libvoxl_io
All serial ports and GPIO on VOXL are controlled by the Sensors DSP (SDSP) which allows for a lot of real-time processing to be offloaded from the Applications Processor for time-sensitive tasks such as handling high data-rate IMUs and Mavlink communication with a PX4 flight controller.
libvoxl_io serves to provide access to these functions from Linux Userspace without requiring the user to build Hexagon DSP Code. That being said, libvoxl_io is the only project for VOXL which is built using the voxl-hexagon docker image and serves as the best starting point for writing your own SDSP programs.
For the remainder of this page we will simply duplicate the documentation already provided in the header voxl_io.h.
RPC Shared Memory
* @brief allocates memory shared between SDSP and APPS proc
* @param[in] bytes bytes to allocate
* @return pointer to memory on success, NULL on failure
uint8_t* voxl_rpc_shared_mem_alloc(size_t bytes);
* @brief frees previously allocated RPC shared memory
* @param ptr pointer to memory
void voxl_rpc_shared_mem_free(uint8_t* ptr);
* @brief deinitiazes the RPC shared memory system
void voxl_rpc_shared_mem_deinit();
UART
#define UART_J7 9 // BLSP 9 on physical port J7 pins 2&3
#define UART_J10 7 // BLSP 7 on physical port J10 pins 2&3
#define UART_J11 12 // BLSP 12 on physical port J11 pins 2&3
#define UART_J12 5 // BLSP 5 on physical port J12 pins 2&3
#define UART_DATA_BUF_LEN 128 // uart read buffer should be this length
* @brief Initializes a UART bus /dev/tty-{bus} at specified baudrate
* This is a very generalized function that configures the bus for
* 8-bit characters, ignores the modem status lines, disables
* parity, disables canonical mode, and enables 1 stop bit. More
* flexibility in configuration could be added in the future if
* necessary. For now this covers the majority of sensors.
* @param[in] bus UART bus number (BLSP #)
* @param[in] baudrate must be one of the standard speeds in the UART spec.
* 115200 and 57600 are most common.
* @return 0 on success, -1 on failure
int voxl_uart_init(int bus, int baudrate);
* @brief closes a UART bus
* Please make an effort to call this before your process exits to
* help ensure a safe cleanup.
* @return returns 0 on success, -1 on error.
int voxl_uart_close(int bus);
* @brief Sends data out the specified uart port through the SDSP
* This will return immediately, even if the data hasn't been sent
* out yet. Use voxl_uart_drain if you need to ensure the data has
* been sent before continuing. Max write length is currently
* untested, UART_DATA_BUF_LEN is a safe limit.
* @param[in] data pointer to data to be sent
* @param[in] bytes number of bytes to send
* @return returns number of bytes sent or -1 on error
int voxl_uart_write(int bus, uint8_t* data, size_t bytes);
* @brief Reads any and all data available from the UART hardware buffer
* This is a non-blocking function call! You do not get to specify
* the number of bytes it reads, it will always read out everything
* in the hardware buffer. The dataLen argument should be the size
* of the data buffer in bytes which should generally be set to
* UART_DATA_BUF_LEN (128)
* @param data pointer to read buffer
* @param[in] dataLen length of the read buffer (should be UART_DATA_BUF_LEN)
* @return Returns number of bytes read or -1 on error.
int voxl_uart_read(int bus, uint8_t* data, size_t dataLen);
* @brief flushes (discards) any data received but not read, or data
* written but not sent.
