SDK 1.6.X Release Notes
Available now at https://developer.modalai.com/asset/
SDK 1.6.X Support Matrix
PlatformPCB TargetsSupport Status
VOXL 2M0054-1, M0054-2, M0154-1, M0154-2
VOXL 2 MiniM0104-1
MVX-T0001MM0204-1
MVX-R0001M0205-1, M0206-1
The SDK-1.6.3 release on the QRB5165 platform uses the 1.8.06 system image. See here for system image release notes.
  1. SDK 1.6.X Release Notes
  2. SDK 1.6.3 Package List and Changelog
    1. SDK 1.6.3 MD5 Hashes
    3. SDK 1.6.3 Full Changelog (from SDK 1.6.2)
  3. SDK 1.6.2 Package List and Changelog
    1. SDK 1.6.2 MD5 Hashes
    2. SDK 1.6.2 Package List
    3. SDK 1.6.2 Full Changelog (from SDK 1.6.1)
  4. SDK 1.6.1 Package List and Changelog
    1. SDK 1.6.1 MD5 Hashes
    2. SDK 1.6.1 Package List
    3. SDK 1.6.1 Full Changelog (from SDK 1.6.0)
  5. SDK 1.6.0 Package List and Changelog
    1. SDK 1.6.0 MD5 Hashes
    2. SDK 1.6.0 Package List
    3. SDK 1.6.0 Full Changelog (from SDK 1.5.0)
  6. SDK 1.6.X Test Matrix
    1. SDK 1.6.1 Test Status
SDKHash
voxl2_SDK_1.6.3.tar.gz47042164dc24b673ddb2e7f5d6d4e5ec
voxl2-mini_SDK_1.6.3.tar.gz37c93636de4953203c30abaa35eb048b
ubun2.0-multi_SDK_1.6.3.tar.gzb3ea20ec39ad706825a48496d4866837
Release date: February 6, 2026
Package list and changes from SDK-1.6.2 to SDK-1.6.3
PackageVersion
libfc-sensor1.0.8 –> 1.0.9
libmodal-cv0.6.0 (unchanged)
libmodal-exposure0.1.4 (unchanged)
libmodal-flow1.0.3 (unchanged)
libmodal-journal0.2.7 (unchanged)
libmodal-json0.4.8 (unchanged)
libmodal-pipe2.14.8 –> 2.14.11
libqrb5165-io0.5.0 –> 0.6.3
librc-math1.4.6 (unchanged)
libslpi-link1.0.1 (unchanged)
libvoxl-cci-direct0.3.2 –> 0.3.3
libvoxl-codec0.0.1 –> 0.0.2
libvoxl-cutils0.1.6 (unchanged)
modalai-slpi1.2.2 (unchanged)
qrb5165-dfs-server0.2.0 (unchanged)
qrb5165-mini-tof-server0.2.2 (unchanged)
qrb5165-rangefinder-server0.1.6 (unchanged)
qrb5165-tflite2.17.2 (unchanged)
voxl-bind-spektrum0.1.1 (unchanged)
voxl-camera-calibration0.6.1 (unchanged)
voxl-camera-server2.2.17 –> 2.2.19
voxl-ceres-solver2:1.14.0-10 –> 2:2.0.0-2
voxl-configurator1.0.9 –> 1.1.5
voxl-cpu-monitor0.7.4 –> 0.7.7
voxl-docker-support1.3.1 (unchanged)
voxl-eigen33.4.0 (unchanged)
voxl-elrs0.4.9 –> 1.1.0
voxl-esc1.5.7 (unchanged)
voxl-esptool0.2.0 (unchanged)
voxl-feature-tracker0.5.2 (unchanged)
voxl-flow-server0.3.6 (unchanged)
voxl-gphoto2-server0.0.10 (unchanged)
voxl-imu-server1.2.3 –> 2.0.1
voxl-io-server0.0.6 –> 0.0.8
voxl-jpeg-turbo2.1.3-7 (unchanged)
voxl-joystick-server0.0.12 –> 0.1.2
voxl-lepton-server1.3.3 (unchanged)
voxl-lepton-tracker0.0.4 (unchanged)
voxl-libgeographic1.0.0 (unchanged)
voxl-libgphoto20.0.4 (unchanged)
voxl-libnanotrack0.1.4 (unchanged)
voxl-libuvc1.0.7 (unchanged)
voxl-logger0.6.0 –> 0.6.1
voxl-mapper0.2.2 –> 0.2.4
voxl-mavcam-manager0.6.0 (unchanged)
voxl-mavlink0.1.6 (unchanged)
voxl-mavlink-server1.4.12 –> 1.4.14
voxl-microdds-agent3.0.0-0 (unchanged)
voxl-modem1.2.2 –> 1.2.3
voxl-mongoose7.7.0-2 –> 7.19.0
voxl-mpa-to-ros0.3.9 (unchanged)
voxl-mpa-to-ros20.0.7 (unchanged)
voxl-mpa-tools1.5.5 –> 1.5.6
voxl-nano-tracker0.1.7 (unchanged)
voxl-nlopt2.5.0-4 –> 2.5.0-5
voxl-open-vins0.4.19 (unchanged)
voxl-open-vins-server0.5.7 –> 0.6.0
voxl-opencv4.5.5-3 (unchanged)
voxl-osd0.2.1 –> 0.3.8
voxl-portal0.8.4 –> 0.8.7
voxl-px41.14.0-2.0.124 –>1.14.0-2.0.133
voxl-fpv-px41.14.0-8.133.0 (unchanged)
voxl-px4-params0.8.10 –> 0.9.0
voxl-qvio-server1.2.2 –> 1.2.3
voxl-remote-id0.0.9 (unchanged)
voxl-reset-slpi0.0.1 (unchanged)
voxl-ros2-foxy0.0.1 (unchanged)
voxl-state-estimator0.0.5 –> 0.0.6
voxl-streamer0.8.0 (unchanged)
voxl-tag-detector0.0.5 –> 0.1.0
voxl-tflite-server0.5.0 –> 0.5.1
voxl-utils1.4.9 –> 2.0.2
voxl-uvc-server0.1.7 (unchanged)
voxl-vision-hub1.9.9 –> 1.9.21
voxl-voxblox1.1.5 (unchanged)
voxl-vtx1.7.6 –> 2.0.2
voxl-wavemux0.0.3 (unchanged)
voxl2-io0.0.3 (unchanged)
libfc-sensor (1.0.8 to 1.0.9)
1.0.9
    * add support for qcs6490
libmodal-pipe (2.14.8 to 2.14.11)
2.14.11
    * Updated VFC flight mode names on OSD to be more informative to reader
2.14.10
    * Add offboard_log_t
2.14.9
    * new crsf_raw_data_t type
    * new payload_status_t type
2.14.8
