Qualcomm Flight RB5 VIO
Update 2022-07-20: the Qualcomm Flight RB5 vehicle is now supported by the VOXL SDK! Please see here from more information
VOXL SDK VIO Guide can be found here
Enabling VIO
VIO on the RB5 is disabled by default. The service file for VIO can be started by configuring the qvio server:
rb5-qvio-server-configure
Would you like to enable the qvio service?
This will start qvio as a background process
1) yes
2) no
Enter 1 (yes) to enable the service. This will immediately start VIO and enable it on boot.
Using VIO
In order to check if VIO is running you can check with the following command:
systemctl status rb5-qvio-server
This will show you the status of the rb5-qvio-server.
If the status displays active(runnning) then VIO is running and the VIO data is being sent to PX4.
If the status displays failed then VIO failed to run. Make sure that camera index 2(downward facing tracking camera) and PX4 are running.
To restart VIO, you can simply restart the service file:
systemctl restart rb5-qvio-server
VIO should be restarted and the drone should be idle before any flight where VIO will be used.
Viewing VIO Data
VIO data can be viewed by manually running the rb5-camera-client command:
rb5-qvio-client
NOTE A library path was set for this command, if you’re command doesn’t execute, inside your adb shell run ldconfig
This will print out position data in the following format:
T_imu_wrt_vio (m) |Roll Pitch Yaw (deg)| state| error_code
-0.11 -0.12 -0.06| -14.6 -30.1 -2.6| OKAY |
T_imu_wrt_vio represents your drones XYZ position in meters from your starting position. To validate this data, you can move the drone forwards and observe as the X value increases.
Flying with VIO
Confirm PX4 is Getting VIO Data
Once rb5-qvio-server is running, confirm quality data before flight by opening the mavlink inspector and checking that X&Y values are non-zero in the ODOMETRY mavlink telemetry packets.
Alternatively, if your computer running QGroundControl has its volume turned up you should hear it announce the swap from “manual” to “position” mode when you flip the flight mode switch from up to middle. If VIO data is not being transmitted, the system will fall back to altitude mode and you will hear “position mode rejected, altitude flight mode”. In this case, go back to manual flight mode (switch up) and wait a few more seconds for rb5-qvio-server to finish initializating.
If this doesn’t work, go back to “Viewing VIO Data” and reconfirm VIO is working with rb5-qvio-client. You can also check the rb5-qvio-server systemd service for indications of what might have gone wrong. We have a VIO parameters file helper located here to help easily configure into VIO or GPS mode. Specifically the EKF2_AID_MASK is often overlooked as an important parameter for VIO flight.
Some relevant PX4 parameters for VIO flight
# enable vision for height, position, and velocity, no GPS or barometer
1 1 EKF2_AID_MASK 280 6
1 1 EKF2_HGT_MODE 3 6
## set MD to 0 to allow covarience from VIO to be used
1 1 EKF2_EV_NOISE_MD 0 6
## Turn off EV Delay, VOXL will do proper timesyncing
1 1 EKF2_EV_DELAY 5.00 9
## increase bias limit to prevent preflight check failure
1 1 COM_ARM_EKF_AB 0.01 9
## Allow arming without GPS indoors
1 1 COM_ARM_WO_GPS 1 9
Confirm Data is in the Right Coordinate Frame
Take off in Position Mode
Next Step: Using Obstacle Avoidance