* uses tcflush(fd, TCIOFLUSH)
* @return 0 on success or -1 on failure
int voxl_uart_flush(int bus);
* @brief waits for data in the write buffer to be sent before returning
int voxl_uart_drain(int bus);
Timing
* @brief get the current monotonic time of the sdsp in nanoseconds
* @return current monotonic time of the sdsp or -1 on error
int64_t voxl_sdsp_time_monotonic_ns();
* @brief get the current realtime time of the sdsp in nanoseconds
* @return current realtime time of the sdsp or -1 on error
int64_t voxl_sdsp_time_realtime_ns();
* @brief get the current monotonic time of the apps proc in nanoseconds
* @return current monotonic time of the apps proc or -1 on error
int64_t voxl_apps_time_monotonic_ns();
* @brief get the current realtime time of the apps proc in nanoseconds
* @return current realtime time of the apps proc or -1 on error
int64_t voxl_apps_time_realtime_ns();
* @brief get the time difference between apps and dsp clocks
* sdsp clock is ahead of the apps proc so this offset should be
* positive. Note that the SDSP clock is sourced differently than
* the apps-proc clock so you may see 10us drift each second between
* the two clocks. Don't assume this offset is constant forever!
* Represented as offset_ns = sdsp_monotonic_ns - apps_monotonic_ns
int64_t voxl_sdsp_time_offset_ns();
SPI
* The maximum length of any receive or transmit over SPI bus.
#define DSPAL_SPI_TRANSMIT_BUFFER_LENGTH 512
#define DSPAL_SPI_RECEIVE_BUFFER_LENGTH 512
* @brief Initializes a SPI port a specified mode and frequency
* For description of the 4 SPI bus modes, see
* <https://en.wikipedia.org/wiki/Serial_Peripheral_Interface_Bus#Mode_numbers>
* Frequency is provided in hertz. MPU9250 claims to support up to 20mhz but we observed corrupted data. In practice 10mhz is plenty fast.
* @param[in] bus SPI bus number (BLSP #)
* @param[in] bus_mode 0,1,2, or 3
* @param[in] freq_hz The frequency in hz
int voxl_spi_init(int bus, int bus_mode, int freq_hz);
* @brief update the speed of the SPI port
* Use this is you wish to run the bus slower for some operations
* and faster for others. For example register configuration may
* want to run more slowly for robustness but read in data quickly.
int voxl_spi_set_freq(int bus, int freq_hz);
* @brief closes a SPI bus
int voxl_spi_close(int bus);
* @brief writes data out the SPI bus
* data length can't exceed DSPAL_SPI_TRANSMIT_BUFFER_LENGTH (512)
* @param data pointer to data to be written
* @return 0 on success -1 on failure
int voxl_spi_write(int bus, uint8_t* data, int bytes);
* @brief reads specified number of bytes out of a register
* You cannot read/write more than DSPAL_SPI_RECEIVE_BUFFER_LENGTH (512)
* bytes at a time.
* @param write_buf data to send out bus
* @param[in] write_len number of bytes to write
* @param read_buf Buffer to write result into
* @param[in] read_len number of bytes to read
int voxl_spi_transfer(int bus, uint8_t* write_buf, int write_len, uint8_t* read_buf, int read_len);
* @brief writes a single byte register at specified address
* this works by writing the address followed by val which is how we
* write registers on the mpu9250 IMU. It may not work on your
* sensor.
* @param[in] address register address
* @param[in] val The value to write
int voxl_spi_write_reg_byte(int bus, uint8_t address, uint8_t val);
* @brief writes a single word (16 bit) register at specified address
* sensor.
int voxl_spi_write_reg_word(int bus, uint8_t address, uint16_t val);
* This works by sending the requested address with the MSB set to 1
* indicating a read operation on MPU9250 and similar IMUs. It then
* reads the specified number of bytes out. This is intended for MPU
* series IMUs and may not work with your sensor if it behaves
* differently.
* If reading chunks of data you should allocate RPC shared memory
* with voxl_rpc_shared_mem_alloc(size_t bytes) to use for the
* output buffer.
* You cannot read more than DSPAL_SPI_RECEIVE_BUFFER_LENGTH (512)
* bytes at a time.
* @param out_buf pointer to buffer write the result into
* @param[in] length The length of data to read in bytes
int voxl_spi_read_reg(int bus, uint8_t address, uint8_t* out_buf, int length);
* @brief reads a single byte register
* reads one byte out. This is intended for MPU series IMUs and may
* not work with your sensor if it behaves differently.
