VOXL Open-VINS Server
voxl-open-vins-server is a multi-camera visual-inertial odometry (VIO) service for the VOXL 2 platform. It uses an MSCKF-based estimator derived from OpenVINS to fuse data from up to 3 tracking cameras and an IMU, producing real-time pose and velocity estimates that are forwarded to the autopilot as odometry data.
The server is built around three modular subsystems: VoxlCore (configuration, housekeeping, publishing), VoxlCam (camera management and feature tracking via OpenCL), and VoxlIMU (IMU data acquisition and frame transformation). Data flows through ModalAI’s MPA pipe architecture, which decouples sensor producers from VIO consumers and downstream clients.
  1. Architecture
    1. System Overview
    2. Data Flow
    3. Module Dependencies
    4. Camera Class Hierarchy
    5. Initialization Flow
  2. Prerequisites
  3. Installation and Setup
    1. Install
    2. Disable qvio
    3. Generate Configuration
    4. Start the Service
  4. Configuration Files
    1. extrinsics.conf
    2. vio_cams.conf
    3. voxl-open-vins-server.conf
      1. Auto-Reset Parameters
      2. State Machine and Fallback
      3. Yaw Monitoring
      4. OpenVINS and Camera Mode
      5. Takeoff and Occlusion
      6. Fusion and Frame Settings
      7. Quality Hysteresis
  5. MPA Pipes
    1. Output Pipes
    2. Publisher Pipeline
    3. Input Pipes
    4. Control Pipe
  6. Command-Line Options
  7. Client Tools
    1. voxl-reset-vins
    2. voxl-inspect-vins
    3. voxl-log-vins
    4. voxl-benchmark-vio
  8. Testing
    1. Hand Testing
      1. Steps
    2. Flight Testing
  9. Troubleshooting
    1. No config file
    2. Server fails to start
    3. VIO quality is poor or resets frequently
    4. IMU body frame errors
  10. Legacy Parameter Notes
  11. API Reference
Architecture
System Overview
Architecture Diagram
The server follows an IMU-driven fusion pattern where IMU data arrival triggers synchronized processing of camera frames:
  1. IMU data arrives via MPA pipe and is buffered by VoxlIMU. The FrameTransform module detects gravity direction and jerk events for initialization.
  2. Camera frames arrive through per-camera MPA pipes. CameraManager dispatches frames to MonoCamera or StereoCamera instances (based on configuration), which push processed frames into CameraQueueFusion.
  3. Each IMU callback triggers CameraQueueFusion::getSortedBatch() to retrieve time-synchronized camera frames, which are fed alongside IMU data to the OpenVINS VioManager MSCKF estimator.
  4. Publisher formats the resulting state (pose, velocity, quality, error codes) with coordinate frame transformation (OpenVINS → FRD) and writes to output pipes.
  5. HealthCheck runs at 30 Hz, monitoring connectivity, error codes, and auto-reset conditions.
Data Flow
Data Flow
IMU callback data flow: each IMU sample triggers _imu_data_handler_cb, which propagates IMU state, fetches time-synchronized camera frames via CameraQueueFusion::getSortedBatch(), feeds them to the VioManager, and publishes the resulting estimate through Publisher::publish().
IMU Call Graph
IMU callback call graph (from Doxygen API): shows connect_imu_service_imu_data_handler_cbCameraQueueFusion::getSortedBatchPublisher::publish with all sub-calls.
Module Dependencies
Module Dependencies
ModuleKey ClassesResponsibility
VoxlCorePublisher, HealthCheck, CameraQueueFusion, VioManagerMain loop, configuration, publishing, health monitoring, multi-camera fusion
VoxlCamCameraManager, CameraBase, MonoCamera, StereoCameraCamera pipe subscription, image processing, per-camera queuing
VoxlIMUFrameTransform, _imu_data_handler_cbIMU pipe subscription, frame transformation, jerk detection
Camera Hierarchy
CameraBase is the abstract base class. MonoCamera handles single-camera pipes, StereoCamera handles stereo pairs. Both push CameraData into lock-free SPSC queues consumed by CameraQueueFusion.
Initialization Flow
Init Flow
main() call graph: reads config, syncs camera calibration, starts Publisher (which starts HealthCheck), then enters the event loop.
