VRX Ground Unit Quick Start Guide
Quick Start Videos
VTX/VRX Out of Box Experience
VTX/VRX Changing Encryption Keys
Example Video Stream
Using Orqa FPV.One to pilot a Stinger Vision FPV using RA01 antenna option, eg. X2-AIR 5.8 MKII.
Hardware Overview
Interfaces
| Interface | Description |
| SMA Antennas | 2.412-2.484GHz or 5.180-5.865GHz, RHCP recommended |
| USB | Video Recordings, Encryption Key Generation/Updates |
| DislpayPort Out | Use USBC to HDMI adapter listed below to get HDMI output |
| HDMI (not active) | Note: the HDMI port is not active in this hardware version. Instead, use USBC to HDMI adapter like below |
Buttons
| Button | Primary Use | Secondary Function (when also pressed with Function Key) |
| 1 | Channel Up | |
| 2 | Record Start/Stop | Generate Encryption Key (save to attached USB Flash Drive…) |
| 3 | Fucntion Key | |
| 4 | Channel Down |
USBC-to-HDMI Adpaters
The following has been succesful in our testing:
- 201388-GRY (included in K1 kit)
Battery/Power Supply
2S-6S supported (), ~7W max usage
Antennas
M10001129- Antenna, X2-AIR 5.8 MKII, RHCP, RG316 cable, SMA, 300mmM10001130- Antenna, X2-AIR 5.8 MKII, RHCP, RG316 cable, SMA, 400mmM10001136- Antenna, 4.9-5.9Ghz, 5dBi, Linear, Whip, SMA, 44mm
Drone Side:
M10001112- 5.8 Core: RHCP 160mm RG137 U.FL AntennaM10001114- 2.4 Singularity: RHCP 160mm RG137 U.FL Antenna
System Overview
Pairing/Binding with VTX
VTX and VRX should “pair” when both powered up by default as shipped from the factory.
Cool use cases (and things to be aware of when powering on multiple units at a time):
- Multiple VRXs can be “paired” with a single VTX, allowing for multi view drop from a VTX
- Multiple VTXs can be configured on different channels, and a single VRX can swap between channels to stream from multiple VTXs.
- VRX can be configured to recieve IP from UAS over VPN offering low latency stream
Changing Channels
Using buttons 1 and 4 shown above so scan through channels to locate streams from VTX systems using the same encryption key.
Generating New Encryption Key
If you want to change the encryption keys from the default, you can generate new ones and then use them on VTX systems to “pair/bind”.
To generate a new key, have:
- the VRX powered on
- a USB flash drive inserted into the USB port
Press and hold buttons 2/3 together for 2 seconds to provision the USB flash drive with a new key.
Using New Encryption Key
Power cycle the VRX with a provisioned USB flash drive inserted into the USB port.
Software Overview
The VRX Grount Unit is supported in VOX VRX SDK 1.5.0+ (ubun2.0-multi_SDK_1.5.0.tar.gz).
See VRX Ground Unit Developer Guide for more details.
Default Settings
VTX and VRX ship with default:
- frequency set to 5.805 GHz
- encryption key, to generate new ones (recommended) see above
OSD
To access the OSD menu:
Example of the current OSD menu:
