VOXL Flight Hardware Quickstart
Please exercise ESD safety precautions and have electronics knowledge when interfacing with the hardware.
Quickstart Video
How to Setup Hardware
  • Connect Micro B side of USB cable to VOXL Flight
  • Connect other side of USB cable (recommmended USB type A) to host computer for later use
VOXL Flight HW Setup
  • Connect the power cable to Power as shown
  • Connect the other side of the power cable to the VOXL Power Module as shown
  • Connect one side of the USB cable to the host computer and connect the other side to the USB (adb) port as shown.
    • Note: the Micro USB connector will consume only a portion of the USB 3.0 port. A USB 3.0 cable can be used as well.
  • Now plug in the power supply (5V/6A DC output) to the wall, and plug it in to the VOXL Power Module barrel jack as shown
How to Power Off
Next Step: Set up ADB
