VOXL 2 Offboard Sensors
Other Software
Accessing QGC via ADB
Using OpenCL inside a Docker Container on VOXL2
Using WSL2 for Upgrading VOXL SDK
EMI Mitigation for GNSS Applications
Core SDK Libraries
libmodal_pipe
libmodal_json
libvoxl_cutils
libvoxl_io
librc_math
libmodal_exposure
libmodal-cv
Inspect Tools
VOXL Inspect Services
VOXL Inspect CPU
VOXL Inspect IMU
VOXL Inspect Camera
VOXL Inspect qVIO
VOXL Inspect Battery
VOXL Inspect GPS
VOXL Inspect Extrinsics
VOXL Inspect Pose
VOXL Inspect Points
VOXL Inspect Tags
VOXL Inspect Vibration
Previous SDKs
VOXL SDK 0.9
VOXL Autopilot & Compute
VOXL 2 User Guides
VOXL 2 Power
VOXL 2 RC Configs
VOXL 2 ESC Configs
VOXL 2 Onboard Sensors
VOXL 2 Image Sensors
VOXL 2 Modems
VOXL 2 Unbricking
VOXL 2 Datasheets
VOXL 2 Feature Matrix
VOXL 2 Connectors
VOXL 2 Mechanical Drawings
VOXL 2 Camera Configs
VOXL 2 LEDs
VOXL 2 HW Versions
VOXL 2 System Image
VOXL 2/VOXL2 Mini System Image
VOXL 2 Linux User Guide
VOXL 2 Kernel Build
VOXL 2 QUPs
VOXL 2 - D0005
VOXL 2 - D0006
VOXL 2 - D0014
VOXL 2 - D0015
VOXL 2 Mini
VOXL 2 Mini User Guides
VOXL 2 Mini Power
VOXL 2 Mini USB Connections
VOXL 2 Mini Shell Access
VOXL 2 Mini RC Configs
VOXL 2 Mini ESC Configs
VOXL 2 Mini Onboard Sensors
VOXL 2 Mini Offboard Sensors
VOXL 2 Mini LEDs
VOXL 2 Mini Linux User Guide
VOXL 2 Mini Switches
VOXL 2 Mini Debug Console
VOXL 2 Mini Datasheets
VOXL 2 Mini Feature Matrix
VOXL 2 Mini Connectors
VOXL 2 Mini System Image
VOXL 2 Mini - D0013
VOXL Flight
VOXL Flight Quickstart
VOXL Flight User Guide
VOXL Flight Datasheets
VOXL Flight Connectors
VOXL Flight LEDs
VOXL Flight IMUs
VOXL Flight Configuration
VOXL Flight Kits
VOXL
VOXL Quickstart
VOXL Hardware Setup
VOXL User Guides
VOXL Serial IO
Thermal and Performance
VOXL GPIO
VOXL I2C
VOXL Fan Control
Unbrick VOXL and VOXL Flight
VOXL Onboard LED Control
How to use VOXL as USB Host
VOXL Hi-res Sensor User Guide
VOXL Stereo Sensor User Guide
VOXL ToF Sensor User Guide
System Image Changelog
VOXL Datasheets
VOXL Functional Description
VOXL Connectors
VOXL Camera Configs
Flight Core
Flight Core Quickstarts
Update Flight Core Firmware
Upload PX4 Parameters
Calibrate Sensors
Configure RC Radio
First Flight
Flight Core User Guides
Flight Core Connections
Flight Core Radios
Flight Core Bootloader
Flight Core Datasheets
Flight Core Connectors
Flight Core LEDs
Flight Core Configuration
Flight Core Kits
Flight Core v2
Flight Core v2 User Guides
Flight Core v2 USB to QGC
Flight Core v2 Power
Flight Core v2 RC Options
Flight Core v2 Actuators
Flight Core v2 Telemetry
Flight Core v2 Firmware
Flight Core v2 Datasheets
Flight Core v2 Connectors
VOXL Dev Kits
VOXL Dev Bundles
VOXL 2 Dev Bundles
VOXL 2 Standalone Bundles
VOXL 2 Coax Camera Bundles
VOXL Flight Deck
VOXL Flight Deck User Guide
VOXL Flight Deck Datasheet
VOXL 2 Flight Deck
VOXL 2 Flight Deck User Guide
VOXL 2 Flight Deck Unboxing
VOXL 2 Flight Deck Setup
VOXL 2 Flight Deck Software
VOXL 2 Flight Deck Datasheet
VOXL CAM
VOXL CAM Quickstart
VOXL CAM User Guide
VOXL CAM Setup
VOXL CAM Flight Core Setup
VOXL CAM Modem Setup
VOXL CAM Datasheet
Dev Drones
Starling 2
1. Hardware Overview
2. Datasheet
Starling 2 Max
2. Datasheet
Sentinel
Sentinel Quickstart
Sentinel User Guide
Sentinel Unboxing
Sentinel Vehicle Components
Sentinel Connect Over ADB
Sentinel Connect Network
Sentinel PX4
Sentinel Pre-Flight Setup
Sentinel Using VIO