    * add more robust ion buffer client tracking
libvoxl-cci-direct (0.3.2 -> 0.3.3)
0.3.3
    * add CI job for qrb5165-2
libqrb5165-io (0.5.0 to 0.6.3)
0.6.3
    * fix ci
0.6.2
    * Enable M0198 GPIOs
0.6.1
    * Add PI4IO Driver for qcs6490
0.6.0
    * Starting to build for qcs6490
    * new voxl_spi_read_reg_bmi function
libvoxl-codec (0.0.1 to 0.0.2)
0.0.2
    * add rotation param for encoder metadata tracking
    * add setframerate method to encoders
    * cleanup warnings, versions, and file locations
voxl-camera-server (2.2.17 to 2.2.19)
2.2.19
    * add C50 and C51 configs
2.2.18
    * fix compiler warnings
    * update fpv default gamma settings
    * fix boson buffer pre-alloc size
voxl-ceres-solver (2:1.14.0-10 to 2:2.0.0-2)
2:2.0.0-2
    * move to new cross
2:2.0.0-1
    * upgrade to upstream 2.0.0, building without patches
    * enabled blas and lapack
    * building in cross-4.3
voxl-configurator (1.0.9 to 1.1.5)
1.1.5
    * enable IO server by default on D0020
1.1.4
    * fix package manager issue
1.1.3
    * update D0011 modem support
1.1.2
    * fix inadvertant voxl-elrs call for GHST configs
    * fix voxl-joysticker-server configuration
1.1.1
    * add joystick configure for fiber drones
    * update joystick flags
    * cleanup configure sku wizard
    * update D0008-V4 vvhub config
1.1.0
    * initial support for m0197 vtx vrx
    * cleaner prompts in configure sku wizard
voxl-cpu-monitor (0.7.4 to 0.7.7)
0.7.7
    * cleanup and robustness
0.7.6
    * dynamically detect thermal zones on start based on known zone type
0.7.5
    * migrate en_auto_pitmode json field in config to boolean
    * update thermal zones for m0197
voxl-elrs (0.4.9 to 1.1.0)
1.1.0
    * betafpv config updates
1.0.9
    * fix changelog again
1.0.8
    * fix changelog formatting
1.0.7
    * libelrs add write_channel_value
    * correct crsf_protocol address bytes
    * update supi_pwm to support latest dropper
1.0.6
    * use get-params-hash at the end of enumerate
    * add get-params-hash cmd and function
    * update configs to disable SUPI pins by default
1.0.5
    * elrs_mpa wait for pipe on bootup instead of giving nondescript error
    * elrs configure move invalid config error from voxl_json to voxl-crsf
    * voxl-elrs configure fail if config is wrong and reduce timeouts
    * firmware update only stop px4 if required
    * reduce verbose logging
    * config: fix lights order, OFF, IR, OVERT
    * fix configure function not working when update required
1.0.4
    * config: stinger fix LED&IR PWM map values
    * config: stinger remove payload config from platform
    * config: seeker remove disconnected pin4
1.0.3
    * 3.5.3.21 firmware
    * fix STR_MAP_MODES
    * fix TEXT_SELECTION
    * fix supi_gpio.json
1.0.2
    * Remove --force flag, use --target to bypass version checks
    * Standardize update/configure commands with explicit --target/--sku flags
    * Filter TX variants from firmware listings (RX-only)
    * Display available targets when device detection fails
    * Improve console output formatting
1.0.1
    * Provide option to specify channel for MPA
1.0.0
    * Libelrs initial version
    * Supports linux serial, slpi uart, and px4 uorb backends
    * Supports CRSF parameter interface
    * Supports firmware updates through xmodem bootloader or esptool
    * Supports presets based on regex for sku
    * Overhauled cli
    * Removed tui
    * Overhauled preset interface
    * 3.5.3.20 firmware
voxl-imu-server (1.2.3 to 2.0.1)
2.0.1
    * refactor thermal cal
2.0.0
    * bmi270 working on M0197
    * rename to voxl-imu-server
voxl-io-server (0.0.6 to 0.0.8)
0.0.8
    * fix joystick confliction with rf by stop using rc_state to send button_value
    * disarm and rearm elrs pwms on joystick loss/reconnect
0.0.7
    * add payload monitoring and status, support FTDI type and M0184 gpio actuator type
voxl-joystick-server (0.0.12 to 0.1.2)
0.1.2
    * clear state on re-connect
0.1.1
    * add fiber support
0.1.0
    * Remove deprecated functionality
voxl-logger (0.6.0 to 0.6.1)
0.6.1
    * add voxl-convert-cal
