- Overview
- Block Diagram
- Dimensions
- 3D Drawings
- Connector Callouts
- J1 - Legacy Voxl Debug/Expansion Port
- J2 - High Speed Board to Board Port
- J6 - FTDI Serial DEBUG Port
- J7 - uSD/UFS Combo Card Slot
- J8 - SPI Port
- J9 - 2W UART + I2C Port
- J10 - USB Host Type A Port
- J11 - USB Host 10-Pin ModalAI Format
- J12 - USB Host 4-Pin ModalAI Format
Block Diagram
Dimensions
3D Drawings
3D Step
Connector Callouts
| Connector | MPN |
| Board Connector | QTH-030-01-L-D-A-K-TR |
| Mating Connector | https://docs.modalai.com/voxl2-connectors/#j3—legacy-board-to-board-connector-b2b |
Color: Black
| Connector | MPN |
| Board Connector | ADM6-30-01.5-L-4-2-A-TR |
| Mating Connector | https://docs.modalai.com/voxl2-connectors/#j5—high-speed-board-to-board-connector-hsb2b |
Color: Black
| Connector | MPN |
| Board Connector | Amphenol 10118194-0001LF |
| Mating Connector | Micro-USB Plug |
| Pin | Net | M0062 Usage |
| 1 | VBUS_DEBUG | VBUS |
| 2 | DBG_HS_CON_D_N | Debug Port USB_D- |
| 3 | DBG_HS_CON_D_P | Debug Port USB_D+ |
| 4 | USB_ID | Not Connected (FTDI is Always Host) |
| 5 | DGND | System GND |
| Connector | MPN |
| Board Connector | Amphenol 1010170469#2A |
| Mating Products | uSD Card or UFS Card |
| Pins | Nets | M0062 Usage |
| FRONT | UFS, 1 Lane | Automatically Picked up when inserting UFS card |
| BACK | uSD (SDCC) | Automatically Picked up when inserting uSD card |
J8 - SPI Port
| Connector | MPN |
| Board Connector | JST SM06B-GHS-TB |
| Mating Connector | JST GHR-06V-S |
| 1 | VREG_3P3V_LOCAL | 3.3V Reference Voltage |
| 2 | SPI_MISO_3P3V_CON | QUP_17 SPI_MISO, 3.3V CMOS |
| 3 | SPI_MOSI_3P3V_CON | QUP_17 SPI_MOSI, 3.3V CMOS |
| 4 | SPI_SCLK_3P3V_CON | QUP_17 SPI_SCLK, 3.3V CMOS |
| 5 | SPI_CS0_N_3P3V_CON | QUP_17 SPI_CS0, 3.3V CMOS |
| 6 | DGND | System GND |
| Connector | MPN |
| 2 | UART_TX_3P3V_CON | QUP_19 UART TX, 3.3V CMOS |
| 3 | UART_RX_3P3V_CON | QUP_19 UART RX, 3.3V CMOS |
| 4 | I2C_SDA_3P3V_CON | QUP_10 I2C_SDA, 3.3V CMOS |
| 5 | I2C_SCL_3P3V_CON | QUP_10 I2C_SCL, 3.3V CMOS |
| Connector | MPN |
| Board Connector | Molex 0483930003 |
| Mating Connector | USB-A Plugs to USB device |
| 1 | VBUS_PORT2 | 5V VBUS, 1A Limit |
| 2 | USB1_HS_CON_D_N | Host Port USB_D- |
| 3 | USB1_HS_CON_D_P | Host Port USB_D+ |
| 4 | DGND | System GND |
| 5 | USB1_SS_RX_N | Host Port SuperSpeed USB RX- (may not work) |
| 6 | USB1_SS_RX_P | Host Port SuperSpeed USB RX+ (may not work) |
| 7 | DGND | System GND |
| 8 | USB1_SS_TX_CONN_N | Host Port SuperSpeed USB TX- (may not work) |
| 9 | USB1_SS_TX_CONN_P | Host Port SuperSpeed USB TX+ (may not work) |
| 10 | DGND | System GND |
| Connector | MPN |
| Board Connector | JST BM10B-GHS-TBT |
| Mating Connector | JST GHR-10V-S |
| 1 | VBUS_PORT3 | 5V VBUS, 1A Limit |
| 5 | USB1_SS_RX_N | Host Port SuperSpeed USB RX- |
| 6 | USB1_SS_RX_P | Host Port SuperSpeed USB RX+ |
| 8 | USB1_SS_TX_CONN_N | Host Port SuperSpeed USB TX- |
| 9 | USB1_SS_TX_CONN_P | Host Port SuperSpeed USB TX+ |
| Connector | MPN |
| Board Connector | JST BM04B-GHS-TBT (may be blue format) |
| Mating Connector | JST GHR-04V-S |
| 1 | VBUS_PORT4 | 5V VBUS, 1A Limit |
