Starling 2 Max Datasheet
Specifications
| Component | Specification |
| Autopilot | VOXL2 |
| Image Sensors | C28 Config - Dual IMX412, Dual AR0144 or C29 Config - Dual IMX412, Dual AR0144, TOF |
| Take-off Weight | 566g |
| Payload Capacity | 500g - will affect flight time with total takeoff weight ~930g |
| Max Speed | Cruise 15m/s, Dash (or burst) 20m/s |
| Wind Gusts | Tolerant to 15m/s |
| Service Ceiling | 4,000m MSL |
| Flight Time | ~55 minutes (with Amprius cells, ~40 min with LiIon) |
| Motors | 2203.5 1500kv |
| Propellers | 180mm Tri-Blade |
| Frame | 3mm Carbon Fiber |
| ESC | ModalAI 4-in-1 Mini ESC |
| GPS | UBlox M10 |
| RC Receiver | 915mhz ELRS or 2.4GHz Ghost Atto |
| Datalink | WiFi: AlfaNetworks AWUS036EACS, FCC ID: 2AB878811 |
| Power Module | Integrated with ModalAI 4-in-1 Mini ESC |
| Battery | Sony VTC6 3000mah 2S, or any 2S 18650 LiIon battery with XT30 connector |
| Diagonal | 512mm (propeller to propeller) |
| Height | 120mm (propeller to propeller) |
| Width | 450mm (propeller to propeller) 260mm (motor to motor) |
| Length | 380mm (propeller to propeller) 190mm (motor to motor) |
Critical Components
| Critical Electronic Component (CEC) | Encryption Type | Make | Model | Location of HQ | Country of Manufacture |
| Flight controller/autopilot | AES-256 Capable / Developer Enabled | VOXL 2 | M0154 | San Diego, CA | USA |
| Additional computers/companion computers | AES-256 Capable / Developer Enabled | VOXL 2 | M0154 | San Diego, CA | USA |
| Radios | -T7 BetaFPV Nano Rx -T9 Ghost Atto Rx | -T7 China -T9 Croatia | -T7 China -T9 Croatia | ||
| Data transmission devices | Developer Enabled | Alfa Network | AWUS036EACS | Taiwan | Taiwan |
| Camera(s) | N/A | ModalAI | M0161 M0166 | San Diego, CA | USA |
| Gimbals | N/A | N/A | |||
| GCS hardware | N/A | ||||
| GCS software | QGC / MAVLink Compatible | ||||
| C2 device/handset | -T7 iFlight Commando 8 Rx -T9 Ghost Atto Rx | -T7 China -T9 Croatia | -T7 China -T9 Croatia | ||
| Secondary tracking hardware (Remote ID, ADS-B, etc.) | N/A | ||||
| Payload(s) | N/A |
Hardware Wiring Diagram
Diagram draw.io Source
3D STEP
- Starling 2 Max 3D STEP R2 (October 2024 onwards)
- Starling 2 Max 3D STEP R1 (April through September 2024)
Add-On Board
The add-on board used on this vehicle has an I2C, UART and GPIOs along with the USB interface. See datasheet for pinouts.