voxl-mapper (0.2.2 to 0.2.4)
0.2.4
    * disbale qrb5165-2 build for now until it can be tested
    * migrate to cross 4.4
0.2.3
    * enable qrb5165-2 build
voxl-mavlink-server (1.4.12 to 1.4.14)
1.4.14
    * set default udp_mtu to 512
1.4.13
    * add qcs6490 support
    * add config items for primary and secondary gcs ports
voxl-modem (1.2.2 to 1.2.3)
1.2.3
    * add voxl-inspect-modem-5g
voxl-mongoose (7.7.0-2 to 7.19.0)
7.19.0
    * mongoose upgrade to version 7.19
voxl-mpa-tools (1.5.5 to 1.5.6)
1.5.6
    * put voxl-inspect-cam-ascii back in for qcs6490 to test opencv linking
voxl-nlopt (2.5.0-4 to 2.5.0-5)
2.5.0-5
    * qrb5165-2
voxl-open-vins-server (0.5.7 to 0.6.0)
0.6.0
    * changes for customizable quality gates - D0008-V4
voxl-osd (0.2.1 to 0.3.8)
0.3.8
    * OSD will display true VFC flight mode instead of "OFFBOARD"
0.3.7
    * Updated PX4 flight mode names on OSD to be more informative to reader
0.3.6
    * Basic OSD functionality is operational over joystick server
0.3.5
    * Update some OSD element default locations
0.3.4
    * Lower throttle to arm (manual/acro) is functional over through wifi over joystick server
0.3.3
    * Update control file depends for QCS6490
0.3.2
    * Removed unused flight modes from osd menu
0.3.1
    * Updated Betaflight support: Stream switching via RC switch, disable flight modes menu, populate RC channels menu
0.3.0
    * Add QCS6490 support
0.2.4
    * Add payload status
0.2.3
    * Flight mode instantly updates upon save and exit from OSD flight mode menu
0.2.2
    * Use OSD to customize which toggles correspond with certain flight modes on the controllers flight mode switch
voxl-portal (0.8.4 to 0.8.7)
0.8.7
    * build for qcs6490
    * stop spamming error messages if mavlink-server is not running
0.8.6
    * new ELRS page
0.8.5
    * voxl-nano-track commands with new camera viewpoint
voxl-px4 (1.14.0-2.0.124 to 1.14.0-2.0.133)
1.14.0-2.0.133
    * Added support for ST IIS2MDC Magnetometer
1.14.0-2.0.132
    * Optimize commander worker thread to persist between tasks (prevent qcs6490 calibration failure)
    * Fix memory leaks and threading bugs in QURT tasks
1.14.0-2.0.131
    * Added support for M0197 (qcs6490)
1.14.0-2.0.130
    * vehicle_local_position bridge: Set all unused fields to NaN
1.14.0-2.0.129
    * crsf_bridge: fix allowing multiple simultaneous control packets in one callback
1.14.0-2.0.128
    * Added vehicle local position data export via uORB to MPA bridge
1.14.0-2.0.127
    * Fixed flight core build error
1.14.0-2.0.126
    * Added a power status message received count to the voxl_esc driver for extra debug
1.14.0-2.0.125
    * CRSF raw processing improvements
voxl-px4-params (0.8.10 to 0.9.0)
0.9.0
    * update params for fiber use-case
voxl-qvio-server (1.2.2 to 1.2.3)
1.2.3
    * auto trim the _ion suffix from new viocam config file
voxl-state-estimator (0.0.5 to 0.0.6)
0.0.6
    * fix memleaks due to unfreed rc_vector and rc_matrix instances
voxl-tag-detector (0.0.5 to 0.1.0)
0.1.0
    * support remaining tag families
    * fully migrate to cross 4.4
    * remove libvoxl-cutils as dependency
    * set config file to read tracking_front and tracking_down by default
voxl-tflite-server (0.5.0 to 0.5.1)
0.5.1
    * LOTS of bug fixes and stability improvements
voxl-utils (1.4.9 to 2.0.2)
2.0.2
    * multiple interface support for voxl-static-ip-watcher
    * update interface detection
    * fix fomatting bug in voxl-inspect-services
2.0.1
    * new voxl-dma-latency service
2.0.0
    * initial support for qcs6490
    * replace now-deprecated qrb5165-system-tweaks
    * voxl-my-ip now lists all ipv4 addresses and their interfaces
    * support for wifi insterfaces with arbitrary names, not just wlan0
    * new voxl-serial utility
    * support for concurrent station/softap on M0213
    * woxl-wifi feature to turn on and off usb0 network interface
voxl-vision-hub (1.9.9 to 1.9.21)
1.9.21
    * separate D0008-V4 and V5 - qmin
    * ext_vfc_data_t add-on
    * remove offboard_log struct
    * add vfc conf files
1.9.20
    * switch activation for (yaw) tracking.
