VOXL Supporting Software
This page is deprecated
Please see VOXL-SDK for our current software bundle.
VOXL’s software stack is broken up into 3 parts, each with their own version and ability to upgrade independently or all together.
- VOXL System Image: This includes the root file system and bootloader partitions. It is only necessary to update the system image to add new hardware driver support.
- VOXL Factory Bundle: This contains proprietary and 3rd party software packages (updated infrequently).
- voxl-suite: precompiled packages of ModalAI-developed open-source software (updated regularly)
The System Image and Factory Bundle are available at https://developer.modalai.com/asset. The voxl-suite package uses an OPKG package manager and is hosted here. The installer at the link below will offer to install the voxl-suite for you as the last step.
All three packages are loaded on VOXL boards at the factory but can be updated by the user at any time using the instructions in VOXL Quickstarts.
voxl-suite
The voxl-suite packages are described and maintained here.
VOXL Factory Bundle
v1.0.1
Note: System Image 2.3.0+ is required to use Factory Bundle v1.0.1
Package list:
| Name | Package | Notes |
| aufs-util | aufs-util_3.14+git0+b59a2167a1-r0_aarch64.ipk | Required for Docker on VOXL |
| avahi-daemon | avahi-daemon_0.6.31-r11.1_aarch64_js.ipk | |
| cgroup-lite | cgroup-lite_1.1-r0_aarch64.ipk | Required for Docker on VOXL |
| royale-331-spectre-4-7 | latest_royale-331-spectre-4-7_0.0.1_8x96.ipk | Required for A65 Time-of-Flight |
| lib32-git-perltools | lib32-git-perltools_2.5.0-r0_armv7a-vfp-neon.ipk | |
| libavahi-common3 | libavahi-common3_0.6.31-r11.1_aarch64.ipk | |
| libavahi-core7 | libavahi-core7_0.6.31-r11.1_aarch64.ipk | |
| libcgroup | libcgroup_0.41-r0_aarch64.ipk | Required for Docker on VOXL |
| libdaemon0 | libdaemon0_0.14-r0_aarch64.ipk | |
| libncurses | libncursesw5_5.9-r15.1_aarch64.ipk | Required for Docker on VOXL |
| libnss-mdns | libnss-mdns_0.10-r7_aarch64.ipk | |
| libsmartcols | libsmartcols1_2.26.2-r0_aarch64.ipk | Required for Docker on VOXL |
| libsystemd | libsystemd0_225+git0+e1439a1472-r0_aarch64 | Required for Docker on VOXL |
| Qualcomm Machine Vision SDK | mv_1.2.8_8x96.ipk | Qualcomm Developer Network |
| ROS Indigo Build Deps | ros-indigo-build-deps_1.0.1.ipk | Source |
| util-linux | util-linux_2.26.2-r0_aarch64_js.ipk | Required for Docker on VOXL |
| util-linux-losetup | util-linux-losetup_2.26.2-r0_aarch64.ipk | Required for Docker on VOXL |
| util-linux-swaponoff | util-linux-swaponoff_2.26.2-r0_aarch64.ipk | Required for Docker on VOXL |
| util-linux-umount | util-linux-umount_2.26.2-r0_aarch64.ipk | Required for Docker on VOXL |
| voxl-utils | voxl-utils_0.5.1.ipk | Source |
v0.0.3, v0.0.4, v0.0.5
Note: the factory version is bumped to stay in sync with software bundle version
Package list:
| ffmpeg | ffmpeg_3.4.5_8x96_js.ipk | Source |
You can check the version of the VOXL Factory Bundle by looking at the version file.
cat /etc/modalai/voxl-factory-bundle-version.txt
0.0.5
VOXL Software Bundle
Note: as of System Image 2.3.0, this is considered legacy. It is replaced with the voxl-suite packages
V0.0.5
Changes:
- Added support for ICM-42688 in imu_app_0.0.5_8x96.ipk for factory test
The package list:
| cellular_tools_0.2.0_8x96.ipk | ||
| Docker | docker_1.9.0+git…aarch64.ipk | |
| IMU app | imu_app_0.0.5_8x96.ipk | Soon to be replaced by voxl-imu |
| RC Math Library | librc_math_1.0.1.ipk | Source |
| VOXL IO Library | libvoxl_io_0.0.6.ipk | Source |
| ModalAI Vision Lib | modalai-vl_0.1.0_8x96.ipk | |
| VOXL Camera Manager | voxl-cam-manager_0.2.1.ipk | Source |
| VOXL Docker Support | voxl-docker-support_1.1.0.ipk | Source |
| VOXL IMU | voxl_imu_0.0.4_8x96.ipk | |
| VOXL ROS Nodes | voxl-nodes_0.0.6_8x96.ipk | Source |
| VOXL RTSP | voxl-rtsp_1.0.0_8x96.ipk | Source |
| VOXL Utils | voxl-utils_0.4.6.ipk | Source |
| VOXL Vision PX4 | voxl-vision-px4_0.4.1_8x96.ipk | Source |
V0.0.4
Changes:
- Improvements in voxl-vision-px4
The package list:
V0.0.3
The package list:
| cellular_tools_0.1.5_8x96.ipk | ||
| IMU app | imu_app_0.0.3_8x96.ipk | Soon to be replaced by voxl-imu |
| ModalAI Vision Lib | modalai-vl_0.0.8_8x96.ipk | |
| VOXL IMU | voxl_imu_0.0.3_8x96.ipk | |
| VOXL Utils | voxl-utils_0.4.4.ipk | Source |
| VOXL Vision PX4 | voxl-vision-px4_0.4.0_8x96.ipk | Source |
Checking Version
Run the following command:
voxl-version
or you can check the version of the VOXL Software Bundle by looking at the version file:
cat /etc/modalai/voxl-software-bundle-version.txt
0.0.5
