Qualcomm Flight RB5 External Flight Controller
Repurpose J12 as a UART
There is a bug in the `1.0.5-M0052-9.1-perf` release preventing this from working. We are investigating a fix
Normally, PX4 uses the J12 connector’s UART (3.3V TTL) for an RC input. But, if you want to use an external flight controller you can instead use this UART as a means to communicate using something like MAVLink.
Disable PX4 from Running on DSP
First, you need to disable PX4 from running on target.
systemctl disable rb5-px4-start
Reboot the system.
Create a Cable
This is the J12 pinout.
| 1 | VREG_3P3V_RC | 3.3V Switchable Power Output * |
| 2 | RC_UART_TX (Output) | APPS_QUP_13, 3.3V signal levels |
| 3 | RC_UART_RX (Input) | APPS_QUP_13, 3.3V signal levels |
| 4 | GND | GND |
Interface with In Linux
This UART shows up as /dev/ttyHS1. Here’s a simple Python example.
import serial
uart_dev='/dev/ttyHS1'
uart = serial.Serial(uart_dev, 115200, xonxoff=False, rtscts=False, dsrdtr=False)
while True:
bytes = uart.read_all()
if len(bytes) > 0:
print(bytes)
Repurpose J19 as a UART
Similar to above, on RB5 Flight, J19 has a UART that is typically used for GNSS/PX4. This can be used similar as above using /dev/ttyHS2.
| 1 | VDC_5V_LOCAL | 5V protected Power Output * |
| 2 | GNSS UART TX (output) | APPS_QUP_18, 3.3V signal levels |
| 3 | GNSS UART RX (input) | APPS_QUP_18, 3.3V signal levels |
| 4 | MAG I2C SCL | SSC_QUP_0, 3.3V signal levels, 2.2K Pullup to VREG_3P3V_LOCAL |
| 5 | MAG I2C SDA | SSC_QUP_0, 3.3V signal levels, 2.2K Pullup to VREG_3P3V_LOCAL |
| 6 | GND | GND |