1.9.19
    * new vfc altitude controller
    * disable hover thrust estimate for now
    * now wait in vfc-alt mode while waiting for VIO to be ready to pos
    * braking zone for alt -> pos transition
1.9.18
    * vfc fix thrust setpoint during position transition
1.9.17
    * Changes to VIO PID/PD D0008/D0013
1.9.16
    * decrease D XY term to reduce roll bouncing
    * D0013 increase Z authority, reduce roll ringing
1.9.15
    * large vertical displacements causing backtrack discontinuity
1.9.14
    * remove vfc position mode arming, takeoff assist and PX4 overrides
1.9.13
    * reduce q_min for flow_back vio configs
    * add HITL support for VFC flow flight mode
    * clean up compiler warnings
1.9.12
    * d0013 more aggressive tune
    * move state manager to new MPA HITL VIO server when in HITL mode
1.9.11
    * fix typo in status message
    * fix backtrack restore after leaving backtrack mode when roll/pitch is idle
voxl-vtx (1.7.6 to 2.0.2)
2.0.2
    * Add rebroadcast encoded video in MPEG-TS format
2.0.1
    * Add retransmission via IP (UDP)
2.0.0
    * Add support for QCS6490
    * Integration of libvoxl-codec
    * enable invert_toggle by default on boson profile
1.8.6
    * Update weston config files
1.8.5
    * Add blackout mode
    * Update some VRX OSD element locations
    * Add OSD disable via RC (non-Betaflight)
1.8.4
    * Reopen socket for ATAK/UAS Tool on bad file descriptor
1.8.3
    * Update Betaflight support: OSD Disable
1.8.2
    * Update Betaflight support: stream switching via RC switch
1.8.1
    * Add vtx and vrx configuration script helpers for fiber use case
1.8.0
    * Add ulog logging on VRX
    * Update efuse script efuse set failure rather than error
1.7.8
    * Add support for nanotracker, configurable ai detectiond data source per profile
1.7.7
    * Add initial bi-directional communication
    * Add support for mission uploads via ATAK
SDKHash
voxl2_SDK_1.6.2.tar.gzd6fd51843b8a73ed610220acddf89076
voxl2-mini_SDK_1.6.2.tar.gza278f7b5937f2a0f0e71298507073f32
ubun2.0-multi_SDK_1.6.2.tar.gz28c5bb314f62eaff7fa9ea62d38f9b70
Release date: November 14, 2025
Package list and changes from SDK-1.6.1 to SDK-1.6.2
PackageVersion
libfc-sensor1.0.8 (unchanged)
libmodal-pipe2.14.8 (unchanged)
libqrb5165-io0.5.0 (unchanged)
libvoxl-cci-direct0.3.2 (unchanged)
libvoxl-codec0.0.1 (unchanged)
qrb5165-imu-server1.2.3 (unchanged)
qrb5165-system-tweaks0.3.8 (unchanged)
voxl-camera-server2.2.17 (unchanged)
voxl-ceres-solver2:1.14.0-10 (unchanged)
voxl-configurator1.0.9 (unchanged)
voxl-cpu-monitor0.7.4 (unchanged)
voxl-elrs0.4.9 (unchanged)
voxl-io-server0.0.6 (unchanged)
voxl-joystick-server0.0.12 (unchanged)
voxl-logger0.6.0 (unchanged)
voxl-mapper0.2.2 (unchanged)
voxl-mavlink-server1.4.12 (unchanged)
voxl-modem1.2.2 (unchanged)
voxl-mongoose7.7.0-2 (unchanged)
voxl-mpa-tools1.5.4 –> 1.5.5
voxl-nlopt2.5.0-4 (unchanged)
voxl-open-vins-server0.5.6 –> 0.5.7
voxl-osd0.2.1 (unchanged)
voxl-portal0.8.4 (unchanged)
voxl-px41.14.0-2.0.124 (unchanged)
voxl-px4-params0.8.10 (unchanged)
voxl-qvio-server1.2.2 (unchanged)
voxl-state-estimator0.0.5 (unchanged)
voxl-tag-detector0.0.5 (unchanged)
voxl-tflite-server0.5.0 (unchanged)
voxl-utils1.4.9 (unchanged)
voxl-vision-hub1.9.9 (unchanged)
voxl-vtx1.7.6 (unchanged)
voxl-mpa-tools (1.5.4 to 1.5.5)
1.5.5
    * make starling2 2-cam default
voxl-open-vins-server (0.5.6 to 0.5.7)
0.5.7
    * change for arming in px4 mpc pos
    * debug fix for jerk+qual compliance
    * qual only reports cep in init if zup occured
SDKHash
voxl2_SDK_1.6.1.tar.gz7cce5a96877c95ac835ebe27a17382f7
voxl2-mini_SDK_1.6.1.tar.gzf65a287db6d5c048ee9de6695c6a0b57
ubun2.0-multi_SDK_1.6.1.tar.gze285a60224e059e1e3ad02f1dfb224ca
Release date: November 8, 2025
Package list and changes from SDK-1.6.0 to SDK-1.6.1
PackageVersion
voxl-camera-server2.2.16 –> 2.2.17
voxl-configurator1.0.8 –> 1.0.9
voxl-modem1.2.1 –> 1.2.2
voxl-mpa-tools1.5.3 –> 1.5.4
voxl-open-vins-server0.5.6 (unchanged)
voxl-osd0.2.0 –> 0.2.1
voxl-px41.14.0-2.0.121 –>1.14.0-2.0.124
voxl-px4-params0.8.9 –> 0.8.10
voxl-vtx1.7.1 –> 1.7.6
voxl-camera-server (2.2.16 to 2.2.17)
2.2.17
    * Remove unused OSD code
    * add option to rotate AR0144 encoded video
