Qualcomm Flight RB5 WiFi
Connecting to a WiFi Network
In order to connect your Qualcomm Flight RB5 to a WiFi network, you need to specify your network’s SSID and PASSWORD in the configuration file by doing the following:
adb shell
vi /data/misc/wifi/wpa_supplicant.conf
You will see a file similar to the following:
# Only WPA-PSK is used. Any valid cipher combination is accepted.
ctrl_interface=/var/run/wpa_supplicant
update_config=1
network={
#Open
# ssid="example open network"
# key_mgmt=NONE
#WPA-PSK
ssid="Your SSID here"
#proto=WPA
key_mgmt=WPA-PSK
pairwise=TKIP CCMP
group=TKIP CCMP
psk="Your PASSWORD here"
#WEP
# ssid="example wep network"
# key_mgmt=NONE
# wep_key0="abcde"
# wep_key1=0102030405
# wep_tx_keyidx=0
wowlan_triggers=magic_pkt
Modify the ssid and psk fields to correspond with your WiFi network’s details.
Save and exit out of vi with :wq! and reboot your Qualcomm Flight RB5 for your changes to take effect.
If you enter a valid ssid and psk and are within range of your WiFi router, the next time you boot your device it will automatically connect to your network.