Prerequisites
  • VOXL 2 hardware
  • VOXL SDK 1.4.0 or later
  • All tracking cameras calibrated (intrinsics files present in /data/modalai/)
  • Extrinsics configured in /etc/modalai/extrinsics.conf (see Configure Extrinsics)
  • Camera feeds verified in voxl-portal before enabling VIO
Install
If you are working on a non-development drone, back up configuration and intrinsic files first:
/etc/modalai
/data/modalai
Disable qvio
Only one VIO source should be active at a time. Disable qvio before starting voxl-open-vins-server:
voxl-configure-qvio disable
Run the configuration tool to create all necessary config files:
voxl-configure-open-vins <camera_configuration>
For example, voxl-configure-open-vins starling2_2cam configures a two-camera setup using front and down tracking cameras. The result should be in agreement with the three configuration files in /etc/modalai/:
  • voxl-open-vins-server.conf
  • vio_cams.conf
  • extrinsics.conf (if not already present)
Start the Service
systemctl restart voxl-open-vins-server
Configuration Files
Three files in /etc/modalai/ control the server:
extrinsics.conf
Defines the geometric relationship between sensors (cameras, IMU) and the body frame. See the extrinsics configuration page for details.
When imu_body_frame_mode is enabled (default), the server also reads the body -> imu_apps extrinsic to transform VIO output into the body frame. For cross-platform compatibility OVins-server has been disable for IMU non-body frames.
vio_cams.conf
Defines which camera pipes to subscribe to and how each camera participates in VIO. Example for a two-camera setup:
    "cams": [{
            "enable":               true,
            "name":                 "tracking_front",
            "pipe_for_preview":     "tracking_front",
            "pipe_for_tracking":    "tracking_front",
            "is_occluded_on_ground": false,
            "imu":                  "imu_apps",
            "cal_file":             "opencv_tracking_front_intrinsics.yml"
            "enable":               true,
            "name":                 "tracking_down",
            "pipe_for_preview":     "tracking_down",
            "pipe_for_tracking":    "tracking_down",
            "is_occluded_on_ground": true,
            "imu":                  "imu_apps",
            "cal_file":             "opencv_tracking_down_intrinsics.yml"
            "enable":               false,
            "name":                 "tracking_rear",
            "pipe_for_preview":     "tracking_rear",
            "pipe_for_tracking":    "tracking_rear",
            "imu":                  "imu_apps",
            "cal_file":             "opencv_tracking_rear_intrinsics.yml"
FieldDescription
enableWhether this camera is active in the VIO pipeline
nameCamera identifier used in logs and overlays
pipe_for_trackingMPA pipe name to subscribe to for feature tracking frames. Can differ from the preview pipe (e.g. tracking_front_misp_norm or tracking_front_misp_grey) depending on which image processing yields the best features for your application
pipe_for_previewMPA pipe name used for overlay visualization
is_occluded_on_groundIf true, this camera’s view is obstructed while landed (e.g. a downward camera on the ground). The server will not use features from this camera until the drone reaches takeoff_alt_threshold altitude
imuIMU pipe name. All cameras must reference the same IMU
cal_fileOpenCV intrinsics calibration file in /data/modalai/
To enable a third camera, set its enable field to true.
Main server configuration file. The server creates this file with default values if it does not exist. All parameters are read by read_server_config() in VoxlConfigure.cpp.
ParameterTypeDefaultDescription
en_auto_resetbooltrueEnable automatic VIO reset when divergence or low feature count is detected
auto_reset_max_velocityfloat20.0Velocity magnitude threshold (m/s) above which the system considers the estimate divergent
auto_reset_max_v_cov_instantfloat0.2Instantaneous velocity covariance threshold that triggers an immediate reset
auto_reset_max_v_covfloat0.2Average velocity covariance threshold for sustained poor estimation
auto_reset_max_v_cov_timeout_sfloat0.5Duration (s) that velocity covariance must exceed the threshold before triggering a reset
auto_reset_min_featuresint1Minimum number of tracked features required to avoid a reset
auto_reset_min_feature_timeout_sfloat10.0Duration (s) that the feature count must stay below the minimum before triggering a reset
ok_state_grace_timeout_sfloat2.0Grace period (s) after entering OK state during which quality is held low to avoid false confidence from bad initialization
auto_fallback_timeout_sfloat3.0Duration (s) before the system falls back to a simpler tracking mode
auto_fallback_min_vfloat0.6Minimum velocity (m/s) required to trigger auto-fallback mode
Yaw Monitoring
en_cont_yaw_checksboolfalseEnable continuous yaw rate monitoring for stability validation
fast_yaw_threshfloat5.0Threshold for detecting rapid yaw changes that may indicate tracking issues
fast_yaw_timeout_sfloat1.75Duration (s) for fast yaw detection before triggering corrective action
yaml_folderstring/usr/share/modalai/voxl-open-vins/VoxlConfig/starling2Path to the folder containing OpenVINS YAML configuration files (estimator_config.yaml, kalibr_imucam_chain.yaml)
using_stereoint0Set to 1 to enable stereo camera mode
sync_configbooltrueSync OpenVINS YAML configs with system calibration data (intrinsics and extrinsics) on startup
takeoff_alt_thresholdfloat0.5Altitude (m) above which cameras marked is_occluded_on_ground become active
takeoff_occlude_stereo_leftboolfalseOcclude the stereo left camera during takeoff
takeoff_occlude_stereo_rightboolfalseOcclude the stereo right camera during takeoff
fusion_rate_dt_msfloat20.0Fusion loop interval in milliseconds (50 Hz default)
imu_body_frame_modebooltrueWhen enabled, the server reads the body -> imu extrinsic and outputs VIO in the body frame. The IMU pipe is subscribed as imu_apps_body instead of imu_apps
Quality Hysteresis
The server uses a state machine with hysteresis to classify VIO quality: INITIAL, GOOD, and BAD. The thresholds and transition counts below control state transitions.
