LTE Modem v2 Dongle Datasheet
- Board Connections and I/O
- Specifications
- LEDs
- Connector Pinouts
- Environmental
- 2D/3D Drawings
- Connection to Companion Computers
Specifications
Physical Specification
| Specicifcation | Value |
| Weight (with modem and lid) | 14g |
| Dimensions | 37.0 x 43.3mm |
| Upstream USB ports | 1 |
| Downstream USB ports | 2 |
| Cellular 3GPP Bands Supported | See Radio Specifications below |
| WWAN Antenna Connectors (MIMO) | UFL-R-SMT-110 |
| Recommend Antennas | W3907B0100 |
| Downstream USB Connectors | 4 Position JST GH, Vertical, BM04B-GHS-TBT |
| Downstream USB Mating Connector | JST GHR-04V-S |
Radio Specification
LTEH-SA-7607 (EMEA)
| Specification | Details |
| 4G LTE, Cat-4 | B1, B3, B7, B8, B20, B28 |
| 3G Fallback, HSPA+, UMTS | B1, B8 |
| 2G Fallback, EDGE, GSM, GPRS | 900, 1800 |
| Bandwidth | up to 150/50 Mbps Download/Upload |
LTEH-SA-7610 (North America)
| 4G LTE, Cat-4 | B2, B4, B5, B12, B13, B14, B17, B66 |
| 3G Fallback, HSPA+, UMTS | B2, B4, B5 |
SIM Cards and Supported Networks
The modem card requires the use of a Nano SIM card.
AT&T (FirstNet), Verizon and Sierra Wireless are supported by VOXL-ACC-LTEH-7610.
For Band 3 support, the VOXL-ACC-LTEH-7607 modem is required and Band 3 SIM cards need to be requested through ModalAI.
Power Consumption
| Configuration | 5V Power Consumption (mA) |
| Baseline (USB Hub, Glue Logic, All LEDs ON) | 150 |
| Baseline plus Qty-2 USB Peripherals at Max 500mA* | 1180 |
| Baseline + Qty-2 DS USB* + WP Series^ HSDPA Band 1 | 2010 |
| Baseline + Qty-2 DS USB* + WP Series^ HSDPA Band 8 | 1930 |
| Baseline + Qty-2 DS USB* + WP Series^ LTE Band 1 | 2240 |
| Baseline + Qty-2 DS USB* + WP Series^ LTE Band 7 | 2150 |
| Baseline + Qty-2 DS USB* + WP Series^ LTE Band 25 | 2265 |
^ Band power consumption information is limited to WP7502, WP7504, and WP8548 (max of these three, at listed mode & band). For other module power consumptions or alternate bands, please contact your local Sierra Wireless FAE, or ModalAI.
LEDs
Status LEDs
| LED | Description |
5VDC IN | Illuminates GREEN when the board is powered |
WWAN STAT | Illuminates GREEN when the modem is initialized |
PWR GOOD | Illuminates solid GREEN when all local power is good |
USB LEDs
The USB PORT2 PWR and USB PORT3 PWR LEDs illuminate green to indicate the USB device is powered when plugged in
Connector Pinouts
J3 - 5VDC Power In
- Connector - SM02B-SFHRS-TFLFSN
- Mating Connector - SFHR-02V-R
| Pin | Description |
| 1 | 5.0 VDC (@4A max) |
| 2 | GND |
J4 - Upstream USB Port
- Connector - 4 Position JST GH, Horizontal, SM04B-GHS-TB
- Mating Connector - JST GHR-04V-S
| Pin | Description |
| 1 | 5VDC (500mA max) |
| 2 | D- |
| 3 | D+ |
| 3 | GND |
J5 - Downstream USB Port 2
- Connector - 4 Position JST GH, Vertical, BM04B-GHS-TBT
| Pin | Description |
| 2 | D- |
| 3 | D+ |
| 3 | GND |
J6 - Downstream USB Port 3
| Pin | Description |
| 2 | D- |
| 3 | D+ |
| 3 | GND |
Environmental
Operating Temperature
TODO
2D/3D Drawings
M0030_REVA_WP_Socket_with_lid.stp
VOXL
RaspberryPi 4
NVidia Jetson TX2
Requires building a new Jetson TX2 system image, see notes here
