How to Control the On-board RGB LEDs on VOXL
VOXL has a small surface mount RGB LED located next to the fan connector J6. LEDs can be accessible using the following devices:
/sys/class/leds/red
/sys/class/leds/green
/sys/class/leds/blue
Query maximum brightness setting.. Should be 255 (optional):
cat /sys/class/leds/red/max_brightness
255
Set PWM period (microseconds) for LED PWM control (optional.. default 1khz)
#set to 1kHz
echo 1000 > /sys/class/leds/red/pwm_us
Set brightness of 127 (out of 255) for red LED:
echo 127 > /sys/class/leds/red/brightness
Turn red LED off:
echo 0 > /sys/class/leds/red/brightness
Next: VOXL as a USB host