quality_low_thresh_initialint15Quality score threshold below which degradation is detected in INITIAL state
quality_low_thresh_goodint14Quality score threshold below which degradation is detected in GOOD state
quality_high_threshint35Quality score threshold above which recovery is detected (used for INITIAL->GOOD and BAD->GOOD transitions)
quality_initial_to_bad_countint20Consecutive low-quality samples required to transition from INITIAL to BAD
quality_initial_to_good_countint50Consecutive high-quality samples required to transition from INITIAL to GOOD
quality_bad_to_good_countint60Consecutive high-quality samples required to transition from BAD to GOOD
quality_good_to_bad_countint45Consecutive low-quality samples required to transition from GOOD to BAD
MPA Pipes
Output Pipes
PipeTypeDescription
ov_extendedext_vio_data_tFull VIO state including covariance matrices, feature counts, quality, and error codes
ovvio_data_tSimplified VIO data with pose and velocity for basic consumers
ov_statusov_status_tSystem status, health information, and operational state
Publisher Pipeline
Publisher Pipeline
Publisher::publish() call graph: calculates quality score, computes angular velocity via dirty quaternion differentiation, applies OpenVINS→FRD coordinate transform, and checks auto-reset conditions before writing to output pipes.
Input Pipes
PipeSourceDescription
imu_apps (or imu_apps_body)voxl-imu-serverIMU data (accelerometer and gyroscope). The _body variant is used when imu_body_frame_mode is enabled
Camera pipes (dynamic)voxl-camera-serverOne pipe per camera defined in vio_cams.conf (e.g. tracking_front, tracking_down)
Control Pipe
The server exposes a control pipe at /run/mpa/ov/control that accepts the following commands:
CommandDescription
RESET_VIO_SOFTSoft reset: reinitializes the VIO state without recreating the VioManager
RESET_VIO_HARDHard reset: destroys and recreates the VioManager from scratch
Control pipes are available on both the ov_extended and ov server channels.
Usage: voxl-open-vins-server [OPTIONS]
Options:
  -d, --debug     Enable debug output and detailed logging
  -v, --verbose   Enable verbose output and status information
  -c, --config    Configuration only mode (load and validate config, then exit)
  -i, --imu-body  Enable IMU body measurements (overrides conf file)
  -h, --help      Display help message
Examples:
voxl-open-vins-server              # Run with default settings
voxl-open-vins-server -d           # Run with debug output
voxl-open-vins-server -v -c        # Validate configuration only
voxl-open-vins-server --imu-body   # Force IMU body frame mode
Client Tools
voxl-reset-vins
Sends a reset command to the running server through the control pipe.
voxl-reset-vins          # Send a hard reset
voxl-reset-vins -s       # Send a soft reset
voxl-inspect-vins
Real-time terminal display of VIO data from the ov pipe. Shows position, rotation, velocity, features, quality, state, and error codes.
