VTX Air Unit Datasheet
Images
High-Level Specs
| Range | 10km+ 5GHz or 2.4GHz (LOS) |
| Video Performance | 1280*720@60fps, 40ms glass-to-glass min, 50ms avg |
| Frequencies Supported | 2.412-2.484GHz or 5.180-5.865GHz |
| Compute. | ModalAI M0204-1 - VOXL 2 Mini |
| USB Port | Yes (USB2 Peripheral mode). |
| IP Interface | Yes (USB-to-Ethernet -> RTSP) |
| Weight | 86g (C51 camera config, EO + IR) w/o battery |
| Size | Size (L x W x H): 45mm x 45mm x 25mm |
| Battery/Power | 2S-6S (6.4-25.2V), XT60 connector, 6W max |
| Antennas | QTY2 U.FL (MHF1), 5GHz (qty-1) and 2.4GHz (qty-1) |
| Image Sensor Options | C50 IMX664, C51 IMX664 and Boson+ (stream switchable) |
Supported VRX Ground Units
- VRX Ground Unit (
MVX-R0001-7-M31)
VOXL SDK Support
The VTX Air Unit is supported in VOXL SDK 1.6.0+
See VTX Ground Unit Software Guide for more details.
Enclosure/Mount
Version 1
- Primary Mounting Hole Pattern - 20mm x 20mm - M2 screws - use this to mount to frame
- Secondary - 30.5mm x 30.5mm - VOXL2 Mini (M0204) mounts to these ‘passthrough’ holes
Interfaces
Antennas
M10001287- SINGULARITY 2.4 V2, RHCP, 100mm tube, 190mm RG178 to U.FLM10001288- CP5.1, RHCP, 100mm tube, 190mm RG178 to U.FL
Power Connectors
MCBL-00115-1- XT30 (included)MCBL-00116-1- XT60 (standard)
Image Sensors
MCCA-M0186- IMX664 (standard)M10000958-C- Boson+ (option)
Micro Coax Cables
MCBL-00084-140- 140mm micro coax
SKUs
Stand Alone VTX
| ModalAI SKU | Description |
MVX-T0001-6-V1-C50-M26 | VTX, Gen1.5, IMX664 (EO) |
MVX-T0001-6-V1-C51-M26 | VTX, Gen1.5, IMX664 (EO), Boson+ (IR) |
Drones with VTX
MRB-D0013-6-V2-C33-M26-T8-X8 | Stinger |
MRB-D0013-6-V2-C34-M26-T8-X8 | Stinger with Boson+ IR |
VTX Image Sensors
MSA-T0001-1-03 | VTX Subassembly, Image Sensor, IMX664 EO |
MSA-T0001-1-04 | VTX Subassembly, Image Sensor, Boson+ IR |
VTX Antenna
MVX-TA01 | VTX Subassembly, Antenna Kit (2.4/5GHz) |
M10001287 - SINGULARITY 2.4 V2, RHCP, 100mm tube, 190mm RG178 to U.FL | |
M10001288 - CP5.1, RHCP, 100mm tube, 190mm RG178 to U.FL |
Other
MSA-T0001-1-01 | VTX Subassembly, Compute, Radio, Cables |
MSA-T0001-1-02 | VTX Subassembly, Fasteners, 3D Printed Parts |
MSA-T0001-1-52 | VTX Subassembly, Accessories |
