SDK 1.5.X Release Notes
Available now at https://developer.modalai.com/asset/
SDK 1.5.X Support Matrix
| Platform | PCB Targets | Support Status |
| VOXL 2 | M0054-1, M0054-2, M0154-1, M0154-2 | |
| VOXL 2 Mini | M0104-1 | |
| VOXL | M0006-2 | |
| VOXL Flight | M0019-2 | |
| Qualcomm Flight RB5 | M0052-2 | |
| Flight Core v2 | M0087-1 | |
| Flight Core v1 | M0018-1 |
The SDK-1.5.0 release on the QRB5165 platform uses the 1.8.04 system image. See here for system image release notes.
SDK 1.5.0 Package List and Changelog
Release date: June 25, 2025
Package list and changes from SDK-1.4.5 to SDK-1.5.0
| Package | Version | APQ8096 | QRB5165 |
| apq8096-dfs-server | 0.3.1 (unchanged) | ✅ | |
| apq8096-imu-server | 1.1.0 (unchanged) | ✅ | |
| apq8096-libpng | 1.6.38-1 (unchanged) | ✅ | |
| apq8096-rangefinder-server | 0.1.3 (unchanged) | ✅ | |
| apq8096-system-tweaks | 0.2.3 (unchanged) | ✅ | |
| apq8096-tflite | 2.8.3-1 (unchanged) | ✅ | |
| libapq8096-io | 0.6.1 (unchanged) | ✅ | |
| libfc-sensor | 1.0.7 (unchanged) | ✅ | |
| libmodal-cv | 0.5.18 (unchanged) | ✅ | ✅ |
| libmodal-exposure | 0.1.4 (unchanged) | ✅ | ✅ |
| libmodal-journal | 0.2.5 –> 0.2.6 | ✅ | ✅ |
| libmodal-json | 0.4.7 (unchanged) | ✅ | ✅ |
| libmodal-pipe | 2.13.1 –> 2.13.2 | ✅ | ✅ |
| libqrb5165-io | 0.5.0 (unchanged) | ✅ | |
| librc-math | 1.4.5 (unchanged) | ✅ | ✅ |
| libslpi-link | 1.0.0 (unchanged) | ✅ | |
| libvoxl-cci-direct | 0.3.2 (unchanged) | ✅ | ✅ |
| libvoxl-cutils | 0.1.5 (unchanged) | ✅ | ✅ |
| modalai-slpi | 1.1.20 –> 1.2.0 | ✅ | |
| qrb5165-dfs-server | 0.2.0 (unchanged) | ✅ | |
| qrb5165-imu-server | 1.1.3 (unchanged) | ✅ | |
| qrb5165-mini-tof-server | 0.2.2 (new) | ✅ | |
| qrb5165-rangefinder-server | 0.1.5 (unchanged) | ✅ | |
| qrb5165-system-tweaks | 0.3.5 –> 0.3.6 | ✅ | |
| qrb5165-tflite | 2.8.0-2 (unchanged) | ✅ | |
| voxl-bind-spektrum | 0.1.1 (unchanged) | ✅ | |
| voxl-boost | 1.65.0 (unchanged) | ✅ | |
| voxl-camera-calibration | 0.5.9 –> 0.6.0 | ✅ | ✅ |
| voxl-camera-server | 2.2.1 –> 2.2.4 | ✅ | ✅ |
| voxl-ceres-solver | 2:1.14.0-10 (unchanged) | ✅ | ✅ |
| voxl-configurator | 1.0.1 –> 1.0.2 | ✅ | ✅ |
| voxl-cpu-monitor | 0.6.0 (unchanged) | ✅ | ✅ |
| voxl-docker-support | 1.3.1 (unchanged) | ✅ | ✅ |
| voxl-elrs | 0.4.7 (unchanged) | ✅ | |
| voxl-esc | 1.5.2 –> 1.5.4 | ✅ | |
| voxl-feature-tracker | 0.5.2 (unchanged) | ✅ | |
| voxl-flow-server | 0.3.6 (unchanged) | ✅ | |
| voxl-gphoto2-server | 0.0.10 (unchanged) | ✅ | ✅ |
| voxl-io-server | 0.0.5 –> deprecated | ✅ | |
| voxl-jpeg-turbo | 2.1.3-7 (unchanged) | ✅ | ✅ |
| voxl-joystick-server | 0.0.6 (new) | ✅ | |
| voxl-lepton-server | 1.3.3 (unchanged) | ✅ | ✅ |
| voxl-lepton-tracker | 0.0.4 (unchanged) | ✅ | |
| voxl-libgphoto2 | 0.0.4 (unchanged) | ✅ | ✅ |
| voxl-libuvc | 1.0.7 (unchanged) | ✅ | ✅ |