voxl-inspect-vins              # Default view (position, rotation, features, quality, state, errors)
voxl-inspect-vins -v           # Include velocity
voxl-inspect-vins -b           # Display values in body frame (reads body->imu extrinsic)
voxl-inspect-vins -z           # Print all fields
voxl-inspect-vins -n           # Print each sample on a new line (useful for logging)
FlagDescription
-aPrint IMU angular velocity
-bPrint values in body frame
-gPrint gravity vector
-mPrint camera-to-IMU extrinsics
-nPrint each sample on a new line
-tPrint timestamp in nanoseconds
-vPrint velocity
-zPrint all fields
voxl-log-vins
Subscribes to the ov_status pipe and logs VIO status data including error codes, state transitions, and feature statistics. Useful for post-flight analysis.
voxl-log-vins
voxl-benchmark-vio
Automated evaluation tool for VIO parameter tuning. Replays logs and records performance metrics (uptime duration, endpoint error, failure codes) across different parameter configurations.
TODO
Testing
OUTDATED TODO
Hand Testing
Hand testing verifies that extrinsics are correct and the VIO pipeline is functioning before flight. This is the recommended starting point.
Steps
  1. SSH or ADB shell into the VOXL 2.
  2. Start the service:
  3. Open voxl-portal and navigate to Cameras > ov_overlay. You should see the tracking camera feed(s) with no feature points yet.
  4. Lift the drone with a small jerk motion (simulating takeoff). Features should start populating on the overlay.
  5. Perform translational motion: move the drone left-right, then front-back. Watch the XYZ position values.
  6. Check roll, pitch, and yaw by navigating to the VIO tab in voxl-portal. Select ov_extended or vvhub_wrt_local.
  7. Move the drone around in 3D space, verifying distance readings are accurate.
    You can also use voxl-inspect-vins in the terminal for a text-based view.
  8. Verify in QGroundControl that the drone shows “Ready to Fly” in Position mode.
  9. If tracking looks correct, proceed to flight testing. If not, double-check your extrinsics.conf. You can isolate cameras by disabling them one at a time in vio_cams.conf.
Flight Testing
You must complete hand testing before flight to avoid fly-aways from bad extrinsics or incorrect parameters.
  3. Open QGroundControl and connect to the VOXL 2.
  4. Verify QGC shows “Ready to Fly”.
  5. Ensure the drone is in Position flight mode and begin flying.
  6. Test roll, pitch, yaw maneuvers and hover in place for several seconds to verify tracking stability.
  7. If everything is stable, continue normal flight operations with OpenVINS.
Troubleshooting
No config file
If voxl-open-vins-server.conf does not exist, run:
  • Check that voxl-camera-server and voxl-imu-server are running and providing data.
  • Verify camera intrinsics files exist in /data/modalai/.
  • Verify extrinsics are configured: cat /etc/modalai/extrinsics.conf.
  • Check the journal for error details: journalctl -u voxl-open-vins-server -n 50.
  • Increase auto_reset_min_feature_timeout_s to allow more time before feature-count resets.
  • Verify cameras have clear field of view with sufficient texture.
  • Check for vibration issues. Excessive IMU vibration degrades the estimator.
  • If using occluded cameras, verify takeoff_alt_threshold matches your takeoff environment.
  • Tune quality hysteresis thresholds if transitions between GOOD and BAD are too sensitive.
If you see Failed to fetch body->imu_apps extrinsic, add the body -> imu_apps relationship to your extrinsics.conf.
The following parameters from older versions of voxl-open-vins-server.conf have been removed. They are either handled internally, moved to OpenVINS YAML configs, or no longer applicable:
Removed ParameterNotes
en_vio_always_onVIO now initializes via jerk detection and does not require arming. No longer needed
en_ext_feature_trackerExternal feature tracker support removed; tracking is handled internally via OpenCL
en_gpu_for_trackingGPU/DSP tracking replaced by OpenCL-based tracking in all configurations
histogram_methodHandled automatically based on detected camera sensor
use_maskMasking configuration moved to OpenVINS YAML configs
en_force_initInitialization is now handled by the jerk detection system in FrameTransform
max_slam_featuresMoved to OpenVINS estimator_config.yaml
max_slam_in_updateMoved to OpenVINS estimator_config.yaml
max_msckf_in_updateMoved to OpenVINS estimator_config.yaml
en_force_ned_2_fluReplaced by imu_body_frame_mode and extrinsic-based frame transformation
takeoff_camTakeoff camera is now automatically determined from is_occluded_on_ground in vio_cams.conf
takeoff_thresholdRenamed to takeoff_alt_threshold
API Reference
For detailed C++ API documentation including class hierarchies, call graphs, and source code reference, see the Doxygen API Documentation.
