VRX Ground Unit Datasheet
Supported VTX Air Units
- Stinger Vision FPV (
MRB-D0013-6-C33-M26-T8-X8)
High-Level Specs
| Range | 10km+ 5GHz or 2.4Ghz (LOS) |
| Video Performance | 1280*720@60fps, 40ms glass-to-glass min, 50ms avg |
| Frequencies Supported | 2.412-2.484GHz or 5.180-5.865GHz |
| Video Output | DisplayPort over USB-C |
| Computing | ModalAI M0205-1 - VOXL 2 Mini VRX |
| Weight | 120g w/o battery |
| Size | Size (L x W x H): 4” x 2” x 1” |
| Battery/Power | 2S-6S, XT30 connector, ~7W |
| Antennas | QTY3 SMA |
VOXL SDK Support
The VRX Grount Unit is supported in VOXL VRX SDK 1.4.5+ (ubun2.0-multi_SDK_1.4.5.tar.gz).
See VRX Ground Unit Developer Guide for more details.
SKUs
| ModalAI VRX | Description |
| MVX-R0001-7-V0-M31-K0 | VRX, Gen1.5, VRX Only |
| MVX-R0001-7-V0-M31-K1 | VRX, Gen1.5, RA01 Antenna, Cables, No Goggles |
| MVX-R0001-7-V0-M31-K2 | VRX, Gen1.5, RA01 Antenna, Cables, Orqa FPV.One Goggles |
VRX by itself
Includes RA01 antenna config - 5GHz QTY2 Patch Directional, QTY1 Omni Whip
M10001129- Antenna, X2-AIR 5.8 MKII, RHCP, RG316 cable, SMA, 300mmM10001130- Antenna, X2-AIR 5.8 MKII, RHCP, RG316 cable, SMA, 400mmM10001136- Antenna, 4.9-5.9Ghz, 5dBi, Linear, Whip, SMA, 44mm
Semi-integrated into Orqa FPV.One goggles with “beta” level integration.
NOTE: this is prototype stage only and not shipping.