* @param out pointer to where to write the result
int voxl_spi_read_reg_byte(int bus, uint8_t address, uint8_t* out);
* @brief reads a single word (16-bit) register
* reads two bytes out. This is intended for MPU series IMUs and may
int voxl_spi_read_reg_word(int bus, uint8_t address, uint16_t* out);
IMU FIFO Reader
* @brief helper function to read out a regularly formed FIFO buffer
* This is intended for the MPU series IMU FIFO buffers. The process
* consists of first reading the number of bytes available in the
* IMU's FIFO as read from the fifo_count register address. This
* count should be a multiple of packet_size.
* The data (even multiple of packet_size) is then read out of the
* fifo_address register and placed into the out_buf buffer.
* The user should allocate RPC shared memory with
* voxl_rpc_shared_mem_alloc(size_t bytes) to use for the output
* buffer with at least the size of the IMU's FIFO. Also provide the
* size of this buffer with the dataLen argument so the functions
* knows not to write too far and create an overflow. You should
* make sure your RPC shared mem and this length are appropriately
* sized for the fifo you are reading.
* For example the icm42688 has a 2k buffer but also has additional
* read cache so it can technically hold 103 packets (2060) bytes.
* We use a 2k + 128 = 2170 bytes buffer in voxl-imu-server to be
* safe.
* The user can specify an optinal minimum number of packets to
* read. If greater than 0, the function will not return until the
* fifo has at least min_packets available to read. This can help
* reduce CPU usage at high sample rates.
* @param[in] count_address fifo_count register address
* @param[in] fifo_address fifo_data address
* @param[in] packet_size expected bytes per fifo packet
* @param[in] min_packets The minimum number of packets to read before
* returning
* @param[out] packets_read The number of packets read
* @param[out] data The output buffer (should be RPC shared memory)
* @param[in] dataLen Size of the output buffer.
* @param[in] count_speed SPI speed in hz to read fifo_count register
* @param[in] data_speed SPI speed in hz to read the fifo data register
int voxl_spi_read_imu_fifo( int bus, uint8_t count_address, uint8_t fifo_address,\
uint8_t packet_size, int min_packets, \
int* packets_read, uint8_t* data, int dataLen, \
int count_speed, int data_speed);
GPIO
//highest number of GPIO pin which can be used (note that actual available pin count may vary)
#define MAX_NUM_GPIO_PINS 256
#define GPIO_DIRECTION_INPUT 0
#define GPIO_DIRECTION_OUTPUT 1
* @brief Initializes a GPIO pin with desired direction and extra flags
* @param[in] gpio_pin GPIO pin number (not BLSP #)
* @param[in] direction Direction : GPIO_DIRECTION_INPUT or GPIO_DIRECTION_OUTPUT
* @param[in] flags Reserved for future use
int voxl_gpio_init(int gpio_pin, int direction, int flags);
* @brief Read the state of a GPIO pin
* The pin must be initialized using voxl_gpio_init before reading its state
* @param[in] gpio_state_ptr Pointer to the integer where pin state will be written
int voxl_gpio_read(int gpio_pin, int * gpio_state_ptr);
* @brief Set the state of a GPIO pin
* The pin must be initialized using voxl_gpio_init in output mode before setting its state
* @param[out] gpio_state Desired state of the pin (0=LOW or 1=High)
int voxl_gpio_write(int gpio_pin, int gpio_state);
* @brief Clean up after using GPIO pin
int voxl_gpio_close(int gpio_pin);
I2C
#define MAX_NUM_I2C_PORTS 16 //highest number of i2c port (BLSP #)
#define MAX_I2C_TX_BUFFER_SIZE 128
* @brief Initializes an I2C port
* Note that I2C bus speed and slave ID are sent using voxl_i2c_slave_config
* @param[in] bus I2C bus number (BLSP #)
int voxl_i2c_init(uint32_t bus);
* @brief Closes an I2C port
int voxl_i2c_close(uint32_t bus);
* @brief Configures I2C port for communication with a certain i2c slave ID
* @param[in] slave_address_7bit I2C slave address (7bit format, 7bit only (10 bit slave addresses are not supported))