    * add option to invert boson output via a command
    * add boson 14 bit support
    * eis tweaks
voxl-configurator  (1.0.8 to 1.0.9)
1.0.9
    * add D0013-V2 handling
voxl-modem  (1.2.1 to 1.2.2)
1.2.2
    * fix quectel-CM build
voxl-mpa-tools  (1.5.3 to 1.5.4)
1.5.4
    * add D0013 Stinger V2 extrinsic file
voxl-osd  (0.2.0 to 0.2.1)
0.2.1
    * OSD will send a signal to VTX/VRX to start/stop debug logs
voxl-px4  (1.14.0-2.0.121 to 1.14.0-2.0.124)
1.14.0-2.0.124
    * Fixed hover thrust estimate backup timeout so that it won't run in addition to the normal callback
1.14.0-2.0.123
    * Added CRSF raw data transfer via MPA to uORB bridge
1.14.0-2.0.122
    * Added external baro device id as an option for baro temp cal
    * Added baro temp cal abort if data is bad (all 0s/nan)
SDKHash
voxl2_SDK_1.6.0.tar.gz01e569484214fa573454e513f349947d
voxl2-mini_SDK_1.6.0.tar.gzc015ef52cabac2613c70bce57760f9de
ubun2.0-multi_SDK_1.6.0.tar.gz78c2a8aa4ffdd2b0b4701a92c3ad60d4
Release date: November 5, 2025
Package list and changes from SDK-1.5.0 to SDK-1.6.0
PackageVersion
libfc-sensor1.0.7 –> 1.0.8
libmodal-cv0.5.18 –> 0.6.0
libmodal-flow1.0.3 (new)
libmodal-journal0.2.6 –> 0.2.7
libmodal-json0.4.7 –> 0.4.8
libmodal-pipe2.13.2 –> 2.14.8
librc-math1.4.5 –> 1.4.6
libslpi-link1.0.0 –> 1.0.1
libvoxl-codec0.0.1 (new)
libvoxl-cutils0.1.5 –> 0.1.6
modalai-slpi1.2.0 –> 1.2.2
qrb5165-imu-server1.1.3 –> 1.2.3
qrb5165-rangefinder-server0.1.5 –> 0.1.6
qrb5165-system-tweaks0.3.6 –> 0.3.8
qrb5165-tflite2.8.0-2 –> 2.17.2
voxl-camera-calibration0.6.0 –> 0.6.1
voxl-camera-server2.2.4 –> 2.2.9
voxl-configurator1.0.2 –> 1.0.8
voxl-cpu-monitor0.6.0 –> 0.7.4
voxl-elrs0.4.7 –> 0.4.9
voxl-esc1.5.4 –> 1.5.7
voxl-io-server0.0.6 (new)
voxl-joystick-server0.0.6 –> 0.0.12
voxl-libgeographic1.0.0 (new)
voxl-logger0.5.3 –> 0.6.0
voxl-mavcam-manager0.5.8 –> 0.6.0
voxl-mavlink0.1.5 –> 0.1.6
voxl-mavlink-server1.4.9 –> 1.4.12
voxl-modem1.1.8 –> 1.2.1
voxl-mpa-tools1.4.0 –> 1.5.3
voxl-open-vins-server0.3.12 –> 0.5.6
voxl-osd0.1.8 –> 0.2.0
voxl-portal0.7.11 –> 0.8.4
voxl-px41.14.0-2.0.105 –>1.14.0-2.0.121
voxl-px4-params0.7.5 –> 0.8.9
voxl-qvio-server1.2.0 –> 1.2.2
voxl-streamer0.7.5 –> 0.8.0
voxl-tag-detector0.0.4 –> 0.0.5
voxl-tflite-server0.4.1 –> 0.5.0
voxl-utils1.4.8 –> 1.4.9
voxl-vision-hub1.8.23 –> 1.9.9
voxl-vtx1.4.7 –> 1.7.1
voxl-wavemux0.0.3 (new)
libfc-sensor (1.0.7 to 1.0.8)
1.0.8
    * added a new function to directly access the SLPI MONOTONIC time
libmodal-journal  (0.2.6 to 0.2.7)
0.2.7
    * add QCS6490 support
libmodal-json  (0.4.7 to 0.4.8)
0.4.8
    * migrate to cross4.3
libmodal-pipe  (2.13.2 to 2.14.8)
2.14.8
2.14.7
    * add better ion buffer release functionality
2.14.6
    * new functions pipe_send_control_cmd and pipe_send_control_cmd_bytes
    * revert ion_buf_t size
2.14.5
    * add new commands for cpu modes to cpu_stats2_t interface
2.14.4
    * Add source field to ion buffer
    * Set format and consumerFlags fields of ion buffer
    * add RAW14 to list of supported formats
    * suppress unsupported format warning for RGBA and RAW16
2.14.3
2.14.2
    * Fix for ion buffer shutdown
2.14.1
    * new tool: voxl-inspect-pipe-info
2.14.0
    * new timing and sleep functions
    * new cpu_stats2_t type
2.13.4
    * Add new backtrack active field to vfc type
    * fix optional support of mavlink
2.13.3
    * Seperate interface files, add barometer
librc-math  (1.4.5 to 1.4.6)
1.4.6
libslpi-link  (1.0.0 -> 1.0.1)
1.0.1
    * added ability to reset the connection
libvoxl-cutils  (0.1.5 to 0.1.6)
0.1.6
modalai-slpi  (1.2.0 to 1.2.2)
1.2.2
    * added a new flight controller function to uninitialize an i2c port
1.2.1
    * Added new flight controller UART function to check rx bytes
    * Added new flight controller UART function to flush rx
    * Increased flight controller UART rx buffer size to match slpi link
qrb5165-imu-server  (1.1.3 to 1.2.3)
1.2.3
    * cpu thermal cal routine now disables cpu pitmode so it can get hot enough
1.2.2
    * fix bug where occationally fifo would stop reading if async command from camera server stopped and started again
    * imu now starts reading right away instead of waiting for a client
    * improvements to support multiple imus
1.2.1
    * add commands in for controlling calibrator through commands from portal
    * add new imu_apps_raw pipe so calibrators can always view raw data
    * "start_calibration" command is now not needed and ignored
1.2.0
    * cleanup build
    * remove old ICM20948 driver
    * convert fft code to C
    * prepare for voxl-cross 4 build environment
qrb5165-rangefinder-server  (0.1.5 to 0.1.6)
0.1.6
    * add m0195 config
qrb5165-system-tweaks  (0.3.6 to 0.3.8)
0.3.8
    * voxl-static-ip-watcher cleanup
0.3.7
    * add voxl-static-ip-watcher
qrb5165-tflite  (2.8.0-2 to 2.17.2)
2.17.2
    * cleanup
2.17.1
    * new op support
voxl-camera-calibration  (0.6.0 to 0.6.1)
0.6.1
    * take cpu out of pitmode for calibration
    * throw a warning if user is trying to calibrate an ar0144 tracking cam without fisheye option
    * lock to larger cores for better performance
voxl-camera-server  (2.2.4 to 2.2.9)
2.2.9
    * fix build issues (libmodal-pipe changes)
2.2.8
    * fix h265 bitrate control
2.2.7
    * remove voxl-cpu-monitor as build dependency
    * fix bug in camera-server-config-helper
2.2.6
    * force cross 4.4
2.2.5
    * add C48
    * fix stereo cam pair going out of sync due to too high of an allowed discrepancy
voxl-configurator  (1.0.2 to 1.0.8)
1.0.8
    * update D0020 elrs pwm configs
1.0.7
    * fix elrs pwm settings on D0020
1.0.6
    * D0020 and other vfc tunes
1.0.5
    * add D0017 Shikra support
    * new openvins configs
1.0.4
    * add D0020 basic framework
1.0.3
    * update voxl-streamer config handling
voxl-cpu-monitor  (0.6.0 to 0.7.4)
0.7.4
    * update voxl-inspect-cpu to add json one-shot logic
0.7.3
    * add systemd watchdog timer function for safety
    * cleanup process hashmap periodically when it gets cluttered
    * new debug tool churn_pid.sh for stress testing
0.7.2
    * new commands to set auto and perf cpu modes while enabling auto pitmode
0.7.1
    * add more obvious pitmode_enable option to configurator
    * fix individual process cpu use being limited to 100.0 percent
0.7.0
    * monitor processes with highest cpu and memory utilization
    * new default behavior is to have cpu in cool mode when disarmed
    * pipe type definitions moved out into libmodal_pipe
    * memory leak detection
    * two-stage overheat warning
    * cpu load is now absolute (not scaled by frequency)
    * new memory allocation rate monitoring
    * support for qcs6490
voxl-elrs  (0.4.7 to 0.4.9)
0.4.9
    * update firmware releases
0.4.8
    * Aligned PWM configuration with fw 3.5.3.15
    * Updated configurations for D0008 (and similar)
voxl-esc  (1.5.4 to 1.5.7)
1.5.7
    * speed up D0013 stinger spinup to 200ms
1.5.6
    * more D0020 Tuning
    * robustness improvement in M0138 firmware
1.5.5
    * initial D0020 tune
    * lower cmd-rate in voxl-esc-calibrate.py to prevent buffer backup when running on VOXL
voxl-logger  (0.5.3 to 0.6.0)
0.6.0
    * update to cross 4.4
    * remove old tof_data_t type support
voxl-mavlink-server  (1.4.9 to 1.4.12)
1.4.12
    * fix for SYS_ID != 1
1.4.11
    * make ci pipeline happy
1.4.10
    * internal baro is published to mpa, external baro is published to px4 via mavlink
voxl-mavlink  (0.1.5 to 0.1.6)
0.1.6
    * undo accidental mavlink submodule change
    * current mavlink commit hash is 5383d892c071095af3f9ad24ceb7b0fb6e18f81f
voxl-modem  (1.1.8 to 1.2.1)
1.2.1
    * auto detect Doodle Lab modem interface from driver name
1.2.0
    * add tailscale mods for startup
    * add lte specific voxl-configure-modem option
1.1.9
    * Add support for Doodle VTX
voxl-mpa-tools  (1.4.0 to 1.5.3)
1.5.3
    * fix voxl-inspect-imu printing
1.5.2
    * re-enable vfc fallback to internal vfc-alt mode when VIO isn't ready
    * smooth out vfc z pid
1.5.1
    * update defaults for vfc config to reflect new z controller
    * add -t (--test) options to various voxl-inspect tools
1.5.0
    * enable secondary cam intrinsics cal file name detection
1.4.9
    * name changes for D0008-V4
1.4.8
    * speed up voxl-list-pipes -t
    * voxl-list-pipes sorts by type by default
1.4.7
    * add OSD visualizer
1.4.6
    * remove vfc arming
1.4.5
    * decrease q_min to 2 as default
    * update vio_cam_configs
    * changes for inspecting ion stream
1.4.4
    * new dependency on libmodal_pipe >1.14.0
    * migrate to new modal pipe timing functions
    * add prints of n samples received to voxl-inspect-imu
1.4.3
    * independent vfc config file
1.4.2
    * builds in cross 4.1 without voxl-opencv dependency
1.4.1
    * inspect-baro
voxl-open-vins-server  (0.3.12 to 0.5.6)
0.5.6
    * bump vins version for flow API and stereo tracking
    * bug fix for entering zupt, when doing jerk detection
    * quality overhaul
    * modify onm dyn priors and gates
0.5.5
    * change disparities and reset fix
0.5.4
    * added jerk detection and atomic handling fix
    * fix bug in reset logic
    * increase feature timeout to 10s
0.5.3
    * added grace timeout on vio init
0.5.2
    * fix for min feature reset and first cam connect
    * toggle missing feature on reset
    * fixed reset stall and double reset from no features
0.5.1
    * adjust verbosity for config script
    * changes for d0008-v4 double ion stream
0.0.1a
    * New server and OV lib with several architectural changes
voxl-osd  (0.1.8 to 0.2.0)
0.2.0
    * Add option set OSD element color
0.1.31
    * Add basic Ready/Not Ready to arm indicator
    * Remove status message
0.1.30
    * Add turtle mode flight mode indicator
0.1.29
    * Implemented ability to adjust joystick sensitivity values within OSD
0.1.28
    * Removed time debounce from OSD, joystick input will now rely solely on physical debounce
0.1.27
    * Update positions for some OSD elements
0.1.26
    * Update default positions for some OSD elements
0.1.25
    * Implemented debounce requiring joystick to return to center position before another input is registered
0.1.24
    * Updates to OSD menu usability
0.1.23
    * Add more cpu status stats
0.1.22
    * Add MAVLink Telemetry Control via debug OSD menu
0.1.21
    * Add throttle warning to OSD when trying to arm in manual mode and throttle is too high
0.1.20
    * Fixed math errors in the bearing to home calculation
    * Fixed math error in the distance to home calculation
    * Fixed the method to check if the global position message is recent to prevent display issues
    * Don't show altitude and to home if no gps msg
    * Add MGRS precision configuration option
0.1.19
    * Adjust OSD element locations
    * Update MGRS format
0.1.18
    * Heading and distance / bearing to home cleanup
    * Move some OSD elements around
0.1.17
    * Add voxl-libgeographic dependency
0.1.16
    * Add MGRS cooridnates
0.1.15
    * Add velocity
0.1.14
    * Use Link Quality instead of RSSI for RC
0.1.13
    * Updates for GPS dist to home and others
0.1.12
    * Added GPS fusion to heading indicator if it isn't being done by PX4
0.1.11
    * Version bump to kick off CI build on new docker image
0.1.10
    * Update RC Channels menu
    * Save advanced menu updates to configuration file
0.1.9
    * Update battery param used for cell voltage calculation
voxl-portal  (0.7.11 to 0.8.4)
0.8.4
    * Updated to voxl-mongoose 7.19 library
0.8.3
    * add status updates for voxl-mavlink-server and voxl-PX4
    * display per-IMU update stages during calibration
0.8.2
    * add imu status updates to calibration
0.8.1
    * add apps-proc imu cal to accelerometer cal procedure
0.8.0
    * huge cleanup. migrate to cross 4
voxl-px4-params  (0.7.5 to 0.8.9)
0.8.9
    * disable battery low and crit thresholds for FPV drones
0.8.8
    * disable BAT_LOW_VOLT for FPV drones
0.8.7
    * set EKF2_BARO_GATE to 100 to prevent baro from being disabled preventing arming
0.8.6
    * pull in D0019 tuning updates from sdk 1.5.1
0.8.5
    * update D0020 failsafes
0.8.4
    * switch test loadout to RTL on CH 10
0.8.3
    * enable RTL on D0019 and D0020
0.8.2
    * update D0019 to clean param set, mostly duplicating D0020
0.8.1
    * set COM_HOME_IN_AIR to 1 to allow RTL when GPS is bad
0.8.0
    * added more stringent check for gps on D0020
    * raise landing slowdown ALT2 to 10m
0.7.9
    * undo typo, oops
0.7.8
    * set up 2-stage RC Lost failsafe on D0020
    * disable D0020 mag
0.7.7
    * More D0020 cleanup.