| voxl-logger | 0.5.3 (unchanged) | ✅ | ✅ |
| voxl-mapper | 0.2.2 (unchanged) | ✅ | ✅ |
| voxl-mavcam-manager | 0.5.8 –> 0.6.0 | ✅ | ✅ |
| voxl-mavlink-server | 1.4.7 –> 1.4.9 | ✅ | ✅ |
| voxl-modem | 1.1.6 –> 1.1.8 | ✅ | ✅ |
| voxl-mongoose | 7.7.0-2 (unchanged) | ✅ | ✅ |
| voxl-mpa-tools | 1.4.0 (unchanged) | ✅ | ✅ |
| voxl-mpa-to-ros | 0.3.9 (unchanged) | ✅ | ✅ |
| voxl-mpa-to-ros2 | 0.0.7 (unchanged) | ✅ | |
| voxl-nlopt | 2.5.0-4 (unchanged) | ✅ | ✅ |
| voxl-opencv | 4.5.5-3 (unchanged) | ✅ | ✅ |
| voxl-open-vins | 0.4.19 (unchanged) | ✅ | |
| voxl-open-vins-server | 0.3.12 (unchanged) | ✅ | |
| voxl-osd | 0.1.7 –> 0.1.8 | ✅ | |
| voxl-portal | 0.7.10 –> 0.7.11 | ✅ | ✅ |
| voxl-px4 | 1.14.0-2.0.104 –>1.14.0-2.0.105 | ✅ | |
| voxl-px4-imu-server | 0.1.2 –> deprecated | ✅ | |
| voxl-px4-params | 0.7.3 –> 0.7.5 | ✅ | |
| voxl-qvio-server | 1.2.0 (unchanged) | ✅ | ✅ |
| voxl-remote-id | 0.0.9 (unchanged) | ✅ | |
| voxl-reset-slpi | 0.0.1 (unchanged) | ✅ | |
| voxl-ros2-foxy | 0.0.1 (unchanged) | ✅ | |
| voxl-state-estimator | 0.0.5 (unchanged) | ✅ | |
| voxl-streamer | 0.7.5 (unchanged) | ✅ | ✅ |
| voxl-tag-detector | 0.0.4 –> 0.0.5 | ✅ | ✅ |
| voxl-tflite-server | 0.4.1 (unchanged) | ✅ | ✅ |
| voxl-utils | 1.4.7 –> 1.4.8 | ✅ | ✅ |
| voxl-uvc-server | 0.1.7 (unchanged) | ✅ | ✅ |
| voxl-vision-hub | 1.8.21 –> 1.8.23 | ✅ | ✅ |
| voxl-voxblox | 1.1.5 (unchanged) | ✅ | ✅ |
| voxl-vpn | 0.0.6 (unchanged) | ✅ | |
| voxl-vtx | 1.3.14 –> 1.4.7 | ✅ | |
| voxl2-io | 0.0.3 (unchanged) | ✅ |
SDK 1.5.0 Full Changelog (from SDK 1.4.5)
libmodal-journal (0.2.5 to 0.2.6)
0.2.6
* Fixed incorrect debug level calculation
libmodal-pipe (2.13.1 to 2.13.2)
2.13.2
* Reset accepting p frames flag for all clients on encoded streams when receiving a new stream header
qrb5165-system-tweaks (0.3.5 to 0.3.6)
0.3.6
* fix voxl-platform for M0205
voxl-camera-calibration (0.5.9 to 0.6.0)
0.6.0
* update to voxl-cross:V4.0
voxl-camera-server (2.2.1 to 2.2.4)
2.2.4
* Enable MISP encoded stream on downward tracking
* update OV9782 ae_desired_msv and gamma
2.2.3
* Add QRB5165-2 support
* Enable Codec2 support on QRB5165-2
* add C22 for platform 1
2.2.2
* Fix FPV camera default softmin exposure
voxl-configurator (1.0.1 to 1.0.2)
1.0.2
* D0019 updates
* voxl-streamer config fixes
voxl-esc (1.5.2 to 1.5.4)
1.5.4
* more D0013 spinup tweaks
1.5.3
* fix D0013 spinup
voxl-io-server
0.0.5
* add Mavlink tunnel option for modalal_io
0.0.4
* add zorro config
0.0.3
* add bash completion to voxl-send-neopixel-cmd
0.0.2
* fix id byte not being sent in the test program
0.0.1
* First commit
voxl-mavcam-manager (0.5.8 to 0.6.0)
0.6.0
* add check to see if video record pipe exists
0.5.9
* MAV_AUTOPILOT_GENERIC -> MAV_AUTOPILOT_INVALID in heartbeat
voxl-mavlink-server (1.4.7 to 1.4.9)
1.4.9
* VFC missions support RTL & LAND waypoints