Sentinel Factory Reset guide
Sentinel Datasheets
Sentinel Board Connectors
Sentinel Spektrum Bind Board
Sentinel Landing Skids
Legacy EOL Dev Drones
Starling
2. Datasheet
M500
M500 Quickstart
M500 User Guides
VOXL m500 Unboxing
VOXL m500 Components
VOXL m500 Connect Network
VOXL m500 PX4 and GCS
VOXL m500 Pre-Flight Setup
VOXL m500 First Flight
VOXL m500 Using VIO
VOXL m500 Gimbal User Guide
M500 Datasheet
Qualcomm Flight RB5
RB5 Unboxing
RB5 Vehicle Components
RB5 Power Supply and Battery
RB5 Connect Over ADB
RB5 Connect Network
RB5 PX4
RB5 Connect to GCS
RB5 Pre-Flight Setup
RB5 First Flight
RB5 Using VIO
RB5 Using VOA
RB5 Streaming Video
RB5 Flight QDL
Qualcomm Flight RB5 SDK
RB5 SDK Installation
RB5 SDK Services
RB5 PX4
RB5 Modem
RB5 Camera Server
RB5 Chirp Server
RB5 QVIO Server
RB5 VOA Server
RB5 Streamer
RB5 WiFi
RB5 Utils
RB5 Emulator
RB5 Linux User Guide
First Person View (FPV)
Stinger Vision FPV
Stinger Datasheet
Stinger Quick Start Guide
Stinger List of Certifications
Stinger Binding Details
VRX Ground Unit
VRX Ground Unit Datasheet
VRX Ground Unit Quick Start Guide
VRX Ground Unit Developer Guide
VRX Ground Unit Goggles Compatibility
VRX Ground Unit List of Certifications
VTX Air Unit
VTX Air Unit Datasheet
VTX Air Unit Quick Start Guide
VTX Air Unit Software Guide
VTX Air Unit List of Certifications
AI Detection
AI Detection Setup Guide
M0197-FPV Hardware-in-the-Loop
Modems
ELRS
ELRS Configurator
4G LTE Modems
V2 LTE Modem Dongle Datasheet
5G Modems
5G Modem User Guide
5G Modem Datasheet
Microhard Modems
Microhard Add-On Datasheet
Microhard USB Carrier Board
Doodle Labs Modems
Doodle Labs User Guide
DTC Modems
DTC User Guide
DTC Starling Integration
Expansion Boards
USB2 Expander M0017
USB2 Expander M0078
USB2 Type A Breakout
VOXL 2 IO
VOXL 2 IO Datasheet
VOXL 2 IO User Guide
VOXL 2 IO Firmware
VOXL 2 IO Legacy Guide
VOXL 2 USB3 UART Add-On
VOXL 2 Developer Test Board
VOXL 2 Developer Test Board Firmware
PCB Catalog
M0183 VOXL 2 mPCIe Expansion and USB Hub
Accessories
VOXL ESCs
VOXL 4-in-1 ESC Datasheet
VOXL FPV ESC 4-in-1 Datasheet
Manual
PX4 Integration
VOXL ESC FAQ
Power Modules
Power Module v3 Datasheet
Power Module v2 Datasheet
Image Sensors
M0015 Stereo Module Datasheet
M0024 IMX214 Module Datasheet
M0025 IMX214 Module Datasheet
M0073 OV9782 Module Datasheet
M0113 OV9782 Module Datasheet
M0186 IMX664 Low Light FPV Image Sensor Datasheet
M0189 VOXL 2 Mini Tof
Micro-Coaxial User Guide
M0008 DFT Interposer Flex
M0010 Stereo Flex
M0036 Extension Flex 15cm
M0039 Wide Stereo Flex
M0074 Extension Flex 6cm
M0076 VOXL 2 AXT Interposer
M0084 VOXL 2 Y-AXT Flex Cable
M0109 VOXL 2 J-Flex Cable
M0153 MIPI Boson Image Sensor Adapter
M0155 Single Coax Adapter
M0172 DF40 TOF and DF56 Coax Hires Adapter
M0187 VOXL 2 Lepton Adapter
M0195 VOXL 2 Mini Stinger Imager Adapter
Transmitters
Orqa / GHST
VTX Systems
VOXL2 with Third Party VTX
Cables
Cable Datasheets
Cable User Guides
Deprecated
VOXL Software Overview
VOXL Cam ROS
Camera and Video Guides
ModalAI Vision Lib
VOXL RTSP
Snap IMU
VOXL Supporting Software
Camera IMU Coordinate Frames
Misc Software
Snapdragon Navigator
Downloads
Contact
Home
Support
Developer Resources
VOXL 2 Datasheets
Mechanical Drawings
2D Drawings
VOXL 2 IMU Locations
Dimensions
Front
Back
3D Drawings
Mechanical Drawings
2D Drawings
Dimensions
Front
Back
3D Drawings
3D STEP File
