M0184 and M0193 ELRS Configurator and Firmware Build
  1. Overview
    1. Downloading Firmware
    2. Hardware Setup
    3. Setting Up the Configurator
To use ELRS configurator with M0184 and M0193, install ExpressLRS-Configurator 1.7.8+
To build and flash custom ExpressLRS firmware for the M0184 or M0193, first download the firmware repository. Open a terminal in your desired directory and run:
git clone https://github.com/modalai/ExpressLRS
To get a specific version of the ModalAI firmware, check out the desired tag from the tags list. Tags with a fourth version number include ModalAI’s patches for M0184 and M0193.
Hardware Setup
The ELRS configurator requires a direct connection to your modem in order to flash it. For receiver firmware: either use a USB-UART adapter connected to the TX, RX and GND pins on the modem or connect to a Betaflight FC over USB. For transmitter firmware: connect to the edgeTX USB and select USB Serial (VCP)
First, ‘Expert Mode’ must be enabled in the ELRS Configurator’s settings menu.
Next, in the flashing menu, go to the ‘Local’ tab and choose the src directory of the firmware repository you downloaded earlier as the ‘Local path’.
Then, choose ModalAI 900 MHz as the ‘Device Category’ and your modem as the device (ModalAI M0184 RX in this example).
At this point you should configure your firmware options like any other ELRS modem, in either standard or manual mode. Please see the ExpressLRS Configurator Documentation for more information on firmware options.
You should also select the correct flashing option for your hardware setup, either UART (serial) for receivers connected directly to your device with a USB-UART bridge, Betaflight Passthrough for a receiver connected to a Betaflight FC, or EdgeTX Passthrough for an internal transmitter modem.
After selecting the correct serial port, press the Flash button and the Configurator will build and flash your modem.
