VRX Ground Unit Goggles Compatibility
  1. MVX VRX Goggles Support
    1. Tested Goggles and Required Accessories for VRX
The VRX (Video Receiver) Ground Unit, with SKU MVX-R0001 (VRX Gen1.5) , is designed to be compatible with various goggles. For video output, the VRX utilizes a USBC DisplayPort running at 60 frames per second (FPS) . Therefore, a DisplayPort to HDMI Adapter is generally required to connect the VRX to goggles. An example adapter is Cable Matters 48Gbps USB C to HDMI 2.1 Adapter.
Below is a compatibility guide for tested goggles and their necessary cables and adapters, including available purchase links:
The VRX Ground Unit also has its own dedicated Quick Start Guide and Software Guide [63, conversation history], which can be found in the ModalAI Technical Docs [63, conversation history]. NotebookLM can be inaccurate; please double check its responses.
