VOXL 2 Mini Feature Matrix
Specifications
| Feature | VOXL 2 Mini | VOXL 2 |
| Dimensions | 42mm x 42mm | 70mm x 36mm |
| Weight | 11g | 16g |
| MIPI Image Sensors | 4 Concurrent | 6 Concurrent |
| CPU | QRB5165 8 cores up to 3.091GHz 8GB LPDDR5 128GB Flash | QRB5165 8 cores up to 3.091GHz 8GB LPDDR5 128GB Flash |
| OS | Ubuntu 18.04 - Linux Kernel v4.19 | Ubuntu 18.04 - Linux Kernel v4.19 |
| GPU | Adreno 650 GPU – 1024 ALU | Adreno 650 GPU – 1024 ALU |
| NPU | 15 TOPS | 15 TOPS |
| Flight Controller Embedded | Yes (PX4 or Ardupilot on Sensors DSP) | Yes (PX4 on Sensors DSP) |
| Integrated Sensors | QTY. 2 ICM-42688P IMU, QTY. 1 ICP-10100 | QTY. 2 ICM-42688P IMU, QTY. 1 ICP-10100 |
| Power Consumption | 0.5 - 8W | 0.5 - 8W |
| Built in WiFi | No | No |
| Add-on Connectivity | via USB3 port, WiFi, 5G, 4G/LTE, Microhard | Via Add-on board, WiFi, 5G, 4G/LTE, Microhard |
| Video Encoding | 8K30 h.264/h.265 108MP still images | 8K30 h.264/h.265 108MP still images |
| VOXL SDK: GPS-denied navigation, SLAM, obstacle avoidance, object recognition | Yes | Yes |
| ROS | ROS 1 & 2 | ROS 1 & 2 |
| QGroundControl | Yes | Yes |
| ATAK | Yes | Yes |
| NDAA ’20 Section 848 Compliant | Yes, Assembled in USA | Yes, Assembled in USA |
| PMD TOF | Yes | Yes |
| FLIR Boson | USB | USB |
| FLIR Lepton | USB, SPI in development | USB, SPI in development |
Platform Release
VOXL 2 Mini requires Platform Release 1.0 and newer. See Platform Releases.
For additional details regarding compatibility see the following resources:
