Sentinel Reference Drone Quickstart
The User’s Guide walks through taking Sentinel out of the box and up into the air!
What’s in the Box
- Sentinel Drone
- 10” props
- Two sets of Propellor ring adapters
- 5G Modem or Microhard Modem or Wifi (Optional)
Required Materials
To follow this user guide, you’ll need the following:
- Spektrum Transmitter
- e.g. SPMR6655, SPM8000 or SPMR8000
- Any Spektrum transmitter with DSMX/DSM2 compatibility will likely work
- Buy Here
- Power Supply or Battery with XT60 connector
- Host computer with:
- QGroundControl 3.5.6+
- Ubuntu 18.04+
- Wi-Fi
- USB Type C Cable
Sentinel Vehicle Components
The following images give an overview of the vehicle components.
Front
Side
Top
Bottom
Safety First!
For setup and configuration of your Sentinel you must Remove the Propellers for safety.
Battery Information
Sentinel requires a Gens Ace 5000mAh, or any 3S battery with XT60 connector.
Buy Battery Here
To install a 3s battery, slide into the body as shown. There is a stop at the front of the vehicle that will prevent the battery from sliding too far forward. The battery should be pressed all the way in until it hits the stop for a consistent center of mass.
Power on Sentinel by connecting the battery to the XT60 connector.
Benchtop Power Supply
For desktop use, a 12VDC wall power supply can be used and is available here. This is convenient when doing development.
