M500 Hardware Quickstart
Quickstart Video
1. Ensure propellors are removed
2. Connect Micro USB Cable
- Connect Micro USB cable to the M500 (labeled
USB for VOXLbelow) - Connect other side of USB cable (recommmended USB type A) to host computer for later use
3. Power ON
- Connect the battery or wall power supply to the XT30 connector at the rear of the vehicle
- NOTE: do not arm the vehicle while using wall power
How to Power Off
