Starling Hardware Quickstart
This section provides the minimum steps needed to get a device powered up and ready to connect to a console.
More details can be found on the Starling Hardware Overview and Datasheet pages, but are not necessary to complete the bootcamp.
1. Ensure propellor clips are installed:
2. Connect USB-C Cable
- Connect USB-C cable to VOXL 2
- Connect other side of USB-C cable (recommended USB type A) to host computer for later use
3. Power ON
- Connect the battery or wall power supply to the XT30 connector (labeled
Powerabove)- NOTE: do not arm the vehicle while using wall power
The development drone will bootup and play a jingle via the ESC.
How to Power Off
