voxl-mavlink-server
  1. Overview
  2. Configuration
    1. udp_mtu
  3. Pipes
voxl-mavlink-server manages MAVLink routing between network interfaces, MPA applications, and the flight controller such as PX4.
Configuration
voxl-mavlink-server reads its configuration from /etc/modalai/voxl-mavlink-server.conf. The available fields and their defaults (as of v1.4.18) are:
FieldDefaultDescription
primary_static_gcs_ip"192.168.8.10"Static GCS IP that voxl-mavlink-server automatically tries to connect to. 192.168.8.10 is the first IP that VOXL DHCP serves when connecting in WiFi SoftAP mode. Set to empty or NULL to let the GCS initialize the connection instead.
primary_static_gcs_ip_port14550UDP port number for the primary static GCS IP.
secondary_static_gcs_ip"192.168.8.11"Second static GCS IP to automatically try to connect to.
secondary_static_gcs_ip_port14550UDP port number for the secondary static GCS IP.
onboard_port_to_autopilot14556UDP port to send high-rate onboard data to SLPI when running voxl-px4.
onboard_port_from_autopilot14557UDP port to receive high-rate onboard data from SLPI.
gcs_port_to_autopilot14558UDP port to send normal-rate GCS data to SLPI.
gcs_port_from_autopilot14559UDP port to receive normal-rate GCS data from SLPI.
en_external_uart_apfalseQRB5165 only. Set to true to enable UART communication to an external flight controller, otherwise a UDP interface is started to talk to voxl-px4 on localhost.
autopilot_uart_bus1UART bus for the external autopilot. Bus 1 goes through the legacy B2B connector (exposed by the M0125 and M0141 accessory boards); bus 12 goes through the ESC port (J18).
autopilot_uart_baudrate921600UART baudrate for the external autopilot.
autopilot_mission_delay_start-1-1 is off; a value >0 delays mission start by that many seconds.
autopilot_mission_delay_soundfalsePlay the ESC chime tone/behavior during the mission delay.
autopilot_mission_force_restart0Force mission restart.
autopilot_mission_notif_dur0.1Visual notification using motor spin, duration in seconds.
en_external_ap_timesync1Enable responding to timesync messages.
en_external_ap_heartbeat1Enable automatic sending of heartbeat.
en_elrs_rc_muxfalse(v1.4.18 and newer) RC-source mux for the rc_active pipe with ELRS failsafe awareness.
udp_mtu512Maximum transfer unit for aggregated UDP packets back to the GCS. Set to 0 to disable aggregation. See below.
gcs_timeout_s4.5Time without a heartbeat before a GCS is considered disconnected.
Never set primary_static_gcs_ip or secondary_static_gcs_ip to localhost, these are meant for external ground control stations. For local MAVSDK and MAVROS communication, set the en_localhost_mavlink_udp flag in voxl-vision-hub’s /etc/modalai/voxl-vision-hub.conf file instead.
udp_mtu
For radios, such as Doodle Labs, that utilize larger packet sizes with increased latency, voxl-mavlink-server can bundle mavlink messages headed to the GCS into larger UDP packets. Since v1.4.14 this aggregation is on by default with a udp_mtu of 512 bytes. Set udp_mtu to 0 to disable aggregation and send one UDP packet per message. The config file contains the following description of the field:
 * udp_mtu - maximum transfer unit for UDP packets back to GCS. voxl-mavlink-server
 *           will bundle up backets for the GCS into a single UDP packet with
 *           a maxium size of this. This saves network traffic drastically.
 *           Set to 0 to disable this feature and send one UDP packet per msg.
Try a few different values such as 100, 200, 300 etc to find an optimal value for your setup.
Pipes
voxl-mavlink-server publishes the following 14 pipes into MPA.
Data from the high-rate onboard stream:
  • mavlink_onboard: full high-rate ‘onboard mode’ mavlink stream from the autopilot
  • mavlink_ap_heartbeat: autopilot heartbeat messages
  • mavlink_sys_status: sys_status messages
  • mavlink_gps_raw_int: gps_raw_int messages
  • mavlink_attitude: attitude messages
  • mavlink_local_position_ned: local_position_ned messages
  • imu_mavlink: IMU data from the autopilot
  • px4_baro: barometer data from the autopilot
  • rc_channels: RC channel data
  • rc_active: active RC source, muxing rc_channels and manual_control
GCS-related pipes:
  • mavlink_to_gcs: normal-rate stream from the autopilot to the GCS
  • mavlink_from_gcs: data coming from the GCS
  • gcs_ip_list: list of IP addresses of connected GCS
  • mission: mission data
Up to 16 simultaneous GCS connections can be established over UDP port 14550. See the Mavlink Routing feature guide for the routing paths and how to inspect these pipes with voxl-inspect-mavlink.