0.7.6
    * initial D0020 starting point
    * move CI to cross 4
voxl-px4  (1.14.0-2.0.105 to 1.14.0-2.0.121)
1.14.0-2.0.121
    * Changed hard coded battery time low failsafe from RTL to Warn
1.14.0-2.0.120
    * Decreased voxlpm battery_status logging interval from 100ms to 20ms
1.14.0-2.0.119
    * Decreased voxl_esc battery_status logging interval from 100 ms to 20 ms
    * Changed printf to PX4_INFO in voxlpm status output
1.14.0-2.0.118
    * Increased battery_status logging rate from 5 Hz to 50 Hz
1.14.0-2.0.117
    * Added a new module called sensor_baro_bridge to send sensor_baro data to an MPA pipe
1.14.0-2.0.116
    * Add start for vehicle_air_data_bridge into start scripts
    * Use DSP clock directly on Posix for CLOCK_MONOTONIC
1.14.0-2.0.115
    * baro_temp_cal updated to stop pit mode while calibrating
1.14.0-2.0.114
    * Fix FC compiler error
1.14.0-2.0.113
    * Implemented basic keepalive mechanism between apps and DSP
    * Added parameters to control keepalive failure actions. Can be configured to force a blind land and to force disarm after some period.
    * Added MPA capability
1.14.0-2.0.112
    * Added turtle mode reporting to the heartbeat mavlink message as a custom field
    * Removed support for RB5 (M0052)
1.14.0-2.0.111
    * Fixed compilation failure for FCv2
1.14.0-2.0.110
    * VOXL ESC: Added a parameter controlled option to send pwm commands instead of rpm commands
1.14.0-2.0.109
    * Added support for dps368 external barometer on apps processor
    * Added support for external ICP10100 barometer on apps processor
    * Made logging with sequential file names the default
1.14.0-2.0.108
    * Improved GPS failure simulation in HITL
    * VOXL ESC: Added M0129-6 as possible ESC type in print out
    * Added support for Mavlink reboot command
    * Added support for the reboot system command
1.14.0-2.0.107
    * Added estimator_aid_src_baro_hgt as a default logging topic to help debug ekf2 instability
    * Reduced baro fusion timeout from 5 seconds to 500 ms
    * HITL: Moved heartbeat send into actuator send thread to avoid race conditions
1.14.0-2.0.106
    * Fixed Mavlink battery status to properly fill in voltages_ext fields
	* Fixed CRSF telemetry
voxl-qvio-server  (1.2.0 to 1.2.2)
1.2.2
    * update for new cpu_stats2 interface
1.2.1
    * swap to 64-bit build for qrb5165-2
    * cleanup and cross4.3 migration
voxl-streamer  (0.7.5 to 0.8.0)
0.8.0
    * migrate to building in cross4
0.7.6
    * Add support for fpv restream
voxl-tflite-server  (0.4.1 to 0.5.0)
0.5.0
    * building in vross 4.3 with new tflite 2.17.1
0.4.2
    * fixed yolov11, updated tflite
voxl-utils  (1.4.8 to 1.4.9)
1.4.9
    * add tailscale to network prefs
voxl-vision-hub  (1.8.23 to 1.9.9)
1.9.9
    * allow failsafe reentry into position mode with still sticks
1.9.9
    * Thermal Flow set relative alt vs global alt based on pilot input
1.9.8
    * D13 alt fix
1.9.7
    * bump
1.9.6
    * smoother transition for sprung loaded throttle R/C units
1.9.5
    * PX4-ALT to VFC clean up mode switching logic--no arm if already blown up
1.9.4
    * config version bump, D0020 support
1.9.3
    * Fix smart takeoff to reset backtrack history
1.9.2
    * moved VFC config into independent file
1.9.1
    * VFC POS/ALT direct arming, soft takeoff mechanism
1.9.0
    * migrate to cross 4.1, enable build for qrb5165-2
1.8.28
    * VFC hover thrust quicker autotune and autosave to conf after 10secs of solid hold
1.8.27
    * VFC hover thrust feature made active. Update thru voxl-config.
1.8.26
    * VFC hover thrust template added. Reduce default PID settings for vfc's ALT and POS modes.
1.8.25
    * VFC yaw tweaks. Add iterm to thrust control and tilt compensation for all VFC auto modes. Alpha-version VFC robust takeoff module.
1.8.24
    * mission cancel into VFC position mode
libmodal-flow (1.0.3)
1.0.3
    * changed track function params to enable stereo
    * optimizations, detection on pyr lvl 1, qcom recordable queue
1.0.2
    * build to fix sdk 1.6.0 dependencies (rollback to v1.0.0)
1.0.1
1.0.0
    * fixed ManagerCL teardown
0.0.1
    * added initial files
libvoxl-codec (0.0.1)
0.0.1
    * add template for cross project
voxl-io-server
0.0.6
    * updates to build in cross 4.4
0.0.5
    * add Mavlink tunnel option for modalal_io
0.0.4
    * add zorro config
0.0.3
    * add bash completion to voxl-send-neopixel-cmd
0.0.2
    * fix id byte not being sent in the test program
0.0.1
    * First commit
voxl-libgeographic (1.0.0)
1.0.0
    * initial release
SymbolDefinition
Passed
In Progress
Failed
Not Supported
ArchitectureDescriptionIndoor Test StatusOutdoor Test Status
D0011PX4 Autonomy Dev Kit, see: Starling
D0012Starling 2 Max, see: Starling
D0013Stinger Vision, see: Stinger
D0014Starling 2, see: Starling