voxl-modem (1.1.6 to 1.1.8)
1.1.8
* Publish stats for Doodle Labs radios
1.1.7
* update to python3
voxl-osd (0.1.7 to 0.1.8)
0.1.8
* Add VTX CPU and memory usage to OSD
* Update advanced menu
* Add Debug OSD menu and RC Channels menu
voxl-portal (0.7.9 to 0.7.11)
0.7.11
* add imu and rangefinder to portal
0.7.10
* Added Benchmark tab to display ov log data
* Barometer calibration updates
voxl-px4-imu-server
0.1.2
* cleanup configure script
0.1.1
* New CI Stuff
0.1.0
* first release
0.0.1
* initial commit
voxl-px4-params (0.7.3 to 0.7.5)
0.7.5
* update OSD params
0.7.4
* D0019 tuning updates
voxl-px4 (1.14.0-2.0.98 to 1.14.0-2.0.105)
1.14.0-2.0.105
* Added MC autotune module to apps side build
1.14.0-2.0.104
* Went back to the baro_temp_cal script from 1.14.0-2.0.101 with some minor tweaks
1.14.0-2.0.103
* Reverted the baro_temp_cal script update from 1.14.0-2.0.101
* Artificially set TMIN to 0 and TMAX to TMAX + 10 in barometer temperature calibration script
1.14.0-2.0.102
* Updated the custom icm42688p IMU driver to use RTC input and to have optional temperature compensation
1.14.0-2.0.101
* Updated baro_temp_cal script to make sure that there is a wide enough temperature range and low enough starting temperature
1.14.0-2.0.100
* Zero RF yaw fix
1.14.0-2.0.99
* update to dds to expose battery status as ros2 endpoint from dds
voxl-tag-detector (0.0.4 to 0.0.5)
0.0.5
* update to voxl-cross:v4.0
voxl-utils (1.4.7 to 1.4.8)
1.4.8
* add M0205 support
voxl-vision-hub (1.8.21 to 1.8.23)
1.8.23
* VFC mission: PX4 rtl & land modes used if requested in mission. Fine tune takeoff.
1.8.22
* VFC mission mode turn to waypoint before translation, smoother traj, tuning
voxl-jpeg-turbo
2.1.3-7
* update for new cmake
2.1.3-6
* bump version to fix qrb5165-2 build
2.1.3-5
* fix native build
2.1.3-4
* cleaned up postinst
2.1.3-3
* fresh CI release
2.1.3-2
* ci stages change
2.1.3-1
* added conflicts/replaces fields for libjpeg-turbo
2.1.3
* voxl build of libjpeg_turbo v2.1.3
voxl-mongoose
7.7.0-2
* new cross template updates
7.7.0-1
* patch to set sockets in blocking mode only
7.6.0
* testing master branch slightly ahead of v7.6, but has massive socket improvements
7.3.0-2
* ci stage updates
7.3.0-1
* added conflicts/replaces for mongoose
7.3.0
* working voxl build, mongoose version 7.3
SDK 1.5.X Test Matrix
| Symbol | Definition |
| Passed | |
| In Progress | |
| Failed | |
| Not Supported |
SDK 1.5.0 Test Status
| Architecture | Description | Indoor Test Status | Outdoor Test Status |
| D0001 | m500 | ||
| D0003 | Seeker | ||
| D0004 | Qualcomm Flight RB5 5G Deprecated | ||
| D0005-4 | Starling | ||
| D0006-4 | Sentinel | ||
| D0011 | PX4 Autonomy Dev Kit, see: Starling | ||
| D0012 | Starling 2 Max, see: Starling | ||
| D0014 | Starling 2, see: Starling |