* @param[in] bit_rate I2C bus bit rate (e.g 100000, 400000)
* @param[in] timeout_us Timeout for transfer (in microseconds)
int voxl_i2c_slave_config(uint32_t bus, uint16_t slave_address, uint32_t bit_rate, uint32_t timeout_us);
* @brief Write data to I2C slave device starting from the specified 8-bit register address
* @param[in] register_address Register address to access on the device (note: byte order is LS Byte first if > 8 bits)
* @param[in] address_num_bits Number of bits to use for sending register address (8, 16, 24, or 32)
* @param[in] output_buffer Buffer with data to send to the device
* @param[in] length Number of bytes to send to device (in addition to the register address)
int voxl_i2c_write(uint32_t bus, uint32_t register_address, uint32_t address_num_bits, uint8_t * write_buffer, uint32_t write_length);
* @brief Read data from I2C slave device starting from the specified 8-bit register address
* @param[in] input_buffer Buffer to hold the incoming data
* @param[in] length Number of bytes to read from device
int voxl_i2c_read(uint32_t bus, uint32_t register_address, uint32_t address_num_bits, uint8_t * read_buffer, uint32_t read_length);
UART Mavlink Parsing
* @brief starts a UART mavlink parsing thread on the SDSP
* buflen specifies how large of a buffer the SDSP should allocate
* internally. The user should allocate their own RPC shared memory
* buffer matching this length for the data to be copied out into
* late.
* There is currenly only one valid flag available:
* FLAG_MAVPARSER_ALLOW_CRC_FAILURES
* The allow CRC failures flag is useful because the CRC on Mavlink
* messages is more than just a message integrity check. It has been
* overloaded with a type of message version check and this can be
* specific to certain implementations. See the description of
* CRC_EXTRA at this link:
* https://mavlink.io/en/guide/serialization.html#crc_extra
* @param[in] bus The UART bus
* @param[in] baudrate The baudrate
* @param[in] buflen Buffer length for SDSP to use
* @param[in] flags flags to change behavior
int voxl_mavparser_init(int bus, int baudrate, int buflen, int flags);
* @brief Copies out any complete parsed mavlnk messages and their status
* to the RPC data buffer allocated during the init step.
* Each message has a corresponding status written to the user's
* status array. The status matches mavlink_framing_t:
* MAVLINK_FRAMING_OK=1, MAVLINK_FRAMING_BAD_CRC=2,
* MAVLINK_FRAMING_BAD_SIGNATURE=3
* Messages are returned to the user even if they are parsed with
* bad signatures or bad CRCs since these two errors don't necessary
* mean there was an integrity problem.
* The CRC on Mavlink messages is more than just a message integrity
* check. It has been overloaded with a type of message version
* check and this can be specific to certain implementations. If the
* mavlink packet structures used by the sender differs from the
* version we have built into this library, the CRC may fail. But
* once the message is forwarded to another receiver, they may
* decode the packet correctly with no CRC error. See the
* description of CRC_EXTRA at this link:
* This library is always built with the latest master branch of the
* Mavlink project to keep up with new packets.
* The status array should be long enough to hold the single-byte
* status of the maxiumum number of mavlink_message_t structs that
* can fit in the user's data buffer. See voxl-test-mavparser.c for
* an example.
* This function will block for up to 1/2 second and will return if
* at least one message is ready or the 1/2 second timeout elapsed.
* @param[out] data pointer to a mavlink_msg_t array to write out to
* @param status pointer to user's status array
* @return returns number of mavlink messages read or -1 on failure
int voxl_mavparser_read(int bus, char* data, uint8_t* status);
* @brief stop a mavparser thread
* @param[in] bus The uart bus
int voxl_mavparser_close(int bus);
Source
Source code available on GitLab.
